настраиваю на mikrotik ccr1036 ospf он не хочет раздавать его в туннель gre-tunnel10 а упорно раздает его в ether2
> export compact
# apr/17/2014 11:41:26 by RouterOS 6.12
# software id = J46A-68XZ
/interface gre
add local-address=1.1.1.5 name=gre-tunnel10 remote-address=2.2.2.2
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
   mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=3des
/port
set 0 name=serial0
set 1 name=serial1
/routing ospf area
set [ find default=yes ] disabled=yes
/routing ospf instance
set [ find default=yes ] disabled=yes redistribute-connected=as-type-2 \
   router-id=10.0.90.25
add disabled=yes name=ospf1 router-id=172.16.0.17
/routing ospf area
add area-id=0.0.0.10 instance=ospf1 name=area1
/ip address
add address=1.1.1.5/24 comment="default configuration" interface=ether1 \
   network=1.1.1.0
add address=172.16.0.17/16 interface=ether2 network=172.16.0.0
add address=10.0.90.25/30 interface=gre-tunnel10 network=10.0.90.24
/ip dns
set servers=172.16.0.5
/ip firewall filter
add action=drop chain=input comment=drop_all disabled=yes in-interface=ether1 \
   protocol=tcp
add action=drop chain=input disabled=yes in-interface=ether1 protocol=udp
add chain=output comment=out protocol=udp
add chain=output protocol=tcp
add chain=input comment="Allow IPSec-esp" protocol=ipsec-esp
add chain=input comment="Allow IKE" dst-port=500 protocol=udp
add chain=input comment="Allow IPSec-ah" protocol=ipsec-ah
add chain=input comment=icp_input protocol=icmp
add chain=input comment=ssh dst-port=22 protocol=tcp
add chain=input comment=www dst-port=80 protocol=tcp
add chain=input dst-port=443 protocol=tcp
add chain=input comment="access to winbox" dst-port=8291 in-interface=ether1 \
   protocol=tcp
add chain=input dst-port=8291 in-interface=ether2 protocol=tcp
add chain=input connection-state=new dst-port=8291,65522 protocol=tcp
add chain=input comment=dns dst-port=53 in-interface=all-ethernet protocol=\
   udp
add chain=input dst-port=53 in-interface=all-ethernet protocol=tcp
add chain=input connection-state=established
add chain=input connection-state=related
add chain=input dst-port=1723 protocol=tcp
add chain=input dst-port=22 protocol=tcp
add action=add-src-to-address-list address-list=ssh_blacklist \
   address-list-timeout=3h chain=input connection-state=new dst-port=22 \
   protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
   address-list-timeout=1m chain=input connection-state=new dst-port=22 \
   protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
   protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
   protocol=tcp
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 \
   protocol=tcp src-address-list=ftp_blacklist
add chain=output content="530 Login incorrect" dst-limit=\
   1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist \
   address-list-timeout=1h chain=output content="530 Login incorrect" \
   protocol=tcp
/ip ipsec peer
add address=2.2.2.2/32 enc-algorithm=3des hash-algorithm=md5 secret=\
   "pass"
/ip route
add distance=1 gateway=91.216.48.1
add distance=1 dst-address=10.0.90.26/32 gateway=gre-tunnel10
/ip upnp
set allow-disable-external-interface=no
/lcd interface
set sfp-sfpplus1 interface=sfp-sfpplus1
set sfp-sfpplus2 interface=sfp-sfpplus2
set ether1 interface=ether1
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
/routing ospf interface
add cost=700 interface=gre-tunnel10 network-type=broadcast priority=0
/routing ospf network
add area=area1 network=172.16.0.0/16
/system clock
set time-zone-name=Europe/Moscow
/system leds
set 0 type=interface-speed
set 2 type=interface-speed
/system ntp client
set enabled=yes mode=unicast primary-ntp=194.149.67.129 secondary-ntp=\
а с херов бы он раздавался на GRE?
в routing ospf interfaces указываются лишь параметры оспф соединения, такие как стоимость, шифрования, таймеры... не более.
смежный интерфейс где запускается оспф задается именно в network.
в нетверк указана подсеть 172.16.0.0/16 которая присвоена ether2 вот там оно и будет искать соседей. все логично. на GRE у вас указана совсем другая подсеть и оспф никак там не запустится.
