spellex
Новичок
  • Публикации
  • Зарегистрирован
  • Посещение
О spellex
  • Звание
    Абитуриент
    Абитуриент
Посетители профиля
  1. ставлю noc на FreeBSD 10.0-RELEAS при выполнении скрипта /opt/noc/scripts/upgrade вываливается с ошибкой Installing collected packages: gmpy, pycrypto, python-cjson, netifaces, Django, South, coverage, protobuf, pyasn1, pyasn1-modules, pysnmp, python-creole, docutils, Pygments, mongoengine, tornado, sleekxmpp, noc-pkg-handlebars, noc-pkg-shjs, noc-pkg-famfamfam-silk, noc-pkg-silk-companion1, noc-pkg-extjs, noc-pkg-mxgraph, noc-pkg-openlayers, noc-pkg-cubism, noc-pkg-d3, noc-pkg-font-awesome Running setup.py install for gmpy building 'gmpy' extension cc -fno-strict-aliasing -O2 -pipe -fno-strict-aliasing -DNDEBUG -fPIC -I./src -I/usr/local/include/python2.7 -c src/gmpy.c -o build/temp.freebsd-10.0-RELEASE-amd64-2.7/src/gmpy.o In file included from src/gmpy.c:248: ./src/gmpy.h:30:10: fatal error: 'gmp.h' file not found #include "gmp.h" ^ 1 error generated. error: command 'cc' failed with exit status 1 Complete output from command /opt/noc/bin/python2.7 -c "import setuptools, tokenize;__file__='/opt/noc/build/gmpy/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-mcylTU-record/install-record.txt --single-version-externally-managed --compile --install-headers /opt/noc/include/site/python2.7: running install running build running build_ext building 'gmpy' extension creating build creating build/temp.freebsd-10.0-RELEASE-amd64-2.7 creating build/temp.freebsd-10.0-RELEASE-amd64-2.7/src cc -fno-strict-aliasing -O2 -pipe -fno-strict-aliasing -DNDEBUG -fPIC -I./src -I/usr/local/include/python2.7 -c src/gmpy.c -o build/temp.freebsd-10.0-RELEASE-amd64-2.7/src/gmpy.o In file included from src/gmpy.c:248: ./src/gmpy.h:30:10: fatal error: 'gmp.h' file not found #include "gmp.h" ^ 1 error generated. error: command 'cc' failed with exit status 1 ---------------------------------------- Cleaning up... Command /opt/noc/bin/python2.7 -c "import setuptools, tokenize;__file__='/opt/noc/build/gmpy/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-mcylTU-record/install-record.txt --single-version-externally-managed --compile --install-headers /opt/noc/include/site/python2.7 failed with error code 1 in /opt/noc/build/gmpy Storing debug log for failure in /root/.pip/pip.log upgrade: 212: Cannot update python libraries Terminating
