Есть Cisco Catalyst 3750G-12S и Cisco Catalyst 3750-24TS.
Делаю так:
C3750G-12S
no errdisable detect cause gbic-invalid
no errdisable detect cause sfp-config-mismatch
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
interface Port-channel3
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 10,20,60,100,300-999
switchport mode trunk
interface GigabitEthernet1/0/7
channel-group 3 mode on
interface GigabitEthernet1/0/8
C3750-24TS (вернее это три таких коммутатора в стеке)
spanning-tree mode pvst
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree etherchannel guard misconfig
spanning-tree extend system-id
no spanning-tree vlan 1-1000
interface Port-channel1
description CORE-BACKBONE-C3750G
switchport trunk allowed vlan 10,20,60,100,300-499,800-999
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
ip dhcp snooping trust
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
switchport trunk allowed vlan 10,301
Пока не сделал no spanning-tree, порт на C3750-24TS тут же гас по причине channel-misconfig.
Подскажите, куда смотреть?
Делаю так:
channel-group 1 mode on на портах не забыли?
Написать в посте забыл.
В конфигурации включал конечно.
Причем etherchannel уже был собран раньше (только подключался он не в C3750G, а в коммутатор QTECH).
Пока не выключил spanning-tree, линк не поднимался.
Пальцем в небо - попробуйте добавить в транк VLAN 1, т.к. именно в нем ходит BPDU. И приведите к одинаковому виду список разрешенных вланов в gi2/0/1 и gi2/0/2
Edited by xpertiza
bpduguard на аплинках лучше запрещать. Как вы достучитесь до коммутатора если сработал bpduguard?
Настройки портов должны быть одинаковы перед включением их в группу.
Ну и настройки STP лучше согласованные делать на коммутаторах.
Вы именно в такой конфигурации пытались порты в port-channel запихать ? Если да - то ругань в логах на vlan mask на портах должна была вас насторожить )
Это я вчера не то скопировал.
vlan в группе и на обоих сторонах одинаковые.
Я бы вообще это все выключил, т.к. колец у меня нет, а защитой от петель должно заниматься оборудование уровнем ниже. Разве что подстраховка нужна на случай, если петля не заблокируется, чтобы флуд в соседние порты не пошел.
Но не соображу, как правильно отключить.
Ну и это уже вопрос второй, а в первую очередь я не пойму, почему порты гасятся. bpduguard и bpdufilter я добавил уже потом.
А что было в сообщениях channel-misconfig?
Настройки stp на коммутаторах какие?
Сомневаюсь что отключение STP это правильное решение - очень мало случаев когда действительно необходимо отключать STP на коммутаторах.
Логичней определить причины проблем с STP , осмыслить и постараться подобрать оптимальные настройки.
