kriks Posted June 25, 2014 Posted June 25, 2014 Подскажите. Может кто сталкивался. rommon 2 >dir bootflash: File Size (Bytes) File Name --------------------------------------- 33363113 cat4500e-entservicesk9-mz.151-1.SG1.bin 24842288 cat4500e-entservices-mz.122-54.SG.bin Total space = 128282624 bytes, Available = 60153856 bytes Read back invalid SEEPROM-1 data : is the SEEPROM programmed? ********************************************************** * * * Welcome to Rom Monitor for WS-C4948E System * * Copyright © 2003-2011 by Cisco Systems, Inc. * * All rights reserved. * * * ********************************************************** Checking the partition table and boot sector... Checking FAT, Files and Directories... Reclaiming unused space... Updating FAT... Rom Monitor Program Version 12.2(44r)SG10 CPU Rev: 2.1, Board Rev: 4, Board Type: 104, CPLD Hobgoblin Rev: 20 Chassis: WS-C4948E Front Panel Phy is Bcm5482s Got Mac Address: 50:3s:e5:34:20:12 MAC Address : 50:3s:e5:34:20:12 IP Address : 172.16.1.5 Netmask : 255.255.255.0 Gateway : 172.16.1.1 TftpServer : 172.16.1.1 Peer supervisor not detected or is not running IOS Supervisor uplinks and all linecards have been reset Established physical link 100Mb Full Duplex Network layer connectivity may take a few seconds rommon 1 >? alias set and display aliases command boot boot up an external process clear clear configurations, use 'clear help' for more info confreg configuration register utility date displays the current date and time dev list the device table with physical device information dir list filesystem information help monitor builtin command help history monitor command history macstats print management port MAC statistics counters meminfo main memory information ping ping utility to determine network connectivity repeat repeat a monitor command reset system reset set show/set environment vars, use 'set help' for more info sprom serial eprom operations unalias unset an alias unset unset a monitor variable version display Rom Monitor version information rommon 2 >meminfo Main memory size: 512 MB. NVRAM size: 512KB rommon 3 >dev Devices in device table: Device id Name Size --------- ----- ------ mem: Main Memory ( SDRAM ) 536870912 nvram: Non Volatile RAM 524288 bootflash: Internal Flash Memory 134217728 (filesystem capable) rommon 4 >set PS1=rommon ! > Netmask=255.255.255.0 IpAddr=172.16.1.5 Broadcast=172.16.1.255 Gateway=172.16.1.1 RommonVer=12.2(44r)SG10 TftpServer=172.16.1.1 ConfigReg=0xc000 BootedFileName=bootflash:cat4500e-entservicesk9-mz.151-1.SG1.bin rommon 5 >boot Rommon reg: 0x00004380 Reset2Reg: 0x00009EFF ## Fortooine controller 0x0B5C65BC..0x0B72EB33 original size:0x001C685D ################## diagsk5 version 5.0.2.3 Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Irq9 Not active Error: FATAL ERROR: PCIE LINK FAILED Warning: PCIE Link Retried for 10 times UNHANDLED ROMMON EXCEPTION at PC=04838180 Vector=00000100 MSR=02029230 LR=04838174 MCSR=00000000 CISR0=00000000 CISR1=00800000 DDR_ERR_DETECT=00000000 Все. на этом пестня заканчивается. Как быть? что делать? Может она окерпичилась совсем? Вставить ник Quote
dIMbI4 Posted June 25, 2014 Posted June 25, 2014 походу ее нужно вывозить на ближайший корпоратив и кидать всем коллективом кто дальше) Вставить ник Quote
kriks Posted June 25, 2014 Author Posted June 25, 2014 Да вот я тоже так думаю. Ибо что только не делал. Не хочет грузиться :( Вставить ник Quote
dIMbI4 Posted June 25, 2014 Posted June 25, 2014 ну я думаю что вы в здравом уме и в продакшн ее ставить не собираетесь в принципе, не так ли? Вставить ник Quote
kriks Posted June 25, 2014 Author Posted June 25, 2014 Да нет конечно. Придется над ней повеселится. Конечно очень обидно что померла, а так она нужна. Вставить ник Quote
