Вот, сегодня в 4 ночи сам перезапустился
загрузка заканчивается на этом:
Flowmask is MODIFIED to interface and full flow
*Oct 12 05:07:07.776: RP: Currently running ROMMON from S (Gold) region
*Oct 12 12:07:14.784 Novosib: %SYS-6-CLOCKUPDATE: System clock has been updated from 05:07:14 UTC Sun Oct 12 2014 to 12:07:14 Novosib Sun Oct 12 2014, configured from console by console.
*Oct 12 12:07:15.052 Novosib: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan. The Bridge IDs of all active STP instances have been updated, which might change the spanning tree topology
*Oct 12 12:08:21.952 Novosib: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 12 12:08:42.092 Novosib: %SYS-5-RESTART: System restarted --
Cisco IOS Software, s3223_rp Software (s3223_rp-ADVENTERPRISEK9_WAN-VM), Version 12.2(33)SXI6, RELEASE SOFTWARE (fc4)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2011 by Cisco Systems, Inc.
Compiled Mon 28-Mar-11 05:31 by prod_rel_team
*Oct 12 04:53:48.868: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Oct 12 05:07:03.476: %SCHED-SP-7-WATCH: Attempt to set uninitialized watched boolean (address 0). -Process= "<interrupt level>", ipl= -1, pid= -1 : ios-base : (PID=12308, TID=17) : -Traceback=(s3223-adventerprisek9_wan-0-dso-bn.so+0x156A8C) ([26:-3]4-dso-b+0x4F9B48) ([26:-9]2+0x4A0410) ([36:0]+0x49EE90) ([36:0]+0x484304) ([36:0]+0x2FE9BC) ([26:-9]4+0x241F3C) ([36:0]+0x3F7A10) ([0:-3]libc+0x2404C)
*Oct 12 05:07:15.049: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan. The Bridge IDs of all active STP instances have been updated, which might change the spanning tree topology
*Oct 12 05:08:41.172: %SYS-SP-5-RESTART: System restarted --
Cisco IOS Software, s3223_sp Software (s3223_sp-ADVENTERPRISEK9_WAN-VM), Version 12.2(33)SXI6, RELEASE SOFTWARE (fc4)
Compiled Mon 28-Mar-11 05:50 by prod_rel_team
*Oct 12 05:08:41.188: SP: Currently running ROMMON from S (Gold) region
*Oct 12 05:08:41.588 UTC: %OIR-SP-6-INSPS: Power supply inserted in slot 1
*Oct 12 12:08:42.160 Novosib: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Oct 12 05:08:41.596 UTC: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
*Oct 12 05:08:43.524 UTC: %C6KENV-SP-4-FANHIOUTPUT: Version 2 high-output fan-tray is in effect
*Oct 12 05:08:43.524 UTC: %OIR-SP-6-INSFAN: Fan 1 inserted
*Oct 12 12:08:45.420 Novosib: %SNMP-5-COLDSTART: SNMP agent on host C6509 is undergoing a cold start
*Oct 12 12:08:45.510 Novosib: %DIAG-SP-6-RUN_MINIMUM: Module 5: Running Minimal Diagnostics...
*Oct 12 12:09:21.732 Novosib: %DIAG-SP-3-MAJOR: Module 5: Online Diagnostics detected a Major Error. Please use 'show diagnostic result <target>' to see test results.
*Oct 12 12:09:21.736 Novosib: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 5: TestFibDevices failed
*Oct 12 12:09:21.736 Novosib: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 5: TestIPv4FibShortcut failed
*Oct 12 12:09:21.736 Novosib: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 5: TestL3Capture2 failed
*Oct 12 12:09:21.736 Novosib: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 5: TestIPv6FibShortcut failed
*Oct 12 12:09:21.736 Novosib: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 5: TestMPLSFibShortcut failed
*Oct 12 05:09:22.524: %HA_EM-6-LOG: Mandatory.go_bootup.tcl: GOLD EEM TCL policy for boot up diagnostic
Crashdump : 05:09:24.708 Sun Oct 12 2014 : ios-base : (PID=12310, TID=7) : -Traceback=(s3223_rp-adventerprisek9_wan-11-dso-b.so+0x417C0C) ([40:0]+0x417C54) ([40:0]+0x456FD4) ([29:-9]7+0x363454) ([39:0]+0x3634D4) ([29:-9]4+0x2BA81C) ([39:0]+0x2BB984) ([39:0]+0x2BB880) ([39:0]+0x2BC89C) ([29:-9]5+0x29EFF8) ([39:0]+0x28D860) ([39:0]+0x28DAF0) ([29:-9]0+0x40E700) ([29:-9]7+0x34F304) ([0:-3]libc+0x2404C)
crashdump called (with pause = 0 sec)
%ALIGN-1-FATAL: Illegal access to a low address 12:09:24 Novosib Sun Oct 12 2014
addr=0x0, pc=0x75EE1BA4, ra=0x75EE1AD0, sp=0xF59850
SLOT0:00:03:22: %DUMPER-3-PROCINFO: pid = 12310: (sbin/ios-base), terminated due to signal SIGSEGV, Segmentation violation (Address not mapped)
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: zero at v0 v1
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R0 00000000 7C18CB78 00000017 00F59FC0
