все файлы у нас на серваке в UTF-8, а хотелось получить в FTP-клиенте CP1251. Пропатчил vsftpd-2.0.1, использовав iconv.
в main.c строки
#define INSIDE_CHARSET "UTF-8"
#define OUTSIDE_CHARSET "CP1251"
задают внутреннюю и внешнюю кодировки.
Патч: vsftpd-2.0.1-convertable.diff
diff -uNr vsftpd-2.0.1/ftpcmdio.c vsftpd-2.0.1-convertable/ftpcmdio.c
--- vsftpd-2.0.1/ftpcmdio.c     2004-07-02 15:23:02.000000000 +0400
+++ vsftpd-2.0.1-convertable/ftpcmdio.c 2004-11-16 15:47:19.000000000 +0300
@@ -200,6 +200,7 @@
  ftp_getline(p_sess, p_str, p_sess->p_control_line_buf);
  /* As mandated by the FTP specifications.. */
  str_replace_char(p_str, '0', 'n');
+  str_iconv(p_str, 1);
  /* If the last character is a r, strip it */
    unsigned int len = str_getlen(p_str);
diff -uNr vsftpd-2.0.1/main.c vsftpd-2.0.1-convertable/main.c
--- vsftpd-2.0.1/main.c 2004-07-02 15:23:39.000000000 +0400
+++ vsftpd-2.0.1-convertable/main.c     2004-11-16 15:33:14.000000000 +0300
@@ -5,6 +5,10 @@
 * main.c
+#include <iconv.h>
+#include <string.h>
+#include <errno.h>
#include "session.h"
#include "utility.h"
#include "tunables.h"
@@ -31,6 +35,10 @@
static void session_init(struct vsf_session* p_sess);
static void env_init(void);
+#define INSIDE_CHARSET "UTF-8"
+#define OUTSIDE_CHARSET "CP1251"
+iconv_t cd_inside, cd_outside;
int
main(int argc, const char* argv[])
@@ -68,6 +76,12 @@
  /* Zero or one argument supported. If one argument is passed, it is the
   * path to the config file
+  cd_inside = iconv_open(INSIDE_CHARSET, OUTSIDE_CHARSET);
+  if (cd_inside == (iconv_t)(-1)) die(strerror(errno));
+  cd_outside = iconv_open(OUTSIDE_CHARSET, INSIDE_CHARSET);
+  if (cd_outside == (iconv_t)(-1)) die(strerror(errno));
  if (argc > 2)
    die("vsftpd: too many arguments (I take an optional config file only)");
diff -uNr vsftpd-2.0.1/str.c vsftpd-2.0.1-convertable/str.c
--- vsftpd-2.0.1/str.c  2004-07-02 15:25:43.000000000 +0400
+++ vsftpd-2.0.1-convertable/str.c      2004-11-16 15:56:33.000000000 +0300
@@ -660,3 +660,24 @@
+void
+str_iconv(struct mystr* p_str, int direction)
+  char tmp[MAX_ICONV_STRING+1], *to_buf, *from_buf;
+  size_t sz_from, sz_to, nconv;
+  from_buf = (char*)str_strdup(p_str);
+  to_buf = tmp;
+  sz_from = str_getlen(p_str)+1;
+  if (sz_from>MAX_ICONV_STRING) return;
+  sz_to = MAX_ICONV_STRING;
+  if (direction) {
+       nconv = iconv(cd_inside, &from_buf, &sz_from, &to_buf, &sz_to);
+       nconv = iconv(cd_inside, NULL, NULL, NULL, NULL);
+  } else {
+    nconv = iconv(cd_outside, &from_buf, &sz_from, &to_buf, &sz_to);
+  str_empty(p_str);
+  str_append_text(p_str, tmp);
diff -uNr vsftpd-2.0.1/str.h vsftpd-2.0.1-convertable/str.h
--- vsftpd-2.0.1/str.h  2004-06-04 20:35:00.000000000 +0400
+++ vsftpd-2.0.1-convertable/str.h      2004-11-16 15:52:48.000000000 +0300
@@ -1,12 +1,19 @@
#ifndef VSFTP_STR_H
#define VSFTP_STR_H
+#include <iconv.h>
+#include "sysstr.h"
+#define MAX_ICONV_STRING 2048
/* TODO - document these functions;-) */
