Добрый день, подскажите пожалуйста по accel'у.
Начались проблемы с upspeed.
Пример:
тариф 10мб, по радиусу атрибуты передаются. Downspeed как и должно быть 10мб, а вот Upspeed 1мб. Если же убираю ограничения и не передаю атрибуты то Upspeed поднимается максимально как и Downspeed.
accel-ppp.conf
[modules]
#path=/usr/local/lib/accel-ppp
log_file
#log_tcp
#log_pgsql
pptp
pppoe
#l2tp
auth_mschap_v2
auth_mschap_v1
auth_chap_md5
auth_pap
radius
ippool
sigchld
pppd_compat
shaper_tbf
#chap-secrets
[core]
log-error=/var/log/accel-ppp/core.log
thread-count=23
[ppp]
verbose=1
min-mtu=1000
mtu=1400
mru=1400
ccp=0
#sid-case=upper
#check-ip=0
#single-session=replace
#mppe=require
[lcp]
echo-interval=30
echo-failure=3
[pptp]
#echo-interval=30
verbose=1
[pppoe]
interface=eth0.101
interface=eth0.136
interface=eth0.151
interface=eth0.152
interface=eth0.153
interface=eth0.154
interface=eth0.155
interface=eth0.156
interface=eth0.157
interface=eth0.159
interface=eth0.93
interface=eth0.999
#ac-name=xxx
#service-name=yyy
#pado-delay=0
#pado-delay=0,100:100,200:200,-1:500
#ifname-in-sid=called-sid
verbose=1
echo-interval=30
[l2tp]
#dictionary=/usr/local/share/accel-ppp/l2tp/dictionary
#hello-interval=60
#timeout=60
#rtimeout=5
#retransmit=5
#host-name=accel-ppp
verbose=1
[dns]
dns1=8.8.8.8
dns2=8.8.4.4
[radius]
dictionary=/usr/local/share/accel-ppp/radius/dictionary
nas-identifier=VPN
nas-ip-address=192.168.0.1
gw-ip-address=172.16.0.1
auth-server=192.168.0.2:1812,xxxxxx
acct-server=192.168.0.2:1813,xxxxxx
dae-server=192.168.0.1:3799,xxxxxx
dm_coa_secret=xxxxxx
verbose=1
#timeout=3
#max-try=3
acct-timeout=0
[client-ip-range]
192.168.0.0/16
10.10.0.0/16
10.253.253.0/24
10.17.139.0/24
[ip-pool]
172.16.0.2-254
172.16.1.2-254
172.16.2.2-254
172.16.3.2-254
172.16.4.2-254
[log]
log-file=/var/log/accel-ppp/accel-ppp.log
log-emerg=/var/log/accel-ppp/emerg.log
log-fail-file=/var/log/accel-ppp/auth-fail.log
#log-debug=/dev/stdout
#log-tcp=127.0.0.1:3000
copy=1
#color=1
#per-user-dir=per_user
#per-session-dir=per_session
#per-session=1
level=3
[log-pgsql]
conninfo=user=log
log-table=log
[pppd-compat]
#ip-pre-up=/etc/ppp/ip-pre-up
#ip-up=/etc/ppp/ip-up
#ip-down=/etc/ppp/ip-down
#ip-change=/etc/ppp/ip-change
radattr-prefix=/var/run/radattr
verbose=1
[chap-secrets]
gw-ip-address=192.168.100.1
#chap-secrets=/etc/ppp/chap-secrets
[tbf]
#attr=Filter-Id
#down-burst-factor=0.1
#up-burst-factor=1.0
#latency=50z
#attr-down=PPPD-Downstream-Speed
#attr-up=PPPD-Upstream-Speed
attr-down=PPPD-Downstream-Speed-Limit
attr-up=PPPD-Upstream-Speed-Limit
[cli]
telnet=127.0.0.1:2000
tcp=127.0.0.1:2001
#password=123
Вырезка из ip-up:
if [ -f /var/run/radattr.$1 ]
then
DOWNSPEED=`/usr/bin/awk '/PPPD-Downstream-Speed-Limit/ {print $2}' /var/run/radattr.$1`
UPSPEED=`/usr/bin/awk '/PPPD-Upstream-Speed-Limit/ {print $2}' /var/run/radattr.$1`
FILTERS=`/usr/bin/awk '/Filter-Id/ {print $2}' /var/run/radattr.$1`
#echo $DOWNSPEED
#echo $UPSPEED
#echo $FILTERS
/usr/sbin/tc qdisc del dev $1 root > /dev/null
/usr/sbin/tc qdisc del dev $1 ingress > /dev/null
##### speed server->client
if [ "$UPSPEED" != "0" ] ;
then
