//GV4.62HC version modify (2007-5-18)
1. change board SDK, add newest HS card support feature
2. add PDA client download feature, user can access dvr server "http://DVRIP/mobiledvr" to download mobile client directly.
3. modify image display way to support more video card like older version.
//GV4.61HC version modify (2007-4-30)
1. Add 6004HC (4 ch ip server) support feature in dvr server.
2. add PDA support feature, user can get mobile phone client from our website or sales. at present, only support 3 frame/sec.
3. modify serval new bug in v4.60.
//GV4.60HC version modify (2007-4-24)
1. Add IP Server(or IP Camera) support feature in DVR Server, User can build a hybrid DVR that will accept both
analog video input through DVR cards and IP camera/video server digital input through an Ethernet port, and
our MD Series board can decode IP camera/video server image , output its image with dvr board image altoghter
to TV monitor.
2. Add setup parameter export and import feature. user can export /import all setup parameter, include PTZ setup.
3. add Screen Keyboard feature in DVR Server, Double click any Edit frame to open Screen keyboard to input text info.
4. Add alarm device, user can parallel connect two 7616 alarm device via rs485 to build one 7632 device with
32 DI 32 DO, but need setup different address to two 7616;
5. Modify PTZ preset control mode compeletely in dvr server and client. so user must upgrade server and client at the same time
to avoid version compatibility issue between different version.
6. Modify user right setup mode, and PTZ right control way. detach local user right manage and network right manage, more flexible now.
7. Modify OSD position setup way, it will be more flexible to adjust OSD position.
8. Modify Grab image save mode, after install software, when grab image first time, user can select save folder by self.
Это Юлия, я еще раз вернулась!!!
Сейчас у нас новый продукт!!