yazero Posted August 26, 2016 Posted August 26, 2016 (edited) при загрузке пишет Peer supervisor not detected or is not running IOS Supervisor uplinks and all linecards have been reset ----- не подскажите что это означает ? (здесь был http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_23834.html) сhecking the partition table and boot sector... Checking FAT, Files and Directories... Reclaiming unused space... Updating FAT... Primary Rom Monitor Version 12.2(44r)SG11 CPU Rev: 2.1, Board Rev: 4, Board Type: 104, CPLD Hobgoblin Rev: 21 Chassis: WS-C4948E Front Panel Phy is Bcm5482s Got Mac Address: 50:3d:e5:5a:7b:3f MAC Address : 50-3d-e5-5a-7b-3f IP Address : 192.168.168.1 Netmask : 255.255.255.0 Gateway : Not set. TftpServer : 192.168.168.2 Peer supervisor not detected or is not running IOS Supervisor uplinks and all linecards have been reset The system will autoboot in 5 seconds *** prod: WS-C4948E part: 73-12488-06 serial: CAT1452S0CP Power-on-self-test for Module 1: WS-C4948E CPU Subsystem Tests ... seeprom: Pass Traffic: L3 Looopback ... Test Results: Pass Traffic: L2 Loopback ... Test Results: Pass Switching Subsystem Memory ... Packet Memory Test Results: Pass Module 1 Passed Switch#sh module Chassis Type : WS-C4948E Power consumed by backplane : 0 Watts Mod Ports Card Type Model Serial No. ---+-----+--------------------------------------+------------------+----------- 1 52 4948E 10/100/1000 (RJ45) 10GE (SFP+) WS-C4948E CAT1452S0CP M MAC addresses Hw Fw Sw Status --+--------------------------------+---+------------+----------------+--------- 1 503d.e55a.7b00 to 503d.e55a.7b33 1.2 12.2(44r)SG1 15.2(1)E1 Ok Switch#sh idprom all Supervisor 1 Idprom : Common Block Signature = 0xABAB Common Block Version = 3 Common Block Length = 144 Common Block Checksum = 3805 Idprom Size = 256 Block Count = 4 FRU Major Type = 0x4101 FRU Minor Type = 392 OEM String = Cisco Product Number = WS-C4948E Serial Number = CAT1452S0CP Part Number = 73-12488-06 Part Revision = A0 Manufacturing Deviation String = 0 Hardware Revision = 1.2 Top Assembly Number = 68-3524-05 Top Assembly Revision Number = A0 Power Consumption = 0 RMA Failure Code = 0 0 0 0 Supervisor Block Signature = 0x4101 Supervisor Block Version = 1 Supervisor Block Length = 24 Supervisor Block Checksum = 738 Feature Bits = 0x0000000000000000 Card Feature Index = 0 MAC Base = 503d.e55a.7b00 MAC Count = 64 Clei Block Signature = 0x4601 Clei Block Version = 2 Clei Block Length = 26 Clei Block Checksum = 1203 Clei code string = CMMCA00ARB Version ID string = V03 Clei ECI Number = 462062 SecSerialNum Block Signature = 0x4602 SecSerialNum Block Version = 1 SecSerialNum Block Length = 26 SecSerialNum Block Checksum = 790 SecSerialNum string = CAT1452L0CP Power Supply 1 Idprom : Common Block Signature = 0xABAB Common Block Version = 2 Common Block Length = 124 Common Block Checksum = 3581 Idprom Size = 128 Block Count = 1 FRU Major Type = 0x4501 FRU Minor Type = 16 OEM String = Cisco Product Number = PWR-C49E-300AC-R Serial Number = QCS1614U0Z8 Part Number = 341-0411-01 Part Revision = A0 Manufacturing Deviation String = Hardware Revision = 1.1 Power Consumption = 300 RMA Failure Code = 0 0 0 0 Edited August 26, 2016 by yazero Вставить ник Quote
mikezzzz Posted August 26, 2016 Posted August 26, 2016 вас смущает Peer supervisor not detected or is not running IOS Supervisor uplinks and all linecards have been reset ? подозреваю, это проверка на VSS Вставить ник Quote
alexpn Posted August 27, 2016 Posted August 27, 2016 Может флешку форматнуть и опять перезалить IOS Такое ощущение что бЭды там или IOS битый Вставить ник Quote
yazero Posted August 29, 2016 Posted August 29, 2016 (edited) 2mikezzzz 1)да именно это. тоесть cisco ищет соседа, но VSS не настроен. 2) думал что ищет slavebootflash, но на cisco нет slave Switch#dir ? /all List all files /recursive List files recursively all-filesystems List files on all filesystems bootflash: Directory or file name cat4000_flash: Directory or file name cns: Directory or file name crashinfo: Directory or file name null: Directory or file name nvram: Directory or file name profiler: Directory or file name system: Directory or file name tar: Directory or file name tmpsys: Directory or file name 3) запускал diagnostic ondaemon , start , вроде все ок. Edited August 29, 2016 by yazero Вставить ник Quote
