Есть пачка серверов Supermicro 5017C-MTRF с дибианом 7 на борту. Хочу помимо прочего мониторить на них состояние БП. После sensors-detect есть вот что:
acpitz-virtual-0
Adapter: Virtual device
temp1:        +27.8°C  (crit = +106.0°C)
temp2:        +29.8°C  (crit = +106.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +25.0°C  (high = +85.0°C, crit = +105.0°C)
Core 0:         +21.0°C  (high = +85.0°C, crit = +105.0°C)
Core 1:         +23.0°C  (high = +85.0°C, crit = +105.0°C)
Core 2:         +25.0°C  (high = +85.0°C, crit = +105.0°C)
Core 3:         +25.0°C  (high = +85.0°C, crit = +105.0°C)
nct6776-isa-0a30
Vcore:         +0.68 V  (min =  +0.60 V, max =  +1.49 V)
in1:           +1.85 V  (min =  +1.62 V, max =  +1.99 V)
AVCC:          +3.38 V  (min =  +2.98 V, max =  +3.63 V)
+3.3V:         +3.38 V  (min =  +2.98 V, max =  +3.63 V)
in4:           +1.52 V  (min =  +1.35 V, max =  +1.65 V)
in5:           +1.27 V  (min =  +1.13 V, max =  +1.38 V)
3VSB:          +3.33 V  (min =  +2.98 V, max =  +3.63 V)
Vbat:          +3.09 V  (min =  +2.70 V, max =  +3.63 V)
fan1:         4891 RPM  (min =  300 RPM)
fan2:            0 RPM  (min =  300 RPM)  ALARM
fan3:         4963 RPM  (min =  300 RPM)
fan4:         4927 RPM  (min =  300 RPM)
fan5:         5018 RPM  (min =  300 RPM)
SYSTIN:        +27.0°C  (high = +75.0°C, hyst = +70.0°C)  sensor = thermistor
CPUTIN:        +22.0°C  (high = +80.0°C, hyst = +75.0°C)  sensor = thermistor
AUXTIN:         +1.5°C    sensor = thermistor
PECI Agent 0:  +16.5°C  (high = +95.0°C, hyst = +92.0°C)
cpu0_vid:     +2.050 V
intrusion0:   ALARM
intrusion1:   ALARM
В общем, что угодно, только не БП. Есть еще мысли как их увидеть из под ОС?
Разве что через ipmi.
Но у меня на материнке Supermicro Product Name: X9SCL/X9SCM Version: 1.11A
в ipmi доступно только это
ipmitool sdr
System Temp      | 30 degrees C      | ok
CPU Temp         | 0 unspecified     | ok
FAN 1            | 8775 RPM          | ok
FAN 2            | 8910 RPM          | ok
FAN 3            | 9315 RPM          | ok
FAN 4            | disabled          | ns
FAN A            | 9045 RPM          | ok
Vcore            | 1.02 Volts        | ok
3.3VCC           | 3.38 Volts        | ok
12V              | 12.03 Volts       | ok
VDIMM            | 1.53 Volts        | ok
5VCC             | 5.06 Volts        | ok
-12V             | -12.45 Volts      | ok
VBAT             | 3.14 Volts        | ok
VSB              | 3.33 Volts        | ok
AVCC             | 3.38 Volts        | ok
Chassis Intru    | 0 unspecified     | ok
PS Status        | 0 unspecified     | nc
Правда у меня не родной супермикровский корпус и нет 2 бп
Edited by ShumBor
В родном корпусе все показывается, в т.ч. и БП
System Temp      | 22 degrees C      | ok
Peripheral Temp  | 27 degrees C      | ok
FAN 1            | 5175 RPM          | ok
FAN 2            | 4950 RPM          | ok
FAN 3            | 4950 RPM          | ok
FAN A            | 4725 RPM          | ok
Vcore            | 0.71 Volts        | ok
12V              | 12.24 Volts       | ok
VDIMM            | 1.52 Volts        | ok
5VCC             | 5.09 Volts        | ok
-12V             | -12.10 Volts      | ok
VBAT             | 3.09 Volts        | ok
Chassis Intru    | 0 unspecified     | nc
PS2 Status       | 0x01              | ok
PS1 Status       | 0x01              | ok