Edited by myst
а ка мне тогда сделать что бы сеть 172.16.0.0/16 анансировалась gre-tunnel10?
Стереть все что касается OSPF в вашем конфиге и ввести команду:
add area=backbone network=0.0.0.0/0
И все заработает без проблем.
Для начала не слушай сааба. Самое дибильное что можно сделать это
включить ББ на всех интерфейсах.
Тебе надо чтоб маршрутная информация о сети 172.16/16 уходила соседу за GRE туннелем?
да ospf должен работать на gre тенелях
сделал как вы сказали но саршруты не появились
на другой стороне стоит cisco 1841
вот ее настройки ospf
interface Tunnel10
bandwidth 30
ip address 10.0.90.26 255.255.255.252
ip virtual-reassembly in
ip route-cache policy
ip tcp adjust-mss 1024
ip ospf cost 700
ip ospf 100 area 10
tunnel source 2.2.2.2
tunnel mode ipsec ipv4
tunnel destination 1.1.1.5
tunnel protection ipsec profile prof_tun
router ospf 100
router-id 192.168.0.253
network 10.0.4.0 0.0.0.255 area 10
network 192.168.0.0 0.0.0.255 area 10
если смотреть на cisco
show ip route ospf
то маршрута на 172.16.0.0/16 через интерфейс Tunnel10 нету
interface Tunnel10
bandwidth 30
ip ospf cost 700
ip ospf 100 area 10
router ospf 100
show ip route ospf
sh ip ospf nei
и от этого уже плясать
ip ospf nei
10.0.8.2          0   FULL/  -        00:00:39    10.0.70.25      Tunnel1
не видит mikrotik
Так онож потушено
или я что-то в конфиге пропустил?
вроде все включино
export compact
# apr/18/2014 11:06:21 by RouterOS 6.12
/interface gre
/ip ipsec proposal
/port
set 0 name=serial0
set 1 name=serial1
set [ find default=yes ] redistribute-connected=as-type-2 router-id=\
   10.0.90.25
/ip address
   network=1.1.1.0
/ip dns
/ip firewall filter
   protocol=tcp
   protocol=tcp
   udp
   protocol=tcp
   protocol=tcp
/ip ipsec peer
add address=83.167.101.203/32 enc-algorithm=3des hash-algorithm=md5 secret=\
   "pass"
/ip route
/ip upnp
/lcd interface
add area=backbone
/system clock
/system leds
/system ntp client
   172.16.0.5
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR
Ой давай без портянок?
покажи вывод c микротика
1) routing ospf area print detail
2) routing ospf network print detail
3) routing ospf instance print detail
4) routing ospf interface print detail
и
кусок конфига касающийся оспф на циске, в том числе таймеры на туннельном интерфейсе.
Flags: X - disabled, I - invalid, * - default
0  * name="backbone" instance=default type=default area-id=0.0.0.0
0   network=0.0.0.0/0 area=backbone
Flags: X - disabled, * - default
0  * name="default" router-id=10.0.90.25 distribute-default=never redistribute-connected=as-type-2 redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no metric-default=1 metric-connected=20 metric-static=20
     metric-rip=20 metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in out-filter=ospf-out
Flags: X - disabled, I - inactive, D - dynamic, P - passive
0 D  interface=ether1 cost=10 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
1 D  interface=ether2 cost=10 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
2 D  interface=gre-tunnel10 cost=10 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=point-to-point instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
Вот это что за наркомания?
Ясен хрен что оно пытается запуститься на ВСЕХ интерфейсах. Оно тебе правда надо?
Как я уже говорил в разделе network описываются смежные подсети.