/usr/sbin/tc qdisc add dev $1 root handle 1: htb default 20 r2q 1
/usr/sbin/tc class add dev $1 parent 1: classid 1:1 htb rate ${UPSPEED}kbit burst 4k
/usr/sbin/tc class add dev $1 parent 1:1 classid 1:10 htb rate ${UPSPEED}kbit burst 4k prio 1
/usr/sbin/tc class add dev $1 parent 1:1 classid 1:20 htb rate ${UPSPEED}kbit burst 4k prio 2
/usr/sbin/tc qdisc add dev $1 parent 1:10 handle 10: sfq perturb 10 quantum 1400
/usr/sbin/tc qdisc add dev $1 parent 1:20 handle 20: sfq perturb 10 quantum 1400
/usr/sbin/tc filter add dev $1 parent 1:0 protocol ip prio 10 u32 match ip tos 0x10 0xff flowid 1:10
/usr/sbin/tc filter add dev $1 parent 1:0 protocol ip prio 10 u32 match ip protocol 1 0xff flowid 1:10
/usr/sbin/tc filter add dev $1 parent 1: protocol ip prio 10 u32 match ip protocol 6 0xff match u8 0x05 0x0f at 0 match u16 0x0000 0xffc0 at 2 match u8 0x10 0xff at 33 flowid 1:10
fi
##### speed client->server
if [ "$DOWNSPEED" != "0" ] ;
then
/usr/sbin/tc qdisc add dev $1 handle ffff: ingress
/usr/sbin/tc filter add dev $1 parent ffff: protocol ip prio 50 u32 match ip src 0.0.0.0/0 police rate ${DOWNSPEED}kbit burst 12k drop flowid :1
fi
/var/log/messages :
2014-04-14T12:16:04.346615+04:00 linux-f2js ip-up: TC HTB version 3.3
2014-04-14T12:16:04.346895+04:00 linux-f2js ip-up: Illegal "rate"
2014-04-14T12:16:04.347240+04:00 linux-f2js ip-up: Usage: ... qdisc add ... htb [default N] [r2q N]
2014-04-14T12:16:04.347708+04:00 linux-f2js ip-up: default minor id of class to which unclassified packets are sent {0}
2014-04-14T12:16:04.347964+04:00 linux-f2js ip-up: r2q DRR quantums are computed as rate in Bps/r2q {10}
2014-04-14T12:16:04.348237+04:00 linux-f2js ip-up: debug string of 16 numbers each 0-3 {0}
2014-04-14T12:16:04.348486+04:00 linux-f2js ip-up:.
2014-04-14T12:16:04.348812+04:00 linux-f2js ip-up: ... class add ... htb rate R1 [burst B1] [mpu B] [overhead O]
2014-04-14T12:16:04.349088+04:00 linux-f2js ip-up: [prio P] [slot S] [pslot PS]
2014-04-14T12:16:04.349325+04:00 linux-f2js ip-up: [ceil R2] [cburst B2] [mtu MTU] [quantum Q]
2014-04-14T12:16:04.349736+04:00 linux-f2js ip-up: rate rate allocated to this class (class can still borrow)
2014-04-14T12:16:04.350060+04:00 linux-f2js ip-up: burst max bytes burst which can be accumulated during idle period {computed}
2014-04-14T12:16:04.350340+04:00 linux-f2js ip-up: mpu minimum packet size used in rate computations
2014-04-14T12:16:04.350637+04:00 linux-f2js ip-up: overhead per-packet size overhead used in rate computations
2014-04-14T12:16:04.350909+04:00 linux-f2js ip-up: linklay adapting to a linklayer e.g. atm
2014-04-14T12:16:04.351195+04:00 linux-f2js ip-up: ceil definite upper class rate (no borrows) {rate}
2014-04-14T12:16:04.351459+04:00 linux-f2js ip-up: cburst burst but for ceil {computed}
2014-04-14T12:16:04.351847+04:00 linux-f2js ip-up: mtu max packet size we create rate map for {1600}
2014-04-14T12:16:04.352197+04:00 linux-f2js ip-up: prio priority of leaf; lower are served first {0}
2014-04-14T12:16:04.352496+04:00 linux-f2js ip-up: quantum how much bytes to serve from leaf at once {use r2q}
2014-04-14T12:16:04.352821+04:00 linux-f2js ip-up:.