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: a0 a1 a2 a3
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R4 00000002 00F59EC0 00F59FC0 00000000
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: t0 t1 t2 t3
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R8 00000000 00000000 00000053 00000000
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: t4 t5 t6 t7
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R12 00000000 776AC070 FFFFFFFF 77688000
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: s0 s1 s2 s3
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R16 00F59B10 00F59B40 00000000 0000001F
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: s4 s5 s6 s7
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R20 7A66E0A0 00000000 00000000 08196A48
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: t8 t9 k0 k1
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R24 00F59750 7065D6B0 00000000 00000000
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: gp sp s8 ra
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R28 7C0DF490 00F59850 00000000 75EE1AD0
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: sr lo hi bad
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R32 1001D463 00000000 00000002 00000000
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: cause pc epc
SLOT0:00:03:22: %DUMPER-3-REGISTERS_INFO: 12310: R36 0000000C 75EE1BA4 00000000
SLOT0:00:03:23: %DUMPER-3-TRACE_BACK_INFO: 12310: (s3223_rp-adventerprisek9_wan-14-dso-b.so+0x269BA4) (s3223_rp-adventerprisek9_wan-11-dso-b.so+0x417C0C) (s3223_rp-adventerprisek9_wan-11-dso-b.so+0x417C54) (s3223_rp-adventerprisek9_wan-11-dso-b.so+0x456FD4) (s3223_rp-adventerprisek9_wan-7-dso-b.so+0x363454) (s3223_rp-adventerprisek9_wan-7-dso-b.so+0x3634D4) (s3223_rp-adventerprisek9_wan-4-dso-b.so+0x2BA81C) (s3223_rp-adventerprisek9_wan-4-dso-b.so+0x2BB984) (s3223_rp-adventerprisek9_
SLOT0:00:03:31: %DUMPER-6-BAD_PATH: 12310: Choice 1 either not configured or bad path. Trying next choice.
SLOT0:00:03:31: %DUMPER-6-BAD_PATH: 12310: Choice 2 either not configured or bad path. Trying next choice.
SLOT0:00:03:31: %DUMPER-6-BAD_PATH: 12310: Choice 3 either not configured or bad path. Trying next choice.
SLOT0:00:03:31: %DUMPER-3-DUMP_FAILURE: 12310: Core dump failed: Could not create core
SLOT0:00:03:35: %DUMPER-3-CRASHINFO_FILE_NAME: 12310: Crashinfo for process sbin/ios-base at bootflash:/crashinfo_ios-base-20141012-050924
SLOT0:00:03:35: %SYSMGR-3-ABNORMTERM: ios-base:1 (jid 71) abnormally terminated, restart disabled
SLOT0:00:03:35: %SYSMGR-6-ERROR_EOK: ios-base:1 (jid 71) mandatory process exited, rebooting
System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Copyright © 2004 by cisco Systems, Inc.
Cat6k-MSFC2A platform with 524288 Kbytes of main memory
System Bootstrap, Version 12.2(18r)SX9, RELEASE SOFTWARE (fc1)
Copyright © 2008 by cisco Systems, Inc.
Cat6k-Sup32 platform with 524288 Kbytes of main memory
rommon 1 >
убрал перезагрузку с помощью #no diagnostic bootup level minimal
загрузилась, сеть еле шевелится
посоветуйте, новый SUP будет еще дней 5 ехать
Кроме как разобрать/сдуть пыль/сбрать в т.ч. память вынуть/подышать спиртом/вставить и попробовать другой слот для фабрики (там альтернатива 5/6 если я не путаю) ничего в голову не приходит...
Можно еще попробовать стартовать железку только с фабрикой, а все остальное вынуть...
Был, кстати, масштабный брак по памяти у cisco... Но как тут можно проверить и вылечить я не знаю... Если память вынимается, не распаяна, можно попробовать найти аналоги в магазинах, писали кингстоны и ксиниксы обычно подходят.
Советую: второй суп должен быть или в коробке или на полке, а не у продавца или на почте.
А по-месту: sh diag result mod 5 detail, но вряд ли оно чем поможет. А тормозит видимо из-за того что CEF не работает.
Ну и на верочку можно и IOS вкатить проверенный типа s3223-advipservicesk9_wan-mz.122-33.SXJ5.bin (или SXJ6,7) вместо того что у вас, но шансов мало.
90% что память, аккуратно достать, протереть контакты на планках памяти
покажите еще лог bootflash:/crashinfo_ios-base-20141012-050924
