У меня аналогичая проблема с точкой, перегрузка, сделал как описано на форуме операции в консоли в итоге пишет такое
WAP-G02A Boot Procedure V1.0
Start ..Boot.B14..
y version 3.0.0.43A
auto-booting...
Attaching to TFFS... done.
Loading /fl/APIMG1...
Please wait, loading image ...
image check ok!!!
/fl/ - Volume is OK
Reading Configuration File "/fl/apcfg".
Configuration file checksum: 8477e9 is good
Please check the ethernet cable on port 1!
halAttach: Failed to find an attachable driver for devid 0x0000
Error initializing wireless software state.
apInit: no wlan device
AP initilization failed!
Attaching interface lo0...done
ERROR: AP start-up failed! Wireless network services disabled.
Tlb Load Exception
Exception Program Counter: 0x8026a1d8
Status Register: 0x1000f001
Cause Register: 0x30800008
Access Address : 0x000022e0
Task: 0x80df7930 "ROMPAGER40"
Task ROMPAGER40 is dead
AP software 4.0.0.167
panic: trapmon detected a fatal error
Rebooting AP...
Waiting for cfg file to finish writing...done. Checksum: 8477ec
ar531x rev 0x00005850 firmware startup...
SDRAM TEST...PASSED
светодиод Power не горит, где копать дальше подскажите пожалусто.
С уважением Павел
