Подключаюсь консолью к Cisco 7206VXR через HyperTerminal.
Параметры подключения:
9600 baud rate
No parity
8 data bits
1 stop bit
No flow control
В инструкции написано, что нажимать Break, CTRL+Break... Нажимал по всякому, и в начале, и после 60 секунд, и когда декомпрессия образа, ничего не помогает. Может кто-нибудь сталкивался с подобной проблемой, подскажите как решилась проблема. Спасибо.
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000025
C7200 platform with 1046528 Kbytes of main memory
Readonly ROMMON initialized
Self decompressing the image : #################################################
[OK]
% Unknown command 'route-map'
% Unknown command 'router'
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
###### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(24)T3
, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 13:16 by prod_rel_team
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Installed image archive
Cisco 7206VXR (NPE-G2) processor (revision A) with 524288K/262144K bytes of memo
ry.
Processor board ID 32605583
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.1
6 slot VXR midplane, Version 2.9
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Press RETURN to get started!
*Sep 2 23:26:39.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0
, changed state to up
*Sep 2 23:26:39.815: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed stat
e to down
*Sep 2 23:26:39.815: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed stat
e to down
*Sep 2 23:26:39.815: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed stat
e to down
*Sep 2 23:26:39.815: %LINK-3-UPDOWN: Interface FastEthernet0/2, changed state t
o down
*Sep 2 23:26:40.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0/1, changed state to down
ernet0/2, changed state to down
ernet0/3, changed state to down
*Sep 2 23:26:40.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Sep 2 23:26:42.291: %SYS-5-CONFIG_I: Configured from memory by console
*Sep 2 23:26:42.647: %SYS-5-RESTART: System restarted --
*Sep 2 23:26:42.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel666,
*Sep 2 23:26:42.879: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Sep 2 23:26:42.879: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Sep 2 23:26:42.879: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Sep 2 23:26:43.479: %SNMP-5-COLDSTART: SNMP agent on host R7206 is undergoing
a cold start
*Sep 2 23:26:44.051: %LINK-5-CHANGED: Interface FastEthernet0/2, changed state
to administratively down
