Приветствую коллеги!
С 3его января начались проблемы с массовым отключением ONU на одной из веток на Головной Станции(далее ГС).
Несколько ONU с одной ветки начинают отключаться по отсутвствию сигнала и потом снова детектились ГС.
Jan 3 23:02:03 GPON[124]: ONU(4,20) Alarm SD is OFF, ber = 0
Jan 3 23:02:03 GPON[124]: ONU(4,62) Alarm SD is ON, ber = 5
Jan 3 23:02:03 GPON[124]: OMCI DB Resync ONU(4,91) eqd:230812 rx_power:26574
Jan 3 23:02:03 GPON[124]: OMCI DB Resync ONU(4,80) eqd:230921 rx_power:26574
Jan 3 23:02:04 GPON[124]: ONU(4,62) Alarm LOSi is ON
Jan 3 23:02:04 GPON[124]: gpon_common_func_discovered_serial_number(2958) Different ONU(4,62) Status (3:0)
Jan 3 23:02:04 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 3 23:02:04 GPON[124]: ONU(4,62) DEACTIVATION (Reason: LOFi)
Jan 3 23:02:05 GPON[124]: ONU(4,4) Alarm SD is ON, ber = 22
Jan 3 23:02:05 GPON[124]: ONU(4,4) Alarm SF is ON, ber = 22
Jan 3 23:02:05 GPON[124]: ONU(4,15) Alarm SD is ON, ber = 54
Jan 3 23:02:05 GPON[124]: ONU(4,15) Alarm SF is ON, ber = 54
Jan 3 23:02:05 GPON[124]: ONU(4,71) Alarm SD is ON, ber = 24
Jan 3 23:02:05 GPON[124]: ONU(4,71) Alarm SF is ON, ber = 24
Jan 3 23:02:05 GPON[124]: ONU(4,77) Alarm SD is ON, ber = 14
Jan 3 23:02:05 GPON[124]: ONU(4,77) Alarm SF is ON, ber = 14
Jan 3 23:02:05 GPON[124]: ONU(4,4) DEACTIVATION (Reason: SFi)
Jan 3 23:02:05 GPON[124]: ONU(4,15) DEACTIVATION (Reason: SFi)
Jan 3 23:02:06 GPON[124]: ONU(4,71) DEACTIVATION (Reason: SFi)
Jan 3 23:02:06 GPON[124]: ONU(4,77) DEACTIVATION (Reason: SFi)
Jan 3 23:02:14 GPON[124]: DISCOVERED serial-number DSNW2820E6B0 (olt 4)
Jan 3 23:02:14 GPON[124]: DISCOVERED serial-number DSNWCBD8DE0E (olt 4)
Jan 3 23:02:14 GPON[124]: DISCOVERED serial-number DSNWCBD8E498 (olt 4)
Jan 3 23:02:14 GPON[124]: DISCOVERED serial-number DSNW2820DF50 (olt 4)
Jan 3 23:02:14 GPON[124]: ONU(4,71) ACTIVATION (SN:DSNW2820E6B0)
Jan 3 23:02:14 GPON[124]: ONU(4,71) Alarm SF is OFF, ber = 0
Jan 3 23:02:14 GPON[124]: ONU(4,71) Alarm SD is OFF, ber = 0
Jan 3 23:02:15 GPON[124]: ONU(4,4) ACTIVATION (SN:DSNWCBD8DE0E)
Jan 3 23:02:15 GPON[124]: ONU(4,4) Alarm SF is OFF, ber = 0
Jan 3 23:02:15 GPON[124]: ONU(4,4) Alarm SD is OFF, ber = 0
Jan 3 23:02:15 GPON[124]: ONU(4,15) ACTIVATION (SN:DSNWCBD8E498)
Jan 3 23:02:15 GPON[124]: ONU(4,15) Alarm SF is OFF, ber = 0
Jan 3 23:02:15 GPON[124]: ONU(4,15) Alarm SD is OFF, ber = 0
Jan 3 23:02:15 GPON[124]: ONU(4,77) ACTIVATION (SN:DSNW2820DF50)
Jan 3 23:02:15 GPON[124]: ONU(4,77) Alarm SF is OFF, ber = 0
Jan 3 23:02:15 GPON[124]: ONU(4,77) Alarm SD is OFF, ber = 0
Jan 3 23:02:21 GPON[124]: OMCI DB Resync ONU(4,4) eqd:229611 rx_power:26196
Jan 3 23:02:21 GPON[124]: OMCI DB Resync ONU(4,15) eqd:228261 rx_power:30000
Jan 3 23:02:22 GPON[124]: OMCI DB Resync ONU(4,71) eqd:230975 rx_power:26776
Jan 3 23:02:23 GPON[124]: OMCI DB Resync ONU(4,77) eqd:234319 rx_power:23978
Jan 3 23:02:24 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 3 23:02:24 GPON[124]: ONU(4,62) Alarm LOSi is OFF
Jan 3 23:02:24 GPON[124]: ONU(4,62) ACTIVATION FAIL, reason : ONU alarm when PW authentication (SN:DSNW2820BC88)
Jan 3 23:02:34 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 3 23:02:34 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 3 23:02:34 GPON[124]: ONU(4,62) Alarm SD is OFF, ber = 0
Jan 3 23:02:37 GPON[124]: ONU(4,62) Alarm SD is ON, ber = 3
Jan 3 23:02:51 GPON[124]: ONU(4,62) Alarm SD is OFF, ber = 0
Jan 3 23:02:53 GPON[124]: ONU(4,62) Alarm SD is ON, ber = 4
Jan 3 23:02:53 GPON[124]: ONU(4,62) Alarm SF is ON, ber = 4
Jan 3 23:02:53 GPON[124]: ONU(4,62) DEACTIVATION (Reason: SFi)
Jan 3 23:02:54 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 3 23:02:54 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 3 23:02:54 GPON[124]: ONU(4,62) Alarm SF is OFF, ber = 0
Jan 3 23:02:54 GPON[124]: ONU(4,62) Alarm SD is OFF, ber = 0
Jan 3 23:03:11 GPON[124]: ONU(4,62) Alarm LOSi is ON
Логически начали искать того кто часто засирает логи, положили глаз на ONU 4,62, постарались всячески заблокировать
Заблокировали что мождно, и порт, и ип, и лицевик, и все равно ГС его старается законектить.
