Доброе время суток. Объясните пожалуйста на пальцах как отресетить на заводские настройка Канопи (Model 2450AP).НА веб интерфейс не заходит,кнопки ресет на корпусе нету.
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Canopy Default Plug
When inserted, the default plug brings the module up with a default configuration. This allows the
operator to regain control of a module, which may be using an IP address and/or password that
has been forgotten. The default plug will also override the passwords for access and change
control and set the LAN1 IP address back to 169.254.1.1. This does not, by itself, change any
configuration, rather, it allows the operator to attach to the module using the default configuration
so that they can read the actual non-default values and set them accordingly.
The following steps outline the creation of a default plug (this plug can also be purchase for a
nominal fee at http://www.best-tronics.com/motorola):
• Obtain a RJ-11, 6-pin connector and a small length of CAT 5 cable.
• Pin-out all 6-pins according the following diagram and then short (i.e. solder) together pins
4 and 6 on the other end. Remaining wires should not be connected to anything.
The following diagram shows the wiring of a default plug:
pin 1 → white / orange
pin 2 → white / green
pin 3 → white / blue
pin 4 → green solder to orange
pin 5 → blue
pin 6 → orange solder to green
• Insert “default plug” in the GPS sync port of the module and apply power to the module via
its Ethernet cable.
When the module is booted up (power applied) it will be in default mode where the IP address will
be 169.254.1.1 and the passwords will be blank. All other configurations will have been preserved.
http://www.viterbimexico.com/pdf/Canopy%20SM%20Manual.pdf
Ссылка на сообщение
USH а можно по распиновке по Русски пожалуйсто.
или лучше в картинке :(
Ссылка на сообщение
куда еще проще?
translate.google.com в помощь
Ссылка на сообщение
куда еще проще?
Так делали, уже второй день греется и молчит. ПОМОШЬ!!!!
Ссылка на сообщение
вам нужен разъем RG11 вилка. закорачиваете 4 и 6 пин. после этого эту заглушку подсоединяете в девайсу и подаете питание
Ссылка на сообщение
Так и делали, даже лампочки не моргают!!!!
Ссылка на сообщение
и дальше?она выходит на стандартные настройки поидее?вытаскиваем заглушку перегружаем и все?или как?уже как только не тыкали.может все таки умерла :(
Ссылка на сообщение
вставляете заглушку
подаете питание
девайс загружается по стандартному айпишнику 169.254.1.1
заходите в него и нажимаете сброс до фабричных настроек
перегружаетесь
вытаскиваете заглушку
девайс доступен
Ссылка на сообщение
вставляете заглушку
подаете питание
перегружаетесь
девайс доступен
спасибо,доступно для чайника,все заработало...
Ссылка на сообщение
У меня модель Motorola Canopy AN500A у которой питание идёт 24 вольта. Но полярность не так как в предыдущих моделях. Дело в том что минус (-) это 4 и 5 пины (белосиний/синий) в разъёме RJ45, а плюс (+) это 7 и 8 (белокоричневый/коричневый). Но в моделях где идёт питание 12 вольт, там наоборот, 4 пин попадает не минус (масса), а плюс. Получается что закорачивается 4 пин это минус, с 6 (зелёным) один из тех пар по которым идёт обмен данными. Но если вместо минуса попадёт +24 вольта на зелёный провод, это не есть хорошо... Так вот вопрос, почему не сказано что минус и плюс могут отличаться в разных моделях? И что нужно закорачивать с зелёным проводом, минус или плюс(+)?
P.S. Заглушки нет, блока питания тоже нет, просто досталась одна болванка... ХОЧУ НАСТРОИТЬ САМОСТОЯТЕЛЬНО. ПОМОГИТЕ, ПОЖАЛУЙСТА
Ссылка на сообщение
А не подскажете, как ее запитать через средний штекер, между RJ11 и RJ45?
И во что ее максимум полезное можно перешить? :)
У меня Canopy 2450SM.
Ссылка на сообщение
Доброго времени суток, подскажите пожалуйста, как правильно настроить:
у нас canopy 2450sm и 2450ap, 2 LTV ip-камеры и рабочее место
на какую сторону лучше ставить AP, а на какую SM
сейчас мы добились картинок, которая на разрешении 1280*960 притормаживает не хило, может какие нибудь настройки надо выставить... тест между антенами показывает 14Мб\с(7upload 7 download)пробовал менять приоритет, если на AP2450 увеличить Download(90%) то и на SM Upload становится минимальным 10%.
Изменено пользователем KeeperHome
Ссылка на сообщение
Подписчики 0