2014-04-14T12:16:04.353102+04:00 linux-f2js ip-up: TC HTB version 3.3
2014-04-14T12:16:04.353420+04:00 linux-f2js ip-up: Illegal "rate"
2014-04-14T12:16:04.353691+04:00 linux-f2js ip-up: Usage: ... qdisc add ... htb [default N] [r2q N]
2014-04-14T12:16:04.353957+04:00 linux-f2js ip-up: default minor id of class to which unclassified packets are sent {0}
2014-04-14T12:16:04.354272+04:00 linux-f2js ip-up: r2q DRR quantums are computed as rate in Bps/r2q {10}
2014-04-14T12:16:04.354590+04:00 linux-f2js ip-up: debug string of 16 numbers each 0-3 {0}
2014-04-14T12:16:04.354924+04:00 linux-f2js ip-up:.
2014-04-14T12:16:04.355146+04:00 linux-f2js ip-up: ... class add ... htb rate R1 [burst B1] [mpu B] [overhead O]
2014-04-14T12:16:04.355495+04:00 linux-f2js ip-up: [prio P] [slot S] [pslot PS]
2014-04-14T12:16:04.355816+04:00 linux-f2js ip-up: [ceil R2] [cburst B2] [mtu MTU] [quantum Q]
2014-04-14T12:16:04.356123+04:00 linux-f2js ip-up: rate rate allocated to this class (class can still borrow)
2014-04-14T12:16:04.356403+04:00 linux-f2js ip-up: burst max bytes burst which can be accumulated during idle period {computed}
2014-04-14T12:16:04.356720+04:00 linux-f2js ip-up: mpu minimum packet size used in rate computations
2014-04-14T12:16:04.357013+04:00 linux-f2js ip-up: overhead per-packet size overhead used in rate computations
2014-04-14T12:16:04.357268+04:00 linux-f2js ip-up: linklay adapting to a linklayer e.g. atm
2014-04-14T12:16:04.357617+04:00 linux-f2js ip-up: ceil definite upper class rate (no borrows) {rate}
2014-04-14T12:16:04.357907+04:00 linux-f2js ip-up: cburst burst but for ceil {computed}
2014-04-14T12:16:04.358185+04:00 linux-f2js ip-up: mtu max packet size we create rate map for {1600}
2014-04-14T12:16:04.358494+04:00 linux-f2js ip-up: prio priority of leaf; lower are served first {0}
2014-04-14T12:16:04.358736+04:00 linux-f2js ip-up: quantum how much bytes to serve from leaf at once {use r2q}
2014-04-14T12:16:04.359054+04:00 linux-f2js ip-up:.
2014-04-14T12:16:04.359409+04:00 linux-f2js ip-up: TC HTB version 3.3
2014-04-14T12:16:04.359819+04:00 linux-f2js ip-up: RTNETLINK answers: No such file or directory
2014-04-14T12:16:04.370682+04:00 linux-f2js ip-up: RTNETLINK answers: No such file or directory
2014-04-14T12:16:04.430537+04:00 linux-f2js ip-up: Illegal "rate"
2014-04-14T12:16:04.431027+04:00 linux-f2js ip-up: Illegal "police"
2014-04-14T12:17:24.017866+04:00 linux-f2js netconfig: open lock for netconfig failed. Abort.
2014-04-14T12:17:24.048520+04:00 linux-f2js ip-up: RTNETLINK answers: No such file or directory
2014-04-14T12:17:24.063122+04:00 linux-f2js ip-up: RTNETLINK answers: No such file or directory
2014-04-14T13:02:32.636496+04:00 linux-f2js kernel: [434238.711191] HTB: quantum of class 10001 is big. Consider r2q change.
2014-04-14T13:02:32.651425+04:00 linux-f2js kernel: [434238.726131] HTB: quantum of class 10010 is big. Consider r2q change.
2014-04-14T13:02:32.665466+04:00 linux-f2js kernel: [434238.740731] HTB: quantum of class 10020 is big. Consider r2q change.
Edited by alishkka