0  * name="area 10" instance=default type=default area-id=0.0.0.0
0   network=10.0.90.0/24 area=area 10
0    interface=gre-tunnel10 cost=700 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
на cisco sh ip ospf int
Tunnel10 is up, line protocol is up
 Internet Address 10.0.90.26/30, Area 10
 Process ID 100, Router ID 192.168.0.253, Network Type POINT_TO_POINT, Cost: 700
 Topology-MTID    Cost    Disabled    Shutdown      Topology Name
       0           700       no          no            Base
 Enabled by interface config, including secondary ip addresses
 Transmit Delay is 1 sec, State POINT_TO_POINT
 Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
   oob-resync timeout 40
   Hello due in 00:00:04
 Supports Link-local Signaling (LLS)
 Cisco NSF helper support enabled
 IETF NSF helper support enabled
 Index 5/5, flood queue length 0
 Next 0x0(0)/0x0(0)
 Last flood scan length is 0, maximum is 0
 Last flood scan time is 0 msec, maximum is 0 msec
 Neighbor Count is 0, Adjacent neighbor count is 0
 Suppress hello for 0 neighbor(s)
FastEthernet0/1 is up, line protocol is up
 Internet Address 192.168.0.253/24, Area 10
 Process ID 100, Router ID 192.168.0.253, Network Type BROADCAST, Cost: 1
       0           1         no          no            Base
 Transmit Delay is 1 sec, State DR, Priority 1
 Designated Router (ID) 192.168.0.253, Interface address 192.168.0.253
 No backup designated router on this network
   Hello due in 00:00:03
 Index 4/4, flood queue length 0
 Next 0x0(0)/0x0(0)
Tunnel13 is up, line protocol is down
 Internet Address 10.0.85.25/30, Area 10
 Process ID 100, Router ID 192.168.0.253, Network Type POINT_TO_POINT, Cost: 200
       0           200       no          no            Base
 Transmit Delay is 1 sec, State DOWN
Tunnel4 is up, line protocol is up
 Internet Address 10.0.75.26/30, Area 10
 Process ID 100, Router ID 192.168.0.253, Network Type POINT_TO_POINT, Cost: 100
       0           100       no          no            Base
 Index 2/2, flood queue length 0
 Next 0x0(0)/0x0(0)
 Last flood scan length is 1, maximum is 1
 Last flood scan time is 0 msec, maximum is 4 msec
 Neighbor Count is 1, Adjacent neighbor count is 1
   Adjacent with neighbor 172.16.0.20
Tunnel1 is up, line protocol is up
 Internet Address 10.0.70.26/30, Area 10
       0           100       no          no            Base
   Hello due in 00:00:07
 Index 1/1, flood queue length 0
 Next 0x0(0)/0x0(0)
 Last flood scan length is 1, maximum is 4
 Last flood scan time is 0 msec, maximum is 16 msec
   Adjacent with neighbor 10.0.8.2
настройки ospf на cisco
router ospf 100
interface Tunnel10
bandwidth 30
ip mtu 1476
ip ospf cost 700
ip ospf 100 area 10
спасибо вроде все заработало
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.0.90.25        0   FULL/  -        00:00:37    10.0.90.25      Tunnel10
172.16.0.20       0   FULL/  -        00:00:38    10.0.75.25      Tunnel4
10.0.8.2          0   FULL/  -        00:00:38    10.0.70.25      Tunnel1
Edited by svetogor82
  • 1 month later...
снова проблемма возникла стал эту схему внедрять так у меня ospf не видит маршруты
1 X  name="area10_ospf" instance=default type=default area-id=0.0.0.10
0 X network=10.0.91.0/30 area=backbone
1   network=10.0.8.0/24 area=backbone
2 X network=10.0.98.0/30 area=backbone
3   network=10.0.94.0/30 area=backbone
4   network=10.0.9.0/24 area=backbone
0  * name="default" router-id=10.0.94.1 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
0 X  interface=kdms_to_dm cost=100 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
1 X  interface=lan_port8 cost=300 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
2 X  interface=avk_to_msk cost=200 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
3    interface=msk_kdms cost=100 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
4 D  interface=lan_port8 cost=10 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
5 D  interface=lan_port8 cost=10 priority=1 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s use-bfd=no
на cisco
interface Tunnel24
description ostovtsi_to_mikrotik
ip address 10.0.94.2 255.255.255.248
ip ospf cost 100
ip ospf 100 area 0
tunnel source 83.167.x.x
tunnel destination 109.206.x.x
router ospf 100
network 10.0.4.0 0.0.0.255 area 0
network 192.168.0.0 0.0.0.255 area 0
смотрю на cisco
show ip ospf neighbor
10.0.94.1         0   INIT/  -        00:00:38    10.0.94.1       Tunnel24
show ip route ospf и маршрутов нету
разобрался по чему весел статус INIT сейчас все нормально должно быть
10.0.94.1         0   FULL/  -        00:00:32    10.0.94.1       Tunnel24
но маршрцты так и не появляются