#ifndef VSF_FILESIZE_H
#include "filesize.h"
#endif
+extern iconv_t cd_inside, cd_outside;
struct mystr
  char* PRIVATE_HANDS_OFF_p_buf;
@@ -120,5 +127,7 @@
int str_contains_line(const struct mystr* p_str,
                      const struct mystr* p_line_str);
+void str_iconv(struct mystr* p_str, int direction); //  direction: 1 - inside, 0 - outside
#endif /* VSFTP_STR_H */
diff -uNr vsftpd-2.0.1/strlist.c vsftpd-2.0.1-convertable/strlist.c
--- vsftpd-2.0.1/strlist.c      2004-07-02 15:25:48.000000000 +0400
+++ vsftpd-2.0.1-convertable/strlist.c  2004-11-16 15:39:25.000000000 +0300
@@ -92,6 +92,7 @@
  p_node = &p_list->p_nodes[p_list->list_len];
  p_node->str = s_null_str;
  p_node->sort_key_str = s_null_str;
+  str_iconv(p_str, 0);
  str_copy(&p_node->str, p_str);
  if (p_sort_key_str)
патч применяется как всегда:
cd vsftpd-2.0.1
patch -p1 < ../vsftpd-2.0.1-convertable.diff
[/code]
  • 3 months later...
я его немного проапгрейдил - в командной строке можно указывать внутреннюю, внешнюю кодировки, и порт, на котором слушать. плюс, видимо, вышел новый релиз под версией 2.0.1, и предыдущий патч на ней не срабатывал. новый патч:
diff -rc vsftpd-2.0.1/ftpcmdio.c vsftpd-2.0.1-convertable-r2/ftpcmdio.c
*** vsftpd-2.0.1/ftpcmdio.c     2004-07-02 15:23:02.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/ftpcmdio.c      2005-02-01 01:17:17.000000000 +0300
*** 200,205 ****
--- 200,206 ----
+   if (iconv_enabled) str_iconv(p_str, 1);
diff -rc vsftpd-2.0.1/ftpcmdio.h vsftpd-2.0.1-convertable-r2/ftpcmdio.h
*** vsftpd-2.0.1/ftpcmdio.h     2003-09-10 03:11:01.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/ftpcmdio.h      2005-02-01 01:17:00.000000000 +0300
*** 1,6 ****
--- 1,8 ----
 #ifndef VSF_FTPCMDIO_H
 #define VSF_FTPCMDIO_H
+ extern int iconv_enabled;
 struct mystr;
 struct vsf_session;
diff -rc vsftpd-2.0.1/main.c vsftpd-2.0.1-convertable-r2/main.c
*** vsftpd-2.0.1/main.c 2004-07-02 15:23:39.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/main.c  2005-02-01 01:33:46.000000000 +0300
*** 5,10 ****
--- 5,15 ----
  * main.c
+ #include <iconv.h>
+ #include <stdlib.h>
+ #include <string.h>
+ #include <errno.h>
*** 31,36 ****
--- 36,46 ----
+ #define INSIDE_CHARSET "UTF-8"
+ #define OUTSIDE_CHARSET "WINDOWS-1251"
+ iconv_t cd_inside, cd_outside;
+ int iconv_enabled=0;
 int
*** 68,82 ****
!   if (argc > 2)
!     die("vsftpd: too many arguments (I take an optional config file only)");
   else if (argc == 0)
     die("vsftpd: missing argv[0]");
!   if (argc == 2)
     if (!vsf_sysutil_strcmp(argv[1], "-v"))
--- 78,93 ----
!   if (argc > 5 || argc == 3)
!     die("vsftpd: incorrect arguments (usage: vsftpd /path/to/config [inside_charset outside_charset [listen_port]]");
   else if (argc == 0)
!   if (argc >= 2)
*** 85,90 ****
--- 96,112 ----
     p_config_name = argv[1];
     config_specified = 1;
+   if (argc >= 4) {
+       cd_inside = iconv_open(argv[2], argv[3]);
+       cd_outside = iconv_open(argv[3], argv[2]);
