добавил экспорт компакт
export compact
# feb/28/2023 20:14:24 by RouterOS 6.40.4
# software id = A3F5-WDHP
# model = RouterBOARD 941-2nD
# serial number = ***
/interface bridge
add admin-mac=D4:CA:6D:89:CA:46 arp=proxy-arp auto-mac=no fast-forward=no name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=russia disabled=no \
distance=indoors frequency=2422 mode=ap-bridge ssid="Ololowku Freedom" wireless-protocol=802.11
/interface ethernet
set [ find default-name=ether1 ] mac-address=00:0C:43:30:52:D1 name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
/interface l2tp-client
add add-default-route=yes allow=chap connect-to=l2tp.freedom default-route-distance=1 disabled=no \
keepalive-timeout=disabled max-mru=1456 max-mtu=1456 name=l2tp-freedom password=*** user=***
/interface pptp-client
add connect-to=pl226.vpnbook.com disabled=no name=vpn password=*** user=***
/ip neighbor discovery
set ether1-gateway discover=no
/interface wireless security-profiles
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=\
MikroTik wpa-pre-shared-key=*** wpa2-pre-shared-key=***
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/ip pool
add name=dhcp ranges=192.168.3.10-192.168.3.254
/ip dhcp-server
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local name=default
/interface bridge port
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/interface wireless access-list
add interface=wlan1 mac-address=*** vlan-mode=no-tag
/interface wireless connect-list
add interface=wlan1 mac-address=*** security-profile=default
/ip address
add address=192.168.3.1/24 comment="default configuration" interface=ether2-master-local network=192.168.3.0
/ip dhcp-client
add comment="default configuration" default-route-distance=2 dhcp-options=hostname,clientid disabled=no \
interface=ether1-gateway
/ip dhcp-server network
add address=192.168.3.0/24 comment="default configuration" gateway=192.168.3.1 netmask=24
/ip dns
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.3.1 name=router
/ip firewall address-list
add address=178.63.151.224 list=vpn
add address=93.184.219.82 list=vpn
add address=93.174.89.3 list=vpn
add address=195.82.146.214 list=vpn
add address=176.114.3.91 list=vpn
add address=31.192.120.36 list=vpn
add address=185.36.100.195 list=vpn
add address=104.28.6.212 list=vpn
add address=176.114.0.132 list=vpn
add address=81.17.30.22 list=vpn
add address=185.25.48.155 list=vpn
add address=31.192.120.44 list=vpn
add address=88.208.29.24 list=vpn
add address=37.1.207.109 list=vpn
add address=46.148.17.244 list=vpn
add address=50.6.0.2 list=vpn
add address=67.22.32.168 list=vpn
add address=vator.org list=vpn
add address=www.new-rutor.info list=vpn
add address=proxy-rutor.org list=vpn
add address=sopcast.com list=vpn
add address=4pda.ru list=vpn
add address=gulagu.net list=vpn
add address=www.vpnbook.com list=vpn
add address=rutracker.org list=vpn
add address=kinoflux.org list=vpn
add address=bridges.torproject.org list=vpn
add address=www.torproject.org list=vpn
add address=dist.torproject.org list=vpn
add address=Twitter.com list=vpn
add address=mobile.twitter.com list=vpn
add address=twitterinc.com list=vpn
add address=facebook.com list=vpn
add address=m.facebook.com list=vpn
add address=instagram.com list=vpn
add address=31.13.71.174 list=vpn
add address=nnm-club.me list=vpn
add address=riseup.net list=vpn
add address=www.pimpletv.ru list=vpn
add address=2ip.ru list=vpn
add address=speedtest.net list=vpn
add address=livetv.sx list=vpn
/ip firewall filter
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established,related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=\
established,related
add action=accept chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=input protocol=udp
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=\
new in-interface=ether1-gateway
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=vpn in-interface=bridge-local new-routing-mark=vpn \
passthrough=no
/ip firewall nat
add action=masquerade chain=srcnat out-interface=vpn src-address=192.168.3.0/24
add action=masquerade chain=srcnat src-address=192.168.3.0/24
add action=masquerade chain=srcnat comment="default configuration" disabled=yes out-interface=ether1-gateway
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=3389 protocol=tcp to-addresses=\
192.168.3.38 to-ports=3389
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=137 log-prefix=192.168.3.38 protocol=tcp \
to-ports=137
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=139 protocol=tcp to-addresses=192.168.3.38 \
to-ports=139
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=443 protocol=tcp to-addresses=192.168.3.38 \
to-ports=443
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=80 protocol=tcp to-addresses=192.168.3.38 \
to-ports=80
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=1434 protocol=tcp to-addresses=\
192.168.3.38 to-ports=1434
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=1433 protocol=tcp to-addresses=\
192.168.3.38 to-ports=1433
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=1812 protocol=udp to-addresses=\
192.168.3.38 to-ports=1812
add action=dst-nat chain=dstnat dst-address=46.72.238.149 dst-port=1813 protocol=udp to-addresses=\
192.168.3.38 to-ports=1813
/ip route
add distance=1 gateway=vpn routing-mark=vpn
add distance=1 dst-address=192.168.0.0/24 gateway=192.168.0.1
/ip route rule
add action=lookup-only-in-table routing-mark=vpn table=vpn
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set winbox address=192.168.3.0/24,217.25.239.152/32
set api-ssl disabled=yes
/ppp secret
add local-address=192.168.3.1 name=test password=*** remote-address=192.168.3.100 service=pptp
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Moscow
/system package update
set channel=bugfix
/tool graphing
set store-every=hour
/tool graphing interface
add allow-address=192.168.3.0/24 store-on-disk=no
add allow-address=217.25.239.152/32 store-on-disk=no
/tool graphing resource
/tool mac-server
set [ find default=yes ] disabled=yes
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
/tool romon port
add
