Публикации
10
Зарегистрирован
4 сентября, 2023
Посещение
6 часов назад
Не работает. Пинг не проходит
Switch#show run int ep0/3:1
Building configuration...
Current configuration:
interface EPON0/3:1
description test
epon onu description test
epon onu port 1 ctc vlan mode tag 100 priority 0
Настройки ONU epon0/3:1 после команды "epon onu port 1 ctc vlan mode tag 100 priority 0"остаются без изменений (режим Transparent). Не работает канал. Два компьютера между собой не пингуются.
Switch_config#show configuration
!version 10.1.0F build 121083
service timestamps log date
service timestamps debug date
logging buffered 4096
port-protected 1
ip default-gateway 192.168.20.254
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 0 admin
epon oam-version 1 0x30
epon oam-version 2 0x21
epon oam-version 3 0x20
!!slot 0 89 unknow CARD
interface GigaEthernet0/1
description UpLink
switchport trunk vlan-untagged 1
switchport mode dot1q-tunnel-uplink
interface GigaEthernet0/2
interface GigaEthernet0/3
interface GigaEthernet0/4
interface GigaEthernet0/5
switchport trunk vlan-allowed 100
switchport trunk vlan-untagged none
switchport mode access
switchport pvid 100
interface GigaEthernet0/6
interface EPON0/1
epon bind-onu mac f8f0.8211.f243 2
switchport protected 1
interface EPON0/2
description gpon
epon bind-onu mac f8f0.8211.f23b 1
epon bind-onu mac f8f0.8211.f229 2
epon bind-onu mac f8f0.8211.f253 3
epon bind-onu mac f8f0.8262.afee 4
epon bind-onu mac f8f0.8211.f24b 5
epon bind-onu mac f8f0.8211.f22d 6
epon bind-onu mac f8f0.8211.f223 7
filter bpdu
filter dhcp
switchport rate-limit 16000 ingress
switchport rate-limit 16000 egress
interface EPON0/3
epon bind-onu mac f8f0.8262.afe6 1
interface EPON0/4
!!slot end
interface VLAN1
ip address 192.168.20.253 255.255.255.0
vlan 1,100
ip http server
time-zone tz 3 0
!Pending configurations for absent linecards:
!No configurations pending global
Доброго всем времени! Как организовать канал между двумя компьютерами? Первый подключен к порту g0/5 , второй к ONU epon0/3:1 . На данный момент есть только дефолтовый vlan1
Нужно настроить bdcom P3310D с SNR-onu-epon-1g-mini технологи EPON.
Только безналичный расчет.
Пишите в личку.
25 камер iptronic подключены к 32-х канальному регистратору RVI всё работает. Четыре камеры также были подключены к 4-х канальному регистратору RVI , но показывали только три канала. Купил данный регистратор, а он подключает камеру только если пароль admin . Иначе ругается на неправильный пароль. Но как только камера в online, то регистратор становится недоступен через браузер (хотя пинг до него идет) и монитор пишет что нет сигнала. Совпадений адресов нет.
Не могу подключить камеры Iptronic. Как только добавляю камеру, сразу пропадает сигнал на видео-выходе и в браузере регистратор сразу становится не доступным.
Кто-то сталкивался с подобной проблемой ?
Через консоль команды проходят, но ноут не получает адрес. А если через WEB смотреть, то gi0/1 имеет два режима Access и Trunk
У интерфейса ep0 есть режим dot1q-tunnel-uplink , но и перевод в него ничего не дал
Не удается организовать отдельный канал G1->PON2->ONU1 . Весь трафик приходящий на G1 должен по VLAN2 через PON2 уходить на конкретную ONU1.
На G1 приходит трафик с сети 172.16.1.0/24 . Комп. после ONU1 должен получить адрес в этой сети по DHCP.
snr onu epon 1g mini
Switch#show configuration
!version 10.1.0F build 79597
port-protected 1
description UPLINK
switchport mode trunk
interface EPON0/1
epon bind-onu mac f8f0.8211.f243 1
epon bind-onu mac f8f0.8262.afe6 2
interface EPON0/2
epon bind-onu mac f8f0.8211.f253 1
epon bind-onu mac f8f0.8211.f23b 3
interface EPON0/3
interface EPON0/4
!!slot end
interface VLAN1
vlan 1
ip http server