+       iconv_enabled = 1;
+   if (argc == 5) {
+     tunable_listen_port = atoi(argv[4]);
   /* This might need to open /dev/zero on systems lacking MAP_ANON. Needs
    * to be done early (i.e. before config file parse, which may use
    * anonymous pages
diff -rc vsftpd-2.0.1/str.c vsftpd-2.0.1-convertable-r2/str.c
*** vsftpd-2.0.1/str.c  2004-07-02 15:25:43.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/str.c   2005-02-01 01:09:16.000000000 +0300
*** 660,662 ****
--- 660,683 ----
+ void
+ str_iconv(struct mystr* p_str, int direction)
+   to_buf = tmp;
+   if (direction) {
+   } else {
+   str_empty(p_str);
diff -rc vsftpd-2.0.1/str.h vsftpd-2.0.1-convertable-r2/str.h
*** vsftpd-2.0.1/str.h  2004-06-04 20:35:00.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/str.h   2005-02-01 01:09:16.000000000 +0300
*** 1,12 ****
--- 1,19 ----
 #ifndef VSFTP_STR_H
 #define VSFTP_STR_H
+ #include "sysstr.h"
+ #define MAX_ICONV_STRING 2048
 #endif
+ extern iconv_t cd_inside, cd_outside;
 struct mystr
*** 120,124 ****
--- 127,133 ----
+ void str_iconv(struct mystr* p_str, int direction); //  direction: 1 - inside, 0 - outside
diff -rc vsftpd-2.0.1/strlist.c vsftpd-2.0.1-convertable-r2/strlist.c
*** vsftpd-2.0.1/strlist.c      2004-07-02 15:25:48.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/strlist.c       2005-02-01 01:21:12.000000000 +0300
*** 92,97 ****
--- 92,98 ----
+   if (iconv_enabled) str_iconv((struct mystr*)p_str, 0);
   if (p_sort_key_str)
diff -rc vsftpd-2.0.1/strlist.h vsftpd-2.0.1-convertable-r2/strlist.h
*** vsftpd-2.0.1/strlist.h      2002-07-14 22:27:03.000000000 +0400
--- vsftpd-2.0.1-convertable-r2/strlist.h       2005-02-01 01:17:58.000000000 +0300
*** 1,6 ****
--- 1,8 ----
 #ifndef VSF_STRLIST_H
 #define VSF_STRLIST_H
 /* Forward declarations */
 struct mystr;
 struct mystr_list_node;
запускать можно так:
# /usr/sbin/vsftpd /etc/vsftpd/vsftpd.conf UTF-8 WINDOWS-1251
# /usr/sbin/vsftpd /etc/vsftpd/vsftpd.conf UTF-8 UTF-8 2121
# /usr/sbin/vsftpd /etc/vsftpd/vsftpd.conf UTF-8 KOI8-R 2122
всё это конечно хорошо, но не у всех локально utf-8. лучше вынести это дело в конфиг. ну и конечно добится добавления патча на официальном уровне.
мой патч основан на iconv, так что можно перекодировать хоть из WINDOWS-1251 в CP866, UTF-8 я привел для примера. в конфиг выносить не хочу - хочется запускать несколько vsftpd с указанием одного конфига и разных кодировок и портов.
официально думаю не получится - решение не очень красивое, и с безопасностью теоретически могут возникнуть проблемы. у них для работы со строками только свои функции используются, а тут какая-то внешняя библиотека..
а как быть с другими версиями (у меня 1.2.2) ? ну и раз уже взялся делать патчи выкладывай их гденибудь. а то на форуме както несеръёзно.
с другими версиями - нет времени, тем более на предыдущие... +(
с патчем - подумаю, пока нет стабильного места, где выложить...
1.2.2 это не предидущая а стабильная ветка.
  • 8 months later...
