Posts
4 -
Joined
Last visited
About Nets_admins
Rank
Абитуриент
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
Добрый день, задача настроить Tp-link DS-P7001-08 для работы onu в 500 влане. Влан 500- услуги. Влан 700 - управление. В порт interface gpon 1/0/2 подключена бриджовая onu в неё подключен ПК. DS-P7001-08_6290F6#show running-config running-config DS-P7001-08_6290F6#show running-config !DS-P7001-08 # vlan 500 name "500" # vlan 700 name "700" # serial_port baud_rate 38400 # # system-time ntp UTC 133.100.9.2 139.78.100.163 12 no system-time dst # # # no service reset-disable # # # # ip route 0.0.0.0 0.0.0.0 10.10.10.1 # # # # dba-profile profile-id 0 profile-name default type4 max 102400 ont-srvprofile gpon profile-id 0 profile-name default mac-learning native-vlan unconcern multicast-mode unconcern multicast-forward unconcern ont-port eth adaptive 4 port priority-policy eth 1 unconcern port igmp-forward eth 1 unconcern port q-in-q eth 1 unconcern port eth 1 max-mac-count unlimited port priority-policy eth 2 unconcern port igmp-forward eth 2 unconcern port q-in-q eth 2 unconcern port eth 2 max-mac-count unlimited port priority-policy eth 3 unconcern port igmp-forward eth 3 unconcern port q-in-q eth 3 unconcern port eth 3 max-mac-count unlimited port priority-policy eth 4 unconcern port igmp-forward eth 4 unconcern port q-in-q eth 4 unconcern port eth 4 max-mac-count unlimited ont-port pots adaptive 2 # ont-srvprofile gpon profile-id 10 profile-name srv_profile_10 mac-learning native-vlan unconcern multicast-mode unconcern multicast-forward unconcern ont-port eth adaptive 1 port priority-policy eth 1 unconcern port igmp-forward eth 1 unconcern port q-in-q eth 1 unconcern port eth 1 max-mac-count unlimited ont-port pots adaptive 2 # ont-lineprofile gpon profile-id 0 profile-name default no fec-upstream mapping-mode vlan omcc encrypt tcont 1 dba-profile-id 0 gem add 1 tcont 1 encrypt enable gem mapping 1 1 vlan-untag # ont-lineprofile gpon profile-id 10 profile-name line_profile_10 no fec-upstream mapping-mode vlan no omcc encrypt tcont 1 dba-profile-id 0 gem add 11 tcont 1 encrypt disable gem mapping 11 1 vlan 500 # # service-port 3 config gpon 1/0/1 ont 1 gem-id 1 svlan 500 user-vlan 500 tag-action transparent interface gpon 1/0/1 ont auto-auth authmode sn-auth ont add 1 sn-auth HWTC-82101753 ont-lineprofile-id 10 ont-srvprofile-id 0 ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 ont port attribute 1 eth 1 admin-status enable ont port native-vlan 1 eth 1 vlan 500 prival 0 # interface gpon 1/0/2 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface gpon 1/0/3 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface gpon 1/0/4 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface gpon 1/0/5 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface gpon 1/0/6 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface gpon 1/0/7 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface gpon 1/0/8 ont auto-auth authmode sn-auth ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0 # interface management 1 ip address 192.168.1.1 255.255.255.0 ipv6 enable # interface vlan 1 ip address 192.168.0.1 255.255.255.0 ipv6 enable dpms interface-id 1 # interface vlan 700 ip address 10.10.10.5 255.255.252.0 no ipv6 enable # interface ten-gigabitEthernet 1/0/1 duplex full # interface ten-gigabitEthernet 1/0/2 duplex full # interface gigabitEthernet 1/0/3 switchport general allowed vlan 500,700 tagged # end При такой конфигурации mac адреса пк включенного в onu в выводе show mac address-table vlan 500 не вижу. Просьба помочь с конфигурацией/указать на ошибки/показать примеры конфига.
