Есть 2 модуля которые стоят в Catalyst 6509-E
1. WS-SVC-ADM-1-K9
2. WS-SVC-AGM-1-K9
Первый из них грузится с незначительной ошибкой и при этом стартует.
Второй грузится с какой то серьезной ошибкой диагностики и после нескольких попыток уходит в shutdown
Гугл ничего не дает. Посдскажите кто знает, что это может быть и есть ли шанс починить ?
1 модуль
00:03:41: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
00:03:46: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 4: TestPCLoopback failed on port(s) 1
00:03:47: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
2 модуль
00:09:23: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
00:09:48: %HA_EM-6-LOG: Mandatory.go_bootup.tcl: GOLD EEM TCL policy for boot up diagnostic
00:09:48: %DIAG-SP-3-MAJOR: Module 3: Online Diagnostics detected a Major Error. Please use 'show diagnostic result <target>' to see test results.
00:09:48: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 3: TestPortASICLoopback failed on port(s) 1-3
00:09:48: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 3: TestPCLoopback failed on port(s) 1-3
00:09:48: %OIR-SP-3-LC_FAILURE: Module 3 has Major online diagnostic failure, Card will be powered down. Please check bootflash diaginfo file for detailed diagnostic result.
00:09:48: SP: The PC in slot 3 is shutting down. Please wait ...
00:10:02: SP: PC shutdown completed for module 3
Данные коммутатора
gw#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI14, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2014 by Cisco Systems, Inc.
Compiled Thu 04-Sep-14 00:37 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
gw uptime is 53 minutes
Uptime for this control processor is 53 minutes
Time since gw switched to active is 52 minutes
System returned to ROM by reload at 00:51:11 UTC Tue Jul 25 2000 (SP by reload)
System image file is "disk0:s72033-adventerprisek9_wan-mz.122-33.SXI14.bin"
Last reload reason: Reload Command
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMG1116N0KA
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
2 Virtual Ethernet interfaces
62 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
gw#show module
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1052BYXS
3 3 Anomaly Guard Module WS-SVC-AGM-1-K9 SAD121301T8
4 3 Anomaly Detector Module WS-SVC-ADM-1-K9 SAD120101XM
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAL1411CQTD
8 6 Firewall Module WS-SVC-FWM-1 SAD084302UU
Mod MAC addresses Hw Fw Sw Status
1 001a.6cbe.60e0 to 001a.6cbe.610f 2.5 12.2(18r)S1 12.2(33)SXI1 Ok
3 001f.6c89.1a30 to 001f.6c89.1a37 3.3 7.2(1) 6.1(5) PwrDown
4 001e.beaf.df38 to 001e.beaf.df3f 3.3 7.2(1) 6.1(5) Ok
5 001f.6c77.ca78 to 001f.6c77.ca7b 4.1 8.5(4) 12.2(33)SXI1 Ok
8 0003.e471.6e32 to 0003.e471.6e39 3.0 7.2(1) 2.3(3) Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1103EABA 2.1 Ok
5 Policy Feature Card 3 WS-F6K-PFC3A SAL1411CQW3 2.8 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD083406PJ 2.8 Ok
Mod Online Diag Status
1 Pass
3 Not Applicable
4 Minor Error
5 Pass
8 Pass
gw#
gw#sh mod 3
3 Not Applicable
gw#sh mod 4
4 Minor Error
gw#show diagnostic result module 4
Current bootup diagnostic level: minimal
Module 4: Anomaly Detector Module SerialNo : SAD120101XM
Overall Diagnostic Result for Module 4 : MINOR ERROR
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
1) TestPortASICLoopback:
Port 1 2 3
2) TestPCLoopback:
Port 1 2 3
F . .
3) TestNetflowInlineRewrite:
Port 1 2 3
U U U
4) TestSynchedFabChannel -----------> .
5) TestEobcStressPing --------------> U
6) TestFirmwareDiagStatus ----------> .
7) TestAsicSync --------------------> .
8) TestErrorCounterMonitor ---------> U
9) TestLtlFpoeMemoryConsistency ----> .
gw#show diagnostic result module 3
Module 3: Anomaly Guard Module SerialNo : SAD121301T8
Overall Diagnostic Result for Module 3 : UNTESTED
Port 1 2 3
F F F
2) TestPCLoopback:
Port 1 2 3
F F F
Port 1 2 3
U U U
4) TestSynchedFabChannel -----------> U
6) TestFirmwareDiagStatus ----------> U
7) TestAsicSync --------------------> U
9) TestLtlFpoeMemoryConsistency ----> U
