Прошу помощи с BFD MAD на SNR-S2995G-48TX.
Настраиваю согласно https://nag.wiki/pages/viewpage.action?pageId=25107753
Использую 36-е порты на обоих членах VSF. BFD просто не поднимается.
Я что-то не донастроил?
SNR-S2995G-cc-1#sho run int vl4090
interface Vlan4090
 vsf mad bfd enable
 vsf mad ip address 192.168.1.2 255.255.255.0 member 1
 vsf mad ip address 192.168.1.1 255.255.255.0 member 2
SNR-S2995G-cc-1#sho run | i bfd
 vsf mad bfd enable
SNR-S2995G-cc-1#sho vlan id 4090
VLAN Name         Type       Media     Ports
4090 BFD          Static     ENET      Ethernet1/0/36      Ethernet2/0/36
SNR-S2995G-cc-1#sho int e s | i /0/36
1/0/36     UP/UP          a-1G    a-FULL  4090   G-TX            BFD
2/0/36     UP/UP          a-1G    a-FULL  4090   G-TX            BFD
SNR-S2995G-cc-1#sho ip int br
Index     Interface             IP-Address      Protocol
1154      Ethernet0             unassigned      down
11005     Vlan5                 10.10.5.51      up
15090     Vlan4090              192.168.1.2     up
17500     Loopback              127.0.0.1       up
SNR-S2995G-cc-1#sho bfd interface
Interface:                    15090
Mini trans interval:          400       Mini recv interval:           400
Detect Mult:                  5         Mini echo recv interval:      400
Echo Mode:                    Disable
SNR-S2995G-cc-1#sho bfd neighbor
OurAddr                                 NeighAddr                               LD/RD               Detec Int(ms)  State   Vrf Id  Interface
0.0.0.0                                 192.168.1.1                             1/0                 0              Down    0       Vlan4090
SNR-S2995G-cc-1#sho arp vlan 4090
ARP Unicast Items: 11, Valid: 11, Matched: 1, Verifying: 0, Incomplete: 0, Failed: 0, None: 0
Ethernet Manager Port ARP Items: 0
Address          Hardware Addr      Interface     Port                  Flag      Age-time(sec)     subvlanVID
192.168.1.1      f8-f0-82-10-00-06  Vlan4090      Ethernet1/0/36        Static                        0
SNR-S2995G-cc-1#show vsf
Switch   Role   Priority   CPU-Mac             Description
1        M      11         f8-f0-82-7a-29-dc   SNR-S2995G-cc-1
2        SM     2          f8-f0-82-7a-92-76   SNR-S2995G-cc-2
The Bridge Mac of the VSF is: f8-f0-82-7a-29-dc
Auto Merge: yes
Domain ID: 10
SNR-S2995G-cc-1#sho spanning-tree interface e1/0/36
*********************************** Process 0 ***********************************
Ethernet1/0/36:
       ID      State Role    DsgBridge          DsgPort VlanCount
   128.00036   FWD  DSGN  4096.f8f0827a29dc   128.00036         1
SNR-S2995G-cc-1#sho spanning-tree interface e2/0/36
Ethernet2/0/36:
   128.00100   FWD  DSGN  4096.f8f0827a29dc   128.00100         1
Edited by saturn
Добрый день, @Kozubsky Vladimir .
SNR-S2995G-cc-1#sho ver
  SNR-S2995G-48TX Device, Compiled on Sep 14 14:39:20 2022
  sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia
  CPU Mac f8:f0:82:7a:29:dc
  Vlan MAC f8:f0:82:7a:29:db
  SoftWare Package Version 7.5.3.6(R0004.0473)
  BootRom Version 7.5.25
  HardWare Version 2.0.1
  CPLD Version 1.01
  Serial No.:SW078320I921000205
  Copyright (C) 2022 NAG LLC
  All rights reserved
  Last reboot is warm reset.
  Uptime is 0 weeks, 2 days, 1 hours, 49 minutes
SNR-S2995G-cc-1#show slot
--------------------member :1--------------------
Inserted                    : YES
Module type                 : Switch
Work mode                   : ACTIVE MASTER
Work state                  : RUNNING
Software package version    : 7.5.3.6(R0004.0473)
Bootrom version             : 7.5.25
CPLD version                : 1.01
Hardware version            : 2.0.1
Serial number               : SW078320I921000205
Manufacture date            : 2018/02/05
Temperature                 : 44C/111F
Uptime                      : 0 weeks, 2 days, 1 hours, 49 minutes
--------------------member :2--------------------
Inserted                    : YES
Work mode                   : STANDBY MASTER
CPLD version                : 1.01
Serial number               : SW078320JB08000207
Manufacture date            : 2019/10/25
Uptime                      : 0 weeks, 2 days, 1 hours, 48 minutes
Здравствуйте.
BFD MAD настроено корректно.
1. При нормальной работе стека BFD в выводе sho bfd neighbor не поднимется. Оно и должно находиться в состоянии down - это нормальная, стандартная работа. BFD сессия должна находиться в состоянии down.
2. Стек у нас работает нормально. Линки на BFD портах светятся и можно заметитить, что они постоянно мигают. member 1, который active master, передает служебные пакеты в сторону member 2.
3. В случае, если происходит пропадание связи на vsf линке, то происходит следующее:
а) поднимается BFD сессия(переходит из DOWN в UP) между двумя коммутаторами для обнаружения MAD
б) member 1 сообщает member 2 выключить все свои порты(чтобы не случилось так, что member 2 остался активен), кроме vsf линка
в) member 2 выключает все свои порты
г) member 1 уничтожает из своего конфига порты member 2 аля "MODULE_PORT/5/:%LINK-3-DESTROY: Interface Ethernet2/0/1, changed state to DESTROYED"
в) т.к. на member 2 и на member 1 BFD порты теперь удалены и выключены, то BFD линк не работает , поэтому он снова переходит в состояние DOWN
4. В случае восстановления линка vsf,  member 2  перезагрузиться и снова станет standbymaster, порты у него будут  апе
