saturn
Новичок
  • Публикации
    5
  • Зарегистрирован
  • Посещение
О saturn
  • Звание
    Абитуриент
    Абитуриент
  1. Добрый день, @Kozubsky Vladimir . SNR-S2995G-cc-1#sho ver SNR-S2995G-48TX Device, Compiled on Sep 14 14:39:20 2022 sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia CPU Mac f8:f0:82:7a:29:dc Vlan MAC f8:f0:82:7a:29:db SoftWare Package Version 7.5.3.6(R0004.0473) BootRom Version 7.5.25 HardWare Version 2.0.1 CPLD Version 1.01 Serial No.:SW078320I921000205 Copyright (C) 2022 NAG LLC All rights reserved Last reboot is warm reset. Uptime is 0 weeks, 2 days, 1 hours, 49 minutes SNR-S2995G-cc-1#show slot --------------------member :1-------------------- Inserted : YES Module type : Switch Work mode : ACTIVE MASTER Work state : RUNNING Software package version : 7.5.3.6(R0004.0473) Bootrom version : 7.5.25 CPLD version : 1.01 Hardware version : 2.0.1 Serial number : SW078320I921000205 Manufacture date : 2018/02/05 Temperature : 44C/111F Uptime : 0 weeks, 2 days, 1 hours, 49 minutes --------------------member :2-------------------- Inserted : YES Module type : Switch Work mode : STANDBY MASTER Work state : RUNNING Software package version : 7.5.3.6(R0004.0473) Bootrom version : 7.5.25 CPLD version : 1.01 Hardware version : 2.0.1 Serial number : SW078320JB08000207 Manufacture date : 2019/10/25 Temperature : 44C/111F Uptime : 0 weeks, 2 days, 1 hours, 48 minutes
  2. Прошу помощи с BFD MAD на SNR-S2995G-48TX. Настраиваю согласно https://nag.wiki/pages/viewpage.action?pageId=25107753 Использую 36-е порты на обоих членах VSF. BFD просто не поднимается. Я что-то не донастроил? SNR-S2995G-cc-1#sho run int vl4090 interface Vlan4090 vsf mad bfd enable vsf mad ip address 192.168.1.2 255.255.255.0 member 1 vsf mad ip address 192.168.1.1 255.255.255.0 member 2 SNR-S2995G-cc-1#sho run | i bfd vsf mad bfd enable SNR-S2995G-cc-1#sho vlan id 4090 VLAN Name Type Media Ports ---- ------------ ---------- --------- ---------------------------------------- 4090 BFD Static ENET Ethernet1/0/36 Ethernet2/0/36 SNR-S2995G-cc-1#sho int e s | i /0/36 1/0/36 UP/UP a-1G a-FULL 4090 G-TX BFD 2/0/36 UP/UP a-1G a-FULL 4090 G-TX BFD SNR-S2995G-cc-1#sho ip int br Index Interface IP-Address Protocol 1154 Ethernet0 unassigned down 11005 Vlan5 10.10.5.51 up 15090 Vlan4090 192.168.1.2 up 17500 Loopback 127.0.0.1 up SNR-S2995G-cc-1#sho bfd interface Interface: 15090 Mini trans interval: 400 Mini recv interval: 400 Detect Mult: 5 Mini echo recv interval: 400 Echo Mode: Disable SNR-S2995G-cc-1#sho bfd neighbor OurAddr NeighAddr LD/RD Detec Int(ms) State Vrf Id Interface 0.0.0.0 192.168.1.1 1/0 0 Down 0 Vlan4090 SNR-S2995G-cc-1#sho arp vlan 4090 ARP Unicast Items: 11, Valid: 11, Matched: 1, Verifying: 0, Incomplete: 0, Failed: 0, None: 0 Ethernet Manager Port ARP Items: 0 Address Hardware Addr Interface Port Flag Age-time(sec) subvlanVID 192.168.1.1 f8-f0-82-10-00-06 Vlan4090 Ethernet1/0/36 Static 0 SNR-S2995G-cc-1#show vsf Switch Role Priority CPU-Mac Description ------------------------------------------------------------------- 1 M 11 f8-f0-82-7a-29-dc SNR-S2995G-cc-1 2 SM 2 f8-f0-82-7a-92-76 SNR-S2995G-cc-2 The Bridge Mac of the VSF is: f8-f0-82-7a-29-dc Auto Merge: yes Domain ID: 10 SNR-S2995G-cc-1#sho spanning-tree interface e1/0/36 *********************************** Process 0 *********************************** Ethernet1/0/36: ID State Role DsgBridge DsgPort VlanCount ----------- --- ---- ------------------ ----------- --------- 128.00036 FWD DSGN 4096.f8f0827a29dc 128.00036 1 SNR-S2995G-cc-1#sho spanning-tree interface e2/0/36 *********************************** Process 0 *********************************** Ethernet2/0/36: ID State Role DsgBridge DsgPort VlanCount ----------- --- ---- ------------------ ----------- --------- 128.00100 FWD DSGN 4096.f8f0827a29dc 128.00100 1
  3. Получается, что при использовании не VSF ПО мы получим только стек управления? Или же кросс-коммутация между членами стека будет работать?
  4. Уточните пожалуйста, для поддержки необходимо использование ПО с поддержкой VSF ?
  5. Добрый день. Собираюсь брать несколько SNR-S2990G-24FX для L2-аггрегирования "звёзд". Но не могу найти ответа на ключевой вопрос. Умеет ли данный коммутатор M-LAG. То есть я хочу объединить коммутаторы в стеки по 2 штуки через 10G порты. Затем от каждого коммутатора доступа привести по 2 линка, воткнуть их в РАЗНЫЕ SNR-S2990G-24FX (которых в стеке 2 штуки) и собрать на нём port-channel. Привычная схема для стеков из cisco catalyst или juniper ex. Будет ли работать такая схема на стеке из данных коммутаторов или это просто стек управления?
