Вообщем поставил девайсы WiFI, 2 активный сегменто параболических антенны на 27dbi. Расстояние 500 метров теряются пакеты. Оновная проблема вот в чем, например если человек из рабочей группы с той стороны моста качает файл с моей стороны, процентов так 60% что процесс переливания файла просто напросто оборвётся.
В чем может быть проблема?
Точки: Asus 300G (2штуки)
Пинг:
C:Documents and SettingsCron>ping -n 100 -l 1500 192.168.1.204
Pinging 192.168.1.204 with 1500 bytes of data:
Request timed out.
Request timed out.
Reply from 192.168.1.204: bytes=1500 time=18ms TTL=128
Request timed out.
Request timed out.
Reply from 192.168.1.204: bytes=1500 time=17ms TTL=128
Request timed out.
Request timed out.
Reply from 192.168.1.204: bytes=1500 time=89ms TTL=128
Request timed out.
Request timed out.
Reply from 192.168.1.204: bytes=1500 time=87ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=56ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=58ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.204: bytes=1500 time=11ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=7ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=6ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=10ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=8ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=5ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=4ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=9ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.204:
  Packets: Sent = 100, Received = 77, Lost = 23 (23% loss),
Approximate round trip times in milli-seconds:
  Minimum = 4ms, Maximum = 89ms, Average = 11ms
Более удачный пинг:
Request timed out.
Reply from 192.168.1.204: bytes=1500 time=15ms TTL=128
Reply from 192.168.1.204: bytes=1500 time=16ms TTL=128
   Packets: Sent = 100, Received = 99, Lost = 1 (1% loss),
   Minimum = 4ms, Maximum = 16ms, Average = 6ms
