Новые блоки питания (новые) - в наличии есть 2 штуки. (3000 р. за шт.)
Одинцово.
AC/DC Power Supply Single-OUT 54V 22.2A/50.5A/53.4A 1200W/2725W
Manufacturer Part #: CP2725AC54Z
Alternate Part #: CP2725AC54Z
Compact 1-RU form factor providing 30 W/in3
Constant power from 52 – 58 Vdc
2725W from nominal 200 – 240 Vac
1200W from nominal 100 – 120 Vac
Output voltage programmable from 44V – 58 Vdc; output defaulted to 54V
PMBus compliant dual I2C and RS485 serial bus communications
Power factor correction (meets EN/IEC 61000-3-2 and EN 60555-2 requirements)
DC Output over-voltage and over-current protection
AC Input over-voltage and under-voltage protection
Over-temperature warning and protection
Redundant, parallel operation with active load sharing and redundant +5V Aux power
Remote ON/OFF
Hot insertion/removal (hot plug)
Four front panel LED indicators
UL Recognized to UL60950-1, CAN/ CSA† C22.2 No. 60950-1, and VDE‡ 0805-1 Licensed to IEC60950-1
CE mark meets 2006/95/EC directive§
Internally controlled Variable-speed fan
