Всем привет, пытаюсь запустить qinq, но пока безуспешно
агрегатор DGS3120 8-м портом (UNI mode) подключен к каталисту, одинарные вланы ходят, двойные нет
DGS-3120
# VLAN
enable pvid auto_assign
config vlan default delete 1-26
config vlan default add untagged 1-6,8-26
config vlan default advertisement disable
create vlan s500 tag 500
config vlan s500 add tagged 8 advertisement disable
create vlan Test_Node tag 916
config vlan Test_Node add tagged 1-6,8-24 advertisement disable
create vlan c1000 tag 1000
config vlan c1000 add tagged 1-6,8-24 advertisement disable
enable qinq
disable gvrp
config gvrp nni_bpdu_addr dot1ad
disable asymmetric_vlan
disable vlan_trunk
config port_vlan 1-26 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 1
# QINQ
config qinq ports 1-7,9-24  outer_tpid 0x8100
config qinq ports 8 role uni missdrop enable outer_tpid 0x8100
create vlan_translation ports 8 replace cvid 916 svid 916
create vlan_translation ports 8 add cvid 1000 svid 500
Command: show qinq
QinQ Status : Enabled
с3750
c3750-48#sh run | b 1/0/39
interface GigabitEthernet1/0/39
description Test-Node
switchport trunk encapsulation dot1q
switchport trunk native vlan 28
switchport trunk allowed vlan 28,500,916
switchport mode trunk
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
c3750-48#sh system mtu
System MTU size is 1504 bytes
System Jumbo MTU size is 9000 bytes
Routing MTU size is 1500 bytes
смысл - завернуть клиентский влан 1000 и в 500-й и по нему доставить до браса. брас подключен в тот же каталист:
interface Port-channel2
description NAS30-channel
switchport trunk allowed vlan 1,500
interface GigabitEthernet1/0/17
description NAS30_aggr
channel-group 2 mode active
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
на сервере
bond1: flags=5187<UP,BROADCAST,RUNNING,MASTER,MULTICAST>  mtu 1500
       inet 172.16.0.230  netmask 255.255.255.0  broadcast 172.16.0.255
       ether 6c:ae:8b:52:9a:ea  txqueuelen 0  (Ethernet)
       RX packets 380225  bytes 42970600 (40.9 MiB)
       RX errors 0  dropped 0  overruns 0  frame 0
       TX packets 10779  bytes 1395743 (1.3 MiB)
       TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
bond1.500: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
       RX packets 0  bytes 0 (0.0 B)
       TX packets 0  bytes 0 (0.0 B)
bond1.501: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
bond1.500.1000: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
       inet 10.10.10.1  netmask 255.255.255.0  broadcast 10.10.10.255
где собака порылась?
Это вы пакетам, с тэгом 1000, приходящим с 8ого порта добавляете второй тэг 500
тогда как правильно сделать? к портам агрегатора подключены кольца раздачи, в них клиентские вланы 1000 ..., мне нужно их завернуть в сервисные 500 ...,
вланы 1..999 должны проходить через агрегатор без изменений, в данном случае 8 порт аплинк
Наверное правильнее сделать на 3750 "uni" access порт в влане 500. Я не настраивал qinq на циско, поэтому точно не знаю как это делается
