Dushes Posted December 24, 2014 Posted December 24, 2014 Не получается заставить работать ipv6 через IP Unnumbered, без него все oк подскажите что делаю не так стороны клиента на интерфейсе прописан 2a02:128:8::2/48 interface Loopback2 no ip address ipv6 address 2A02:128:8::1/48 ipv6 enable end interface TenGigabitEthernet0/2/0.20 encapsulation dot1Q 20 ip unnumbered Loopback1 ip nat inside ip flow monitor NETFLOW-MONITOR input ip flow monitor NETFLOW-MONITOR output ipv6 unnumbered Loopback2 ipv6 enable end ipv6 unicast-routing ipv6 route 2A02:128:8::2/128 TenGigabitEthernet0/2/0.20 asr-1002#show ipv6 neighbors IPv6 Address Age Link-layer Addr State Interface 2A02:128:8::2 208 d4ca.6d31.ba4e STALE Te0/2/0.20 FE80::D6CA:6DFF:FE31:BA4E 208 d4ca.6d31.ba4e STALE Te0/2/0.20 .... asr-1002#ping FE80::D6CA:6DFF:FE31:BA4E Output Interface: TenGigabitEthernet0/2/0.20 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to FE80::D6CA:6DFF:FE31:BA4E, timeout is 2 seconds: Packet sent with a source address of FE80::AA0C:DFF:FE8E:7C20%TenGigabitEthernet0/2/0.20 !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/3 ms asr-1002#ping 2A02:128:8::2 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 2A02:128:8::2, timeout is 2 seconds: ..... Success rate is 0 percent (0/5) Лог пакетов с клиента (микротик) https://www.dropbox.....19.54.png?dl=0 Вставить ник Quote
vlad11 Posted December 24, 2014 Posted December 24, 2014 Прикладывайте дамп ipv6 пакетов на стороне клиента. Вставить ник Quote
Dushes Posted December 24, 2014 Author Posted December 24, 2014 в качестве клиента настроен mikrotik когда пингую его вижу следующее asr-1002#ping 2A02:128:8::2 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 2A02:128:8::2, timeout is 2 seconds: ..... Success rate is 0 percent (0/5) https://www.dropbox.com/s/4qtlbze86t72by2/Screenshot%202014-12-24%2013.19.54.png?dl=0 Вставить ник Quote
vlad11 Posted December 24, 2014 Posted December 24, 2014 Дамп прикладывайте, а не конфиг Микротика. В крайнем случае подключите ПК и на нем настройте клиента. Вставить ник Quote
Dushes Posted December 24, 2014 Author Posted December 24, 2014 vlad11 в микротике лог фактически и есть дамп, только не подробный Вставить ник Quote
vlad11 Posted December 24, 2014 Posted December 24, 2014 vlad11 в микротике лог фактически и есть дамп, только не подробный log микротика не есть дамп. Обращайтесь с этим "логом" в суппорт Микротика. Ждем результатов при подключении другого клиентского оборудования. Вставить ник Quote
Merridius Posted December 24, 2014 Posted December 24, 2014 А за чем вообще использовать ipv6 unnumbered? Неужели адресов не хватает?) Вставить ник Quote
vlad11 Posted December 24, 2014 Posted December 24, 2014 А за чем вообще использовать ipv6 unnumbered? Неужели адресов не хватает?) Ну, ТС вместо /64 выдал клиенту /128, если там соединение точка-точка, то не критично, если абонентское устройство, то нужно больше выдавать. Вставить ник Quote
SyJet Posted December 24, 2014 Posted December 24, 2014 А кто вообще ipv6 внедрил? Может кто в личке поделиться опытом внедрения? Вставить ник Quote
vlad11 Posted December 24, 2014 Posted December 24, 2014 Один мой знакомый дает ipv6 абонентам. Так как его мало, всего пару %, то даже с шейпингом не замарачивается. Вставить ник Quote
Dushes Posted December 25, 2014 Author Posted December 25, 2014 я уже много провел эксперементов на тему ipv6 считаю одним из факторов торможения внедрения недостаток информации, очень тяжело разбираться как только закончу все тесты очень подробно распишу весь процес внедрения ipv6 на ASR 1002 + 6509 + СКАТ + Mikrotik, опишу как себя видут 3-7 видов точек доступа, как оказалось там много интересных вещей вообщем зайду со всех сторон и сделаю хорошие описания для провайдеров которые реально хотят внедрять, а не куча теории которой сейчас весь интернет переполнен ) А за чем вообще использовать ipv6 unnumbered? Неужели адресов не хватает?) 2000 VLAN разных вопрос как на это все подконтрольно выдавать адреса через radius Вставить ник Quote
Sergeylo Posted December 25, 2014 Posted December 25, 2014 как на это все подконтрольно выдавать адреса через radius Framed-IPv6-Prefix? Вставить ник Quote
Dushes Posted December 25, 2014 Author Posted December 25, 2014 Sergeylo да именно + Delegated-IPv6-Prefix Delegated-IPv6-Prefix Delegated-IPv6-Prefix-Pool DNS-Server-IPv6-Address Framed-Interface-Id Framed-IPv6-Pool Framed-IPv6-Prefix Framed-IPv6-Route IPv6 ACL IPv6_DNS_Servers IPv6 Pool IPv6 Prefix# IPv6 Route Login-IPv6-Host http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipv6/configuration/xe-3s/ipv6-xe-36s-book/ip6-adsl-dial.html#GUID-11D690FE-C523-4636-AAD3-B3C9D98B938E Вставить ник Quote
Pro-R Posted November 19, 2015 Posted November 19, 2015 как только закончу все тесты очень подробно распишу весь процес внедрения ipv6 на ASR 1002 + 6509 + СКАТ + Mikrotik, опишу как себя видут 3-7 видов точек доступа, как оказалось там много интересных вещей Разобрались? Если не трудно прошу поделиться опытом настройки ASR1k и ipv6. Вставить ник Quote
flamaster Posted July 13, 2016 Posted July 13, 2016 я уже много провел эксперементов на тему ipv6 считаю одним из факторов торможения внедрения недостаток информации, очень тяжело разбираться как только закончу все тесты очень подробно распишу весь процес внедрения ipv6 на ASR 1002 + 6509 + СКАТ + Mikrotik, опишу как себя видут 3-7 видов точек доступа, как оказалось там много интересных вещей вообщем зайду со всех сторон и сделаю хорошие описания для провайдеров которые реально хотят внедрять, а не куча теории которой сейчас весь интернет переполнен ) ждем подробности! Вставить ник Quote
