не получается последняя команда "ena ipforwarding vlan Default" - нету команды "ipforwarding" в списке доступных
enable
access-list Access list
auto-provision Allow switch to obtain the IP Address, Gateway, Config file via DHCP
bootp Configure BOOTP client
bootprelay Configure BOOTP Relay service
cfm IEEE 802.1ag - Connectivity Fault Management
cli Command Line Interface settings
cli-config-logging CLI command logging
clipaging Display command output one screenful at a time
cpu-monitoring Monitor system/process cpu utilization
dhcp Configure DHCP client
diffserv diffserv
dos-protect automatic denial-of-service protection
dot1p dot1p
eaps EAPS (Ethernet Automatic Protection Switching) domain
edp EDP
elrp-client ELRP (Extreme Loop Recovery Protocol) Client
elsm ELSM (Extreme Link Status Monitoring)
esrp ESRP (Extreme Standby Router Protocol) Domain
flooding flooding
flow-control Pause frame handling
icmp icmp option
identity-management Identity Management
idletimeout Timeout for idling configuration session
igmp IGMP Protocol
ip-fix Enable IPFIX module
ip-option ip option
ip-security IP Security
iparp IP ARP
jumbo-frame jumbo-frame
learning learning
license license or feature pack
lldp Configure LLDP specific settings
log Configure log service
loopback-mode loopback
mac-lockdown-timeout mac lockdown timeout
mirroring mirroring
mlag Multi-switch Link Aggregation used to combine remote ports and local ports to a common logical connection
mld Multicast Listener Discovery Protocol
mvr Multicast VLAN Registration
neighbor-discovery IPv6 neighbor
попробовал:
1) создал доп влан ТЕСТ, дал порты 1-2, - остальные порты у ДЕФолта
получил картину:
* X350-24t.8 # sh vlan
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 172.16.7.120 /16 ------------T------------ ANY 0 /24 VR-Default
Mgmt 4095 10.0.0.4 /8 ------------------------- ANY 0 /1 VR-Mgmt
TEST 10 89.209.254.200 /8 ------------------------- ANY 1 /2 VR-Default
Flags : (B) BFD Enabled, © 802.1ad customer VLAN, © EAPS Control VLAN,
(d) NetLogin Dynamically created VLAN, (D) VLAN Admin Disabled,
(E) ESRP Enabled, (f) IP Forwarding Enabled,
(F) Learning Disabled, (i) ISIS Enabled, (L) Loopback Enabled,
(l) MPLS Enabled, (m) IPmc Forwarding Enabled,
(M) Translation Member VLAN or Subscriber VLAN,
(n) IP Multinetting Enabled, (N) Network Login VLAN, (o) OSPF Enabled,
(O) Flooding Disabled, (p) PIM Enabled, (P) EAPS protected VLAN,
® RIP Enabled, ® Sub-VLAN IP Range Configured,
(s) Sub-VLAN, (S) Super-VLAN, (t) Translation VLAN or Network VLAN,
(T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled,
Total number of VLAN(s) : 3
зайти через сеть не могу, смотрю с порта из сети следующее (при подключении в порт 2 Экстрима):
show interfaces description ethernet e6
Port Description
e6
SW2-1-1# configure
SW2-1-1(config)# interface ethernet e6
SW2-1-1(config-if)# no shutdown
SW2-1-1(config-if)# 01-Nov-2011 01:34:48 %ARPINSP-I-PCKTLOG: ARP packet dropped from port e6 with VLAN tag 1 and reason: packet verification failed
SRC MAC 00:04:96:35:88:87 SRC IP 89.209.254.200 DST MAC 00:23:cd:b0:ba:7d DST IP 89.209.254.50
exit
SW2-1-1(config)# exit
SW2-1-1# show mac address-table ethernet e6
Aging time is 300 sec
Vlan Mac Address Port Type
1 00:04:96:35:88:87 e6 dynamic
1 00:e0:2b:00:00:01 e6 dynamic
SW2-1-1# 01-Nov-2011 01:34:53 %ARPINSP-I-PCKTLOG: ARP packet dropped from port e6 with VLAN tag 1 and reason: packet verification failed
