Не получается установить. Система FreeBSD-9.3-i386
# fetch -o- http://cdn.nocproject.org/bs/FreeBSD-9.2.txt | sh | tee /tmp/NOCinstall.log
src/nad_init.c:85: error: expected declaration specifiers or '...' before 'PAFile'
src/nad_init.c:87: error: conflicting types for 'nad_ctable_load'
/usr/local/include/projects.h:418: error: previous declaration of 'nad_ctable_load' was here
src/nad_init.c: In function 'nad_ctable_load':
src/nad_init.c:90: error: 'fid' undeclared (first use in this function)
src/nad_init.c:90: error: (Each undeclared identifier is reported only once
src/nad_init.c:90: error: for each function it appears in.)
src/nad_init.c: At top level:
src/nad_init.c:116: error: expected declaration specifiers or '...' before 'PAFile'
src/nad_init.c:117: error: conflicting types for 'nad_ctable_init'
/usr/local/include/projects.h:417: error: previous declaration of 'nad_ctable_init' was here
src/nad_init.c: In function 'nad_ctable_init':
src/nad_init.c:124: error: 'fid' undeclared (first use in this function)
src/nad_init.c:158: error: expected declaration specifiers or '...' before 'PAFile'
src/nad_init.c:160: error: conflicting types for 'nad_ctable2_load'
/usr/local/include/projects.h:420: error: previous declaration of 'nad_ctable2_load' was here
src/nad_init.c: In function 'nad_ctable2_load':
src/nad_init.c:163: error: 'fid' undeclared (first use in this function)
src/nad_init.c:198: error: expected declaration specifiers or '...' before 'PAFile'
src/nad_init.c:199: error: conflicting types for 'nad_ctable2_init'
/usr/local/include/projects.h:419: error: previous declaration of 'nad_ctable2_init' was here
src/nad_init.c: In function 'nad_ctable2_init':
src/nad_init.c:204: error: 'fid' undeclared (first use in this function)
src/nad_init.c: In function 'nad_init':
src/nad_init.c:271: error: 'PAFile' undeclared (first use in this function)
src/nad_init.c:271: error: expected ';' before 'fid'
src/nad_init.c:279: error: 'fid' undeclared (first use in this function)
src/nad_init.c:283: error: too many arguments to function 'nad_ctable_init'
src/nad_init.c:286: error: too many arguments to function 'nad_ctable_load'
error: command 'cc' failed with exit status 1
Command "/usr/local/noc/bin/python2.7 -c "import setuptools, tokenize;__file__='/tmp/pip-build-OdpOnL/pyproj/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-gvKvDB-record/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/noc/include/site/python2.7/pyproj" failed with error code 1 in /tmp/pip-build-OdpOnL/pyproj
upgrade: 289: Cannot update python libraries
Terminating
Reporting upgrade status
Traceback (most recent call last):
File "./scripts/cptool", line 15, in <module>
from noc.support.cp import CPClient
ImportError: No module named noc.support.cp
Saving upgrade log to /var/log/noc/upgrade.log
bootstrap.sh: Failed to upgrade NOC
Terminating
