есть коммутатор SNR-S2990G-24FX и sfp модули SNR-SFP-W35-3
все работает как и положено, но информации о sfp нету.
прошивку обновил до последней
SoftWare Version 7.0.3.5(R0102.0104)
BootRom Version 7.1.37
HardWare Version 1.0.1
вот вывод инфы о порте
SW_CORE#sh int e1/0/1
Interface brief:
Ethernet1/0/1 is up, line protocol is up
Ethernet1/0/1 is layer 2 port, alias name is (null), index is 1
Hardware is SFP, address is f8-f0-82-73-4a-93
PVID is 1
MTU 1500 bytes, BW 1000000 Kbit
Time since last status change:1w-5d-18h-14m-22s (1102462 seconds)
Encapsulation ARPA, Loopback not set
Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 1G bits
FlowControl is off, MDI type is auto
Transceiver info:
Statistics:
5 minute input rate 1600423 bits/sec, 257 packets/sec
5 minute output rate 562625 bits/sec, 161 packets/sec
The last 5 second input rate 1622874 bits/sec, 254 packets/sec
The last 5 second output rate 153508 bits/sec, 132 packets/sec
Input packets statistics:
311695334 input packets, 246093038248 bytes, 0 no buffer
263436498 unicast packets, 46355948 multicast packets, 1902888 broadcast packets
0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
0 abort, 0 length error, 0 undersize 0 jabber, 0 fragments, 0 pause frame
Output packets statistics:
237292811 output packets, 184552493719 bytes, 0 underruns
149229545 unicast packets, 63614624 multicast packets, 24448642 broadcast packets
0 output errors, 0 collisions, 0 late collisions, 0 pause frame
Transceiver info - пусто
так же вывод
SW_CORE#sh transceiver interface ethernet 1/0/1
Interface Temp(▒▒) Voltage(V) Bias(mA) RX Power(dBm) TX Power(dBm)
1/0/1 N/A N/A N/A N/A N/A
эти же sfp модули с другой стороны в длинках все показывают
может что то включить нужно?
