На клиенты не "видят" точку доступа
Проблема следующего характера.
Имеется несколько точек wifi построенных на базе RB951Ui и RB951G.
На первой точке WiFi настроен так:
[root@wifi] > /interface wireless print advanced
Flags: X - disabled, R - running
0  R name="wlan0" mtu=1500 mac-address=D4:CA:6D:A5:9E:FA arp=enabled
     disable-running-check=no interface-type=Atheros AR9300
     radio-name="D4CA6DDCF611" mode=ap-bridge ssid="WiFi" area=""
     frequency-mode=superchannel country=no_country_set antenna-gain=3
     frequency=2437 band=2ghz-b/g/n channel-width=20/40mhz-ht-above
     scan-list=default wireless-protocol=802.11 rate-set=default
     supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
     supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
                   54Mbps
     basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
     distance=indoors tx-power=18 tx-power-mode=all-rates-fixed
     noise-floor-threshold=default nv2-noise-floor-offset=default
     periodic-calibration=enabled periodic-calibration-interval=60
     dfs-mode=no-radar-detect wds-mode=disabled wds-default-bridge=none
     wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
     update-stats-interval=disabled bridge-mode=enabled
     default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
     default-client-tx-limit=0 proprietary-extensions=post-2.9.25
     wmm-support=enabled hide-ssid=no security-profile=local
     disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
     compression=no allow-sharedkey=no
     station-bridge-clone-mac=00:00:00:00:00:00
     ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=long
     ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,
                mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
                mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
     ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
     ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
     ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
     nv2-qos=default nv2-cell-radius=30 nv2-security=disabled
     nv2-preshared-key="" hw-retries=7 frame-lifetime=0
     adaptive-noise-immunity=ap-and-client-mode
     hw-fragmentation-threshold=disabled hw-protection-mode=rts-cts
     hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced
     multicast-helper=default multicast-buffering=enabled
1  R name="wlan1" mtu=1500 mac-address=D4:CA:6D:A5:9E:FB arp=enabled
     disable-running-check=no interface-type=virtual-AP
     master-interface=wlan0 ssid="wifi_public" area=""
     max-station-count=2007 wds-mode=disabled wds-default-bridge=none
     wds-default-cost=0 wds-cost-range=0 wds-ignore-ssid=no
     wmm-support=enabled hide-ssid=no security-profile=default
[root@wifi] >
И второй маршрутизатор:
[root@gw] > /interface wireless print advanced
0  R name="wlan0:wifi:public" mtu=1500 mac-address=D4:CA:6D:92:A3:09
     arp=enabled disable-running-check=no interface-type=Atheros AR9300
     radio-name="WiFi" mode=ap-bridge ssid="WiFi" area=""
     frequency=2412 band=2ghz-b/g/n channel-width=20/40mhz-ht-above
                   54Mbps
     distance=indoors tx-power=14 tx-power-mode=all-rates-fixed
     periodic-calibration=enabled periodic-calibration-interval=30
     dfs-mode=none wds-mode=disabled wds-default-bridge=none
     disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short
     nv2-preshared-key="" hw-retries=7 frame-lifetime=2
[root@gw] >
Суть сводится к тому, что некоторые клиенты (телефоны\планшеты) подключаются и работают без проблем, но есть несколько клиентов которые периодически "теряют" точку из виду.
Т.е. банально пропадает из списка доступнух сетей для подключения.
Причем на другие точки подключатсья удается без проблем.
В логах на маршрутизаторах в момент подключения этих проблемных клиентов ничего не отображается. Как будто они и вовсе не пытались подключиться.
Кто подскажет в какую сторону стоит смотреть?
Edited by Danila
Danila, это не девайсы от погрызанного яблока?
В первом случае именно они.
Во втором телефон Sony Xperia какой то там на 4-ом андройде.
Danila, про огрызки тут где то есть тема, там есть решения проблемы.
С соней нужно эксперементировать.
Я, видимо, не правильно спрашивал.
Какие нибудь ключевые слова можете подсказать?
