Люди добрые, подскажите Как посмотреть статистику NAT трансляций на juniper SRX3400?
Особенно интересно - количество нат трансляций, новые трансляции \ старые и т.д.
show security flow session nat - только нат сессии,
a.makhinov@srx100> show security flow session nat
Session ID: 8446, Policy name: trust-to-untrust/4, Timeout: 2, Valid
In: y.y.y.y/751 --> x.x.x.x/7034;icmp, If: fe-0/0/1.0, Pkts: 1, Bytes: 84
Out: x.x.x.x/7034 --> y.y.y.y/31151;icmp, If: fe-0/0/0.0, Pkts: 1, Bytes: 84
a.makhinov@srx100> show security flow session nat summary
Valid sessions: 0
Pending sessions: 0
Invalidated sessions: 0
Sessions in other states: 0
Total sessions: 0
a.makhinov@srx100> show security flow session nat extensive
Session ID: 14512, Status: Normal
Flag: 0x80000000
Source NAT pool: interface
Maximum timeout: 4, Current timeout: 4
Session State: Valid
Start time: 6387887, Duration: 0
In: x.x.x.x/1 --> y.y.y.y/13998;icmp,
Interface: fe-0/0/1.0,
Session token: 0x6, Flag: 0x21
Route: 0x60010, Gateway: x.x.x.x, Tunnel: 0
Port sequence: 0, FIN sequence: 0,
FIN state: 0,
Pkts: 1, Bytes: 84
Out: y.y.y.y/13998 --> z.z.z.z/13770;icmp,
Interface: fe-0/0/0.0,
Session token: 0x7, Flag: 0x20
Route: 0x50010, Gateway: z.z.z.z, Tunnel: 0
FIN state: 0,
Pkts: 1, Bytes: 84
Так же можно глянуть
a.makhinov@srx100> show security nat source rule all
Total rules: 1
Total referenced IPv4/IPv6 ip-prefixes: 3/0
source NAT rule: 1 Rule-set: Trust_to_Untrust
Rule-Id : 1
Rule position : 1
From zone : trust
To zone : untrust
Match
Source addresses : x.x.x.x - x.x.x.x
Destination addresses : y.y.y.y - y.y.y.y
y.y.y.y - y.y.y.y
Destination port : 0 - 0
IP protocol : icmp
Action : interface
Persistent NAT type : N/A
Persistent NAT mapping type : address-port-mapping
Inactivity timeout : 0
Max session number : 0
Translation hits : 12719
