есть нат сервер, решил поднять на нем же шейпер.
собственно вот правила шейпера:
tc qdisc del dev bond0.8 root
tc qdisc add dev bond0.8 root handle 1: htb default 900
tc class add dev bond0.8 parent 1: classid 1:1 htb rate 4000Mbit burst 150k
tc class add dev bond0.8 parent 1:1 classid 1:100 htb rate 3800Mbit burst 150k
tc class add dev bond0.8 parent 1: classid 1:900 htb rate 3800Mbit burst 150k
tc qdisc add dev bond0.8 parent 1:900 handle 900 pfifo limit 50000
tc filter add dev bond0.8 parent 1:0 protocol ip u32
tc filter add dev bond0.8 parent 1:0 handle 12: protocol ip u32 divisor 8
tc filter add dev bond0.8 parent 1:0 handle 13: protocol ip u32 divisor 256
tc filter add dev bond0.8 parent 1:0 handle 14: protocol ip u32 divisor 256
tc filter add dev bond0.8 parent 1:0 handle 15: protocol ip u32 divisor 256
tc filter add dev bond0.8 parent 1:0 handle 16: protocol ip u32 divisor 256
tc filter add dev bond0.8 parent 1:0 handle 17: protocol ip u32 divisor 256
tc filter add dev bond0.8 parent 1:0 protocol ip u32 ht 800:: match ip dst 172.24.128.0/17 hashkey mask 0x0000ff00 at 16 link 12:
tc filter add dev bond0.8 parent 1:0 protocol ip u32 ht 12:0: match ip dst 172.24.128.0/24 hashkey mask 0x000000ff at 16 link 13:
tc filter add dev bond0.8 parent 1:0 protocol ip u32 ht 12:1: match ip dst 172.24.129.0/24 hashkey mask 0x000000ff at 16 link 14:
tc filter add dev bond0.8 parent 1:0 protocol ip u32 ht 12:2: match ip dst 172.24.130.0/24 hashkey mask 0x000000ff at 16 link 15:
tc filter add dev bond0.8 parent 1:0 protocol ip u32 ht 12:3: match ip dst 172.24.131.0/24 hashkey mask 0x000000ff at 16 link 16:
tc filter add dev bond0.8 parent 1:0 protocol ip u32 ht 12:4: match ip dst 172.24.132.0/24 hashkey mask 0x000000ff at 16 link 17:
tc class add dev bond0.8 parent 1:100 classid 1:1001 htb rate 20Mbit ceil 20Mbit
tc qdisc add dev bond0.8 parent 1:1001 handle 1001 sfq  perturb 10
tc filter add dev bond0.8 protocol ip parent 1:0 u32 ht 13:1: match ip dst 172.24.128.1 flowid 1:1001
tc class add dev bond0.8 parent 1:100 classid 1:1002 htb rate 20Mbit ceil 20Mbit
tc qdisc add dev bond0.8 parent 1:1002 handle 1002 sfq  perturb 10
tc filter add dev bond0.8 protocol ip parent 1:0 u32 ht 13:2: match ip dst 172.24.128.2 flowid 1:1002
tc class add dev bond0.8 parent 1:100 classid 1:1003 htb rate 20Mbit ceil 20Mbit
tc qdisc add dev bond0.8 parent 1:1003 handle 1003 sfq  perturb 10
tc filter add dev bond0.8 protocol ip parent 1:0 u32 ht 13:3: match ip dst 172.24.128.3 flowid 1:1003
tc class add dev bond0.8 parent 1:100 classid 1:1004 htb rate 20Mbit ceil 20Mbit
tc qdisc add dev bond0.8 parent 1:1004 handle 1004 sfq  perturb 10
tc filter add dev bond0.8 protocol ip parent 1:0 u32 ht 13:4: match ip dst 172.24.128.4 flowid 1:1004
tc class add dev bond0.8 parent 1:100 classid 1:1005 htb rate 20Mbit ceil 20Mbit
tc qdisc add dev bond0.8 parent 1:1005 handle 1005 sfq  perturb 10
tc filter add dev bond0.8 protocol ip parent 1:0 u32 ht 13:5: match ip dst 172.24.128.5 flowid 1:1005
tc class add dev bond0.8 parent 1:100 classid 1:1006 htb rate 20Mbit ceil 20Mbit
тут дальше куча идентичных классов, фильтров и очередей
Проблема выражается таким образом:
При увеличении общего трафика через сервер у юзеров, попадающих в классы 1:1001-1:1275, все нормально со скоростью (наблюдается просадка не более 5%, но это из-за загруженности сервера)
А у пользователей, попадающих в дефолтный класс, серьезные проблемы со скоростью.
Из 100 мбит не более 3-х, задержки при открытии страниц и прочие прелести.
Загрузка CPU 50-60% по каждому из 8 ядер.
Что я сделал неправильно?
Или оно просто не должно работать при таком количестве правил и трафике через сервер ~1Gbit/sec ?
Edited by acutus
Попробуйте вместо
поставить
tc class add dev bond0.8 parent 1:1 classid 1:900 htb rate 200Mbit ceil 3800Mbit burst 150k
Ну или изменить дефолтный класс
tc qdisc add dev bond0.8 root handle 1: htb default 1
Попробуйте оба варианта.
А вообще, откуда такие скорости (4000,3800) если
Из 100 мбит
Да, и хотя это источником проблем не является, но хеши работать не будут. Хеширование идет по всему 3-му октету (ff), а хеши второго порядка указаны от 128. Хеши не работают.
Либо в первом фильтре делайте hashkey 0x00007f00, либо в дочерних хешах указывайте ht 12:128 (вместо 12:0), 12:129(виесто 12:1) и т.д.
Edited by SABRE