Проблема: После активации sfp onu, связь с коммутатором в который подключена sfp onu появляется на 4-6 секунд, после чего связь пропадает и коммутатор не пингуется, при этом: ошибок в логах нет, линки не пропадает, mac адрес свитча на olt виден. Если на olt почистить таблицу коммутации, то пинг появляется, пропускает 10-20 пакетов и снова отваливается. Дублей mac адресов/ip нет. ПО обновляли. Если свитч запустить в обход olt проблемы нет. SFP ONU подключена в порт GPON 0/2 Vlan 3000 - влан управления, в нём находится и olt и свитч. Конфиг: Current configuration: ! !version 10.3.0D build 99242 service timestamps log date service timestamps debug date service password-encryption logging buffered 100000 ! port-protected 1 ! ! ! ! lldp run ! ! ! spanning-tree mode rstp ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! aaa authentication login default local aaa authentication enable default none aaa authorization exec default local ! ! ! ! ! ! gpon profile onu-rate-limit ratelimit-default id 1 gpon-profile pir 1244160 cir 1244160 ! gpon profile onu-tcont tcont-default id 1 gpon-profile tcont-type 3 pir 1024000 cir 512 ! gpon profile onu-virtual-port virtual-port-default id 1 gpon-profile encryption disable gpon-profile upstream queue 8 gpon-profile downstream queue 8 ! gpon profile onu-tcont-virtual-port-bind tvbind-default id 1 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default ! gpon profile onu-flow-mapping flow-mapping-default id 1 gpon-profile entry 1 uni type eth-uni all gpon-profile entry 1 virtual-port 1 ! gpon profile onu-flow-mapping flow-mapping-default-hgu id 2 gpon-profile entry 1 uni type veip all gpon-profile entry 1 virtual-port 1 ! gpon profile onu-flow-mapping vlan3000 id 3 gpon-profile entry 1 uni type eth-uni all gpon-profile entry 1 vlan 3000 gpon-profile entry 1 virtual-port 1 ! gpon profile onu-vlan vlan3000 id 3 gpon-profile vlan mode trunk gpon-profile vlan pvid 3000 0 gpon-profile vlan trunk vlan-allowed 3000 ! ! gpon onutype-template onutype-default-hgu gpon-onutype match ctc-onu-type HGU gpon-onutype config tcont-virtual-port-bind-profile tvbind-default gpon-onutype config flow-mapping-profile flow-mapping-default-hgu ! gpon onutype-template onutype-default gpon-onutype config tcont-virtual-port-bind-profile tvbind-default gpon-onutype config flow-mapping-profile flow-mapping-default ! gpon onu-config-template vlan3000 cmd-sequence 001 gpon onu tcont-virtual-port-bind-profile tvbind-default cmd-sequence 002 gpon onu flow-mapping-profile vlan3000 cmd-sequence 003 gpon onu uni 1 vlan-profile vlan3000 ! ! interface Null0 ! interface GigaEthernet0/0 no ip address ! !!slot 0 1 GP3600-08B mother card interface GigaEthernet0/1 description UPLINK switchport trunk vlan-allowed 1676,3000 switchport trunk vlan-untagged none switchport mode dot1q-tunnel-uplink dhcp snooping trust storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/2 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/3 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/4 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/5 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/6 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/7 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GigaEthernet0/8 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface TGigaEthernet0/1 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface TGigaEthernet0/2 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface TGigaEthernet0/3 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface TGigaEthernet0/4 switchport mode dot1q-tunnel-uplink storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GPON0/1 description users gpon pre-config-template vlan3000 bind-onuid 1-128 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 gpon bind-onu sn GPON:12180418 1 filter dhcp switchport trunk vlan-allowed 3000 switchport trunk vlan-untagged none switchport mode trunk switchport protected 1 storm-control broadcast threshold 1000 storm-control multicast threshold 1000 storm-control unicast threshold 5 ! interface GPON0/1:1 gpon onu model-id IGD gpon onu tcont-virtual-port-bind-profile tvbind-default gpon onu flow-mapping-profile vlan3000 gpon onu virtual-port 1 gem-port 256 gpon onu tcont 1 alloc-id 256 gpon onu uni 1 vlan-profile vlan3000 ! interface GPON0/2 description users gpon pre-config-template vlan3000 bind-onuid 1-128 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 gpon bind-onu sn GPON:12180399 1 filter dhcp switchport trunk vlan-allowed 3000 switchport trunk vlan-untagged none switchport mode trunk switchport protected 1 storm-control broadcast threshold 1000 storm-control multicast threshold 1000 storm-control unicast threshold 5 ! interface GPON0/2:1 gpon onu model-id IGD gpon onu tcont-virtual-port-bind-profile tvbind-default gpon onu flow-mapping-profile vlan3000 gpon onu virtual-port 1 gem-port 256 gpon onu tcont 1 alloc-id 256 gpon onu uni 1 vlan-profile vlan3000 ! interface GPON0/3 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GPON0/4 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GPON0/5 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GPON0/6 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GPON0/7 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! interface GPON0/8 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ! !!slot end ! interface VLAN3000 description management ip address 10.10.10.205 255.255.252.0 no ip directed-broadcast ! ! ! vlan 1676 name 1676 ! vlan 3000 name 3000 ! vlan 1,1676,3000 ! ! ! ! ! ! ! ! ! ! ! ! ip route default 10.10.10.1 ip exf ! ipv6 exf ! ip telnet attack-defense ! ip http server ! ! snmp-server community 0 bdcloud RW ! ! ! ! !Pending configurations for absent linecards: ! !No configurations pending global
Nets_admins changed their profile photo
Acl SNR-S2985G-24T-UPS
Nets_admins posted a topic in Коммутаторы SNR, коммутаторы Orion Networks
Прошу помочь в разборе настройк
