Здравствуйте.
Имеем С6506 в следующей конфигурации:
Mod Ports Card Type                              Model              Serial No.
 1   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL1210J6xx
 4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1011FXxx
 5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL095290xx
Mod MAC addresses                       Hw    Fw           Sw           Status
 1  001e.4a69.d11c to 001e.4a69.d14b   1.10  12.2(14r)S5  12.2(33)SXJ6 Ok
 4  0017.0e2b.a640 to 0017.0e2b.a66f   2.3   12.2(14r)S5  12.2(33)SXJ6 Ok
 5  0013.c347.2054 to 0013.c347.2057   4.6   8.4(2)       12.2(33)SXJ6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
 1  Distributed Forwarding Card WS-F6700-DFC3B     SAL1207G7xx  4.6    Ok
 4  Distributed Forwarding Card WS-F6700-DFC3B     SAL1222RYxx  4.6    Ok
 5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1026TCxx  2.3    Ok
 5  MSFC3 Daughterboard         WS-SUP720          SAL1026TKxx  2.5    Ok
Mod  Online Diag Status
 1  Pass
 4  Pass
 5  Pass
Софт:
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SXJ6, RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 19-Jul-13 03:29 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
c6506 uptime is 1 week, 5 days, 3 hours, 25 minutes
Uptime for this control processor is 1 week, 5 days, 3 hours, 25 minutes
Time since c6506 switched to active is 1 week, 5 days, 3 hours, 24 minutes
System returned to ROM by reload at 15:00:35 UTC Thu Oct 23 2014 (SP by reload)
System restarted at 05:05:14 UTC Thu Dec 4 2014
System image file is "disk1:s72033-adventerprisek9-mz.122-33.SXJ6.bin"
Периодически в лог вываливается:
 %EARL-SP-2-SWITCH_BUS_IDLE: Switching bus is idle for 2 seconds. The card grant is 0
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0xED] HY_FI_FR_LO_FULLNESS_A = 0x7CB
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x11B] HY_FI_FT_LO_FULL_A = 0x0
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x153] HY_EI_EC_CNTRL = 0x13
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x154] HY_EI_EC_HDR_FORM = 0xE
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x160] HY_EI_EC_BUS_STATUS = 0x3
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x196] HY_LS_SV_SYNC_STATUS = 0x3
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x189] HY_LS_SV_DBUS_FLOW_CONTROL_STAT = 0x0
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x18A] HY_LS_SV_RBUS_FLOW_CONTROL_STAT = 0x0
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x5B0] HY_LM_MS_BUS_STATUS = 0x78
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x62D] HY_DR_RI_GEN_RI_INT = 0x0
1w5d: %SYS-5-CONFIG_I: Configured from rcp://secret@10.30.20.10/acl_local_fixed_ip_srv by console
1w5d: %EARL-SP-2-SWITCH_BUS_IDLE: Switching bus is idle for 2 seconds. The card grant is 0
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0xED] HY_FI_FR_LO_FULLNESS_A = 0x7C5
1w5d: %PF_ASIC-SP-3-ASIC_DUMP: [0:0x5B0] HY_LM_MS_BUS_STATUS = 0x50
Уважаемые, подскажите в какую сторону мне копать и что можно сделать? Ошибка стала появляться после того, как в 6 слот (при выключенном питании)вставили модуль Cisco Catalyst WS-X6708-10G-3CXL. После этого модуль WS-X6708-10G-3CXL был извлечен. До этого этот каталист несколько месяцев отработал без ошибок.
Добрый день.
Предлагаю просто перезагрузить шасси.
Ошибка вызвана наиболее вероятно не согласованием фабрик, а если точнее PFC3B у супервизора и DFC3CXL модуля.
Если перезагрузить систему совместно с установленным 6708 то должно будет все завестись без ошибок, (т.к. вся фабрика будет синхронизирована до уровня 3В)
Добрый день.
Дело в том, что сначала мы при отключенном питании установили модуль 6708, запустились, всё заработало нормально. Через пару часов циска вывалила ошибку (в это время трафик через циску перестал ходить на несколько секунд), затем всё само заработало. Но через минут 30 ошибка еще раз повторилась. Затем еще раз. Так как циска стоит в работе, то дальше решили не ждать. Отключили питание, выняли модуль 6708 и снова запустились в исходной конфигурации
После этого циска почти 2 недели отработала без сбоев, но сегодня ошибка снова повторилась. :(
Уверен, стоит поставить резервный, раз таковой имеется.
Будет сложно определить какая из составляющих супервизора вызывает проблему. (Методом исключения только... сменив одну плату, затем другую, затем обе платы на другую подложку).. Но мне кажется в вашем случае такие эксперименты не приветствуются, раз сеть рабочая и загружена.
А еще проверить не загнули ли контакты шины при установке модуля, не занесли ли грязь какую, et cetera. Вполне реальный сценарий, сами разок с пылесосом дебажили 6506.
Хоть и циска боевая, но проблему разруливать нужно было. Поэтому прошлой ночью остановили, поменяли супервизор и дополнительно вставили WS-X6708-10G-3CXL на сей раз в 3 слот. На данный момент все работает без ошибок. Будем мониторить дальше.
Пока так глубоко не лазили. Ограничились заменой супервизора.
