mr.elusive Posted December 25, 2014 Posted December 25, 2014 Господа, кто использует 10g слот на s5328? Суть проблемы - после перехода на 10г линк пошли ошибки Output Discard на гигабитных портах: GigabitEthernet0/0/20 current state : UP Line protocol current state : UP Switch Port, TPID : 8100(Hex), The Maximum Frame Length is 1600 IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 0025-9efc-123c Port Mode: COMMON FIBER Speed : 1000, Loopback: NONE Duplex: FULL, Negotiation: ENABLE Last 300 seconds input rate 66413344 bits/sec, 21808 packets/sec Last 300 seconds output rate 185265056 bits/sec, 19695 packets/sec Input peak rate 1232307080 bits/sec, Record time: 2014-12-24 10:30:32 Output peak rate 1125529224 bits/sec, Record time: 2014-11-29 00:00:54 Input: 107698572869 packets, 35215439666952 bytes Unicast : 107688752195, Multicast : 8341701 Broadcast : 1478972, Jumbo : 0 CRC : 1, Giants : 0 Jabbers : 0, Fragments : 0 Runts : 0, DropEvents : 0 Alignments : 0, Symbols : 0 Ignoreds : 0, Frames : 0 Discard : 0, Total Error : 1 Output: 132738194202 packets, 153601933625083 bytes Unicast : 132736755629, Multicast : 477826 Broadcast : 960734, Jumbo : 13 Collisions : 0, Deferreds : 0 Late Collisions: 0, ExcessiveCollisions: 0 Buffers Purged : 0 Discard : 147683851, Total Error : 0 Input bandwidth utilization threshold : 100.00% Output bandwidth utilization threshold: 100.00% Input bandwidth utilization : 6.64% Output bandwidth utilization : 18.53% На 10г интерфейсе все ок: XGigabitEthernet0/1/1 current state : UP Line protocol current state : UP Switch Port, PVID : 1, TPID : 8100(Hex), The Maximum Frame Length is 1600 IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 0025-9efc-123c Port Mode: COMMON FIBER Speed : 10000, Loopback: NONE Duplex: FULL, Negotiation: DISABLE Last 300 seconds input rate 768828248 bits/sec, 85684 packets/sec Last 300 seconds output rate 253772256 bits/sec, 79600 packets/sec Input peak rate 4124658104 bits/sec, Record time: 2014-12-03 15:33:32 Output peak rate 1924400664 bits/sec, Record time: 2014-12-25 17:35:23 Input: 450085020718 packets, 468712673623269 bytes Unicast : 450018494377, Multicast : 17856848 Broadcast : 46426926, Jumbo : 316 CRC : 1, Giants : 0 Jabbers : 0, Fragments : 0 Runts : 0, DropEvents : 0 Alignments : 0, Symbols : 1 Ignoreds : 0, Frames : 0 Discard : 0, Total Error : 2 Output: 385689989775 packets, 132400250325097 bytes Unicast : 385647710112, Multicast : 13921925 Broadcast : 23421539, Jumbo : 132 Collisions : 0, Deferreds : 0 Late Collisions: 0, ExcessiveCollisions: 0 Buffers Purged : 0 Discard : 0, Total Error : 0 Input bandwidth utilization threshold : 100.00% Output bandwidth utilization threshold: 100.00% Input bandwidth utilization : 7.69% Output bandwidth utilization : 2.54% Подозреваю, что проблема в буфере/очереди передачи на портах. На циске лечилось hold-queue in/out. Как бороться? Вставить ник Quote
Stak Posted December 26, 2014 Posted December 26, 2014 А где ошибки то? В статистике не видно. Вставить ник Quote
Zaqwr Posted December 26, 2014 Posted December 26, 2014 Output Discar .... maybe QoS? Вставить ник Quote
s.lobanov Posted December 27, 2014 Posted December 27, 2014 mr.elusive Это самая стандартная проблема, имеющая название "speed mismatch" (можете почитать здесь ) О том как выкручивать буферы для S5300-HI смотрите здесь На -EI серии вместо length есть аналог max-length Диагностика на S5300-EI: включаем статистику по egress-очередям на порту (для 5328-EI можно только на одном порту): ]qos port statistics enable interface GigabitEthernet0/0/1 >display qos port statistics interface GigabitEthernet0/0/1 - смотрим в каких очередях дропы Если у вас в сети несколько типов трафика, то выстраивайте qos-ы и смотрите чтобы реалтайм не дропался (на huawei это делается довольно прозрачно), советую режим pq, он самый простой и удобных ИМХО. Если у вас только BE-трафик(интернет, локал), то можно немножко поиграться с буферами, но все равно дропы будут, ибо микроберсты очень характеры для инет-трафика. Просто следите за линками. Если будет утилизация в ЧНН на GE-портах больше 70-80% (с усреднением в 5 минут), а прилетает трафик из 10G портов, то планомерно делайте из этих линков eth-trunk'и Вставить ник Quote