После всех действий ГС вроде успокоилась, ONU перестали отваливаться, но 4,62 так же реконектился.
Но все же проблема возобновилась
Jan 4 06:01:24 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:01:32 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:01:33 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:01:54 IMISH[17541]: show syslog local volatile
Jan 4 06:02:04 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:02:12 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:02:13 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:02:44 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:02:52 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:02:53 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:03:05 IMISH[17541]: show syslog local volatile
Jan 4 06:03:24 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:03:32 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:03:33 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:03:54 IMISH[17541]: show syslog local volatile
Jan 4 06:04:03 IMISH[17541]: show onu active
Jan 4 06:04:04 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:04:12 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:04:13 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:04:44 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:04:52 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:04:53 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:05:24 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:05:32 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:05:33 GPON[124]: ONU(4,62) ACTIVATION FAIL, reason : ONU alarm when PW authentication (SN:DSNW2820BC88)
Jan 4 06:05:33 GPON[124]: ONU(4,62) Alarm LOSi is ON
Jan 4 06:05:33 GPON[124]: ONU(4,59) Alarm SD is ON, ber = 31
Jan 4 06:05:33 GPON[124]: ONU(4,59) Alarm SF is ON, ber = 31
Jan 4 06:05:33 GPON[124]: ONU(4,66) Alarm SD is ON, ber = 21
Jan 4 06:05:33 GPON[124]: ONU(4,66) Alarm SF is ON, ber = 21
Jan 4 06:05:33 GPON[124]: ONU(4,72) Alarm SD is ON, ber = 4
Jan 4 06:05:34 GPON[124]: ONU(4,59) DEACTIVATION (Reason: SFi)
Jan 4 06:05:34 GPON[124]: ONU(4,66) DEACTIVATION (Reason: SFi)
Jan 4 06:05:39 GPON[124]: ONU(4,72) Alarm SD is OFF, ber = 0
Jan 4 06:05:42 GPON[124]: DISCOVERED serial-number DSNW2820B860 (olt 4)
Jan 4 06:05:42 GPON[124]: DISCOVERED serial-number DSNW2820BC90 (olt 4)
Jan 4 06:05:43 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:05:43 GPON[124]: ONU(4,59) ACTIVATION (SN:DSNW2820B860)
Jan 4 06:05:43 GPON[124]: ONU(4,59) Alarm SF is OFF, ber = 0
Jan 4 06:05:43 GPON[124]: ONU(4,59) Alarm SD is OFF, ber = 0
Jan 4 06:05:43 GPON[124]: ONU(4,66) ACTIVATION (SN:DSNW2820BC90)
Jan 4 06:05:43 GPON[124]: ONU(4,66) Alarm SF is OFF, ber = 0
Jan 4 06:05:43 GPON[124]: ONU(4,66) Alarm SD is OFF, ber = 0
Jan 4 06:05:44 GPON[124]: ONU(4,62) Alarm LOSi is OFF
Jan 4 06:05:44 GPON[124]: ONU(4,62) ACTIVATION (SN:DSNW2820BC88)
Jan 4 06:05:51 GPON[124]: OMCI DB Resync ONU(4,59) eqd:232907 rx_power:26776
Jan 4 06:05:52 GPON[124]: OMCI DB Resync ONU(4,66) eqd:228637 rx_power:26018
Jan 4 06:06:01 IMISH[17541]: sh run
Jan 4 06:06:16 GPON[124]: ONU(4,62) DEACTIVATION (Reason: Admin control(OMCC problem))
Jan 4 06:06:22 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:06:23 GPON[124]: ONU(4,62) ACTIVATION FAIL, reason : ONU alarm when PW authentication (SN:DSNW2820BC88)
Jan 4 06:06:23 GPON[124]: ONU(4,62) Alarm LOSi is ON
Jan 4 06:06:32 GPON[124]: DISCOVERED serial-number DSNW2820BC88 (olt 4)
Jan 4 06:06:33 GPON[124]: ONU(4,62) Alarm LOSi is OFF
В чем может быть проблема, как ее решить?
P.S. На ГС 460 абонентов(ONU), ГС не не ребутали.
