Коллеги, не выходит заставить работать коннлимит внутри неймспейса ..
Ядро
Linux node-1.domain.tld 2.6.32-431.el6.x86_64 #1 SMP Wed May 14 15:10:05 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
modinfo xt_connlimit
filename:       /lib/modules/2.6.32-431.el6.x86_64/kernel/net/netfilter/xt_connlimit.ko
alias:          ip6t_connlimit
alias:          ipt_connlimit
license:        GPL
description:    Xtables: Number of connections matching
author:         Jan Engelhardt <jengelh@medozas.de>
srcversion:     05DDD107AD26EAD1D3A3E86
depends:        nf_conntrack
vermagic:       2.6.32-431.el6.x86_64 SMP mod_unload modversions
ЗЫ
Вообще-то это опенстек.
Так, создаю 2 неймспейса для чистоты эксперемнта.
ns2 имитирует ВМку, ns1 - транзитный
/sbin/ip netns add ns1
/sbin/ip netns add ns2
/sbin/ip link  add dev local_to_ns1 type veth peer name ns1_to_local
/sbin/ip link  add dev ns1_to_ns2   type veth peer name ns2_to_ns1
/sbin/ip link set  ns1_to_local  netns ns1
/sbin/ip link set  ns1_to_ns2    netns ns1
/sbin/ip link set  ns2_to_ns1    netns ns2
/sbin/ip addr add 172.18.0.1/30 dev local_to_ns1
/sbin/ip link set up dev local_to_ns1
/sbin/ip netns exec ns1 /sbin/ip link set up dev ns1_to_local
/sbin/ip netns exec ns1 /sbin/ip link set up dev ns1_to_ns2
/sbin/ip netns exec ns1 /sbin/ip addr add 172.18.0.2/30 dev ns1_to_local
/sbin/ip netns exec ns1 /sbin/ip addr add 172.18.0.5/30 dev ns1_to_ns2
/sbin/ip netns exec ns1 /sbin/ip route add 0.0.0.0/0 via 172.18.0.1
/sbin/ip netns exec ns2 /sbin/ip addr add 172.18.0.6/30 dev ns2_to_ns1
/sbin/ip netns exec ns2 /sbin/ip route add 0.0.0.0/0 via 172.18.0.5
/sbin/ip netns exec ns2 /sbin/ip link set up dev ns2_to_ns1
После чего в ns1 (транзитный) добавляю 2 правила
нат и connlimit (ine alias ip netns exec )
ine ns1 iptables -t nat -nL
Chain PREROUTING (policy ACCEPT)
target     prot opt source               destination
Chain POSTROUTING (policy ACCEPT)
SNAT       all  --  172.18.0.6           0.0.0.0/0           to:172.18.0.2
Chain OUTPUT (policy ACCEPT)
ine ns1 iptables  -nL -xv
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
   pkts      bytes target     prot opt in     out     source               destination
Chain FORWARD (policy ACCEPT 173 packets, 11463 bytes)
      0        0 REJECT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:25 flags:0x17/0x02 #conn/32 > 1 reject-with icmp-port-unreachable
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
После чего пробую 2 и более раз одновременно
ine ns2 telnet mail 25
И - успешно проходят (срабатывания правила нет)
ОДНАКО
если НАТ вынести из неймспейса в global то правило начинает срабатывать.
Потому очевидно вопрос - как заставить работать коннлимит и нат одновременно - дело похоже не в неймспейсах.
Ага, про нат это точно. Насколько я могу покапаться в моих угасающих знаниях, connlimit смотрит в табличку, которую составляет conntrack. Но вся грусть заключается в том, что conntrack собирает информацию _до_ NAT'а. В рузультате коннекшн после НАТа, не зарегистрированный в conntrack каждый раз считается первым. :(
Что делать? А фиг его знает. Сделать дополнительный ns stack для ната отдельно (попахивает изысканным извращением). У меня НАТ вообще вынесен в пограничный роутер.
PS Проверять еще удобно апачевским бенчмарком - ab.
Edited by vop
На убунте
ip netns exec ns1 conntrack -L | wc -l
conntrack v1.4.1 (conntrack-tools): 2 flow entries have been shown.
2
На CentOS
conntrack v0.9.13 (conntrack-tools): Operation failed: Connection refused
У кого есть проверить ядрышко?
Вопрос не понятен
Если не затруднилит проверить это только у меня так или еще у кого то. Но ядро нужно от опенстека (Rdo) c поддержкой неймспейсов
Дело в ядре - на более новых (попробовал 3.10) - проблемы нет и фильтрация работает как ожидалось.
Центос достаточно консервативен.
Так первым делом надо ELRepo ставить и обновляться.
Это не всегда возможно.
Я предпочитаю обновляться на ELRepo только если не работает что-то конкретно (как сейчас), все таки шанс поймать баг значительно ниже в стандартных ядрах.
