Решил переделать этот скрипт на три канала.
:local pingcount 3
:local checkip 212.122.1.2
:local ipA 192.168.2.3
:local GatewayA 192.168.2.1
:local ipB 172.16.2.5
:local GatewayB 172.16.2.4
ip route add gateway=$GatewayA dst-address=$checkip comment="check"
:local pingresultA [/ping $checkip src-address=$ipA count=$pingcount]
ip route remove [find comment=check]
ip route add gateway=$GatewayB dst-address=$checkip comment="check"
:local pingresultB [/ping $checkip src-address=$ipB count=$pingcount]
:if (($pingresultA=pingcount) && ($pingresultB=pingcount)) do={ip route set [find comment=Default Gateway] gateway=192.168.2.1,172.16.2.4}
:if (($pingresultA=pingcount) && ($pingresultB=0)) do={ip route set [find comment=Default Gateway] gateway=$pingresultA}
:if (($pingresultA=0) && ($pingresultB=pingcount)) do={ip route set [find comment=Default Gateway] gateway=$pingresultB}
Вот что получилось (не работает)
:local pingcount 3
:local hostping ya.ru
:local ipA 192.168.10.4
:local GatewayA 192.168.10.1
:local ipB 192.168.20.4
:local GatewayB 192.168.20.1
:local ipC 195.238.100.86
:local GatewayC 195.238.100.85
ip route add gateway=$GatewayA dst-address=$hostping comment="check"
:local pingresultA [/ping $hostping src-address=$ipA count=$pingcount]
ip route add gateway=$GatewayB dst-address=$hostping comment="check"
:local pingresultB [/ping $hostping src-address=$ipB count=$pingcount]
ip route add gateway=$GatewayC dst-address=$hostping comment="check"
:local pingresultC [/ping $hostping src-address=$ipC count=$pingcount]
:if (($pingresultA=pingcount)&&($pingresultB=pingcount)&&(pingresultC=pingcount)) do={ip route set [find comment=Default Gateway]gateway=192.168.10.1,192.168.20.1,195.238.100.85}
:if (($pingresultA=pingcount)&&($pingresultB=0)&&(pingresultC=pingcount)) do={ip route set [find comment=Default Gateway] gateway=192.168.10.1,195.238.100.85}
:if (($pingresultA=0)&&($pingresultB=pingcount)&&(pingresultC=pingcount)) do={ip route set [find comment=Default Gateway] gateway=192.168.20.1,195.238.100.85}
:if (($pingresultA=pingcount)&&($pingresultB=pingcount)&&(pingresultC=0)) do={ip route set [find comment=Default Gateway]gateway=192.168.10.1,192.168.20.1}
:if (($pingresultA=0)&&($pingresultB=0)&&(pingresultC=pingcount)) do={ip route set [find comment=Default Gateway] gateway=$195.238.100.85}
:if (($pingresultA=0)&&($pingresultB=pingcount)&&(pingresultC=0)) do={ip route set [find comment=Default Gateway] gateway=$192.168.20.1}
:if (($pingresultA=pingcount)&&($pingresultB=0)&&(pingresultC=0)) do={ip route set [find comment=Default Gateway] gateway=$192.168.10.1}
Edited by lk108
