Здравствуйте.
Существует VOIP телефония, шлюзом выступает ADDPAC GS1004, на него идет 2 городских линии + 3 симкарты. Работает транк на elastix.
Конфигурация AddPac'а:
! APOS(tm) configuration saved from vty
!  2014/04/15 08:59:59
version 8.51.007
hostname GS1004
username root password router administrator
script ntpdate default
server ip 3.ru.pool.ntp.org
server ip 1.ru.pool.ntp.org
interface Loopback0
ip address 127.0.0.1 255.0.0.0
interface FastEthernet0/0
ip address 192.168.110.125 255.255.255.0
speed auto
no qos-control
ftp server
http server
logging command
logging event 4-warning
logging on
! VoIP configuration.
! Voice service voip configuration.
voice service voip
protocol sip
dtmf-relay out-of-band
fax protocol t38 redundancy 0
fax rate 9600
h323 call start fast
h323 call tunnel enable
no local-ringback-tone
no call-barring unconfigured-ip-address
no voip-inbound-call-barring enable
! Voice port configuration.
! FXO
voice-port 0/0
connection plar 12345
caller-id enable
caller-id name disable
! FXO
voice-port 0/1
caller-id enable
! FXO
voice-port 0/2
caller-id enable
! FXO
voice-port 0/3
no caller-id enable
! GSM
voice-port 1/0
no caller-id enable
! GSM
voice-port 1/1
caller-id enable
! GSM
voice-port 1/2
caller-id enable
! GSM
voice-port 1/3
caller-id enable
! service port group configuration.
! Pots peer configuration.
dial-peer voice 2 pots
destination-pattern 4T
port 1/1
user-name мобильный номер
user-password password
translate-outgoing called-number 4
dial-peer voice 3 pots
destination-pattern 3T
port 1/2
translate-outgoing called-number 3
dial-peer voice 4 pots
destination-pattern 2T
port 1/3
translate-outgoing called-number 2
dial-peer voice 5 pots
destination-pattern T
port 0/0
user-name 12345
translate-outgoing called-number 1
! Voip peer configuration.
dial-peer voice 1 voip
session target sip-server
session protocol sip
codec g711alaw
vad
dtmf-relay dual-mode
dial-peer call-hold h
dial-peer call-transfer h
gatekeeper
! Gateway configuration.
gateway
h323-id voip.192.168.110.125
no ignore-msg-from-other-gk
! Codec classes configuration.
voice class codec 0
! Translation Rule configuration.
translation-rule 1
rule 1      T                        T
translation-rule 2
rule 2      2T                       T
translation-rule 3
rule 3      3T                       T
translation-rule 4
rule 4      4T                       T
! SIP UA configuration.
sip-ua
user-register
sip-server 192.168.110.220
call-transfer-mode attended
remote-party-id
register e164
! Tones
! SMTP sendmail configuration
sms-delivery
line console
line vty
gsm dev-restart-by-unreg 300
gsm 1/0
sms-language utf8
gsm 1/1
sim pin 6016
sms-language utf8
gsm 1/2
sim pin 0000
sms-language utf8
gsm 1/3
sim pin 0270
sms-language utf8
Все звонки sip-телефонии перенаправляются нормально с телефона на AddPac на городскую и мобильную линии, при входящих звонках на мобильные номера перенаправляется на Elastix. А вот на городской если звонят, перенаправляются номера только мобильных операторов. Все звонки с городского номера на наш городской номер остаются на ADDPAC'е. Что не так делаю?
Лог звонков AddPac:
142> Apr 15 11:02:28   outgoing              12345              12345 sip:12345@192.168.:192.168.110.220  Apr 15 11:01:41    47 Remote:CallClear
<   141> Apr 15 10:49:16   outgoing              12345              12345 sip:12345@192.168.:192.168.110.220  Apr 15 10:46:15   181 Remote:CallClear
<   140> Apr 15 10:37:01  incomming              12345              54321              12345:192.168.110.220  Apr 15 10:36:02    59 Remote:CallClear
<   139> Apr 15 10:24:25  incomming              12345              54374              12345:192.168.110.220  Apr 15 10:23:45    40 Remote:CallClear
<   138> Apr 15 10:21:50   outgoing              12345              12345 sip:12345@192.168.:192.168.110.220  Apr 15 10:20:47    63 Remote:CallClear
<   137> Apr 14 20:17:04   outgoing              12345              12345 sip:12345@192.168.:192.168.110.220  Apr 14 20:16:55     9 Remote:CallClear
<   136> Apr 14 19:03:21  incomming              12345              54321              12345:192.168.110.220                      0 Remote:CallClear
<   135> Apr 14 18:11:35  incomming              12345              54321              12345:192.168.110.220  Apr 14 18:08:59   156 Remote:CallClear
