Добрый день!
Нужна помощь.
Ошибки на интерфейсах, потеря пакетов.
if 0/0 смотрит в инет
5 minute input rate 40368000 bits/sec, 4952 packets/sec
5 minute output rate 8860000 bits/sec, 3604 packets/sec
1995053984 packets input, 3583324273 bytes, 0 no buffer
Received 83948 broadcasts, 0 runts, 0 giants, 154 throttles
128262 input errors, 0 CRC, 0 frame, 4456 overrun, 123806 ignored
if 1/0 смотрит в нашу сеть
5 minute input rate 9355000 bits/sec, 3480 packets/sec
5 minute output rate 34173000 bits/sec, 4007 packets/sec
1414355008 packets input, 1016738213 bytes
Received 2022878 broadcasts, 0 runts, 0 giants, 4 throttles
45437 input errors, 0 CRC, 0 frame, 4 overrun, 44865 ignored
нужен совет что делать?
Router#show buffers
Buffer elements:
1117 in free list (1119 max allowed)
53328824 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 85, permanent 50, peak 133 @ 6d18h):
83 in free list (20 min, 150 max allowed)
22721877 hits, 2513 misses, 1773 trims, 1808 created
722 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 65 @ 6d18h):
23 in free list (10 min, 150 max allowed)
5162158 hits, 433 misses, 250 trims, 250 created
216 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 96 @ 4d02h):
49 in free list (5 min, 150 max allowed)
11223008 hits, 2267 misses, 432 trims, 432 created
1014 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 13 @ 4d23h):
9 in free list (0 min, 100 max allowed)
472 hits, 544 misses, 30 trims, 30 created
544 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 4 @ 4d23h):
1 in free list (0 min, 10 max allowed)
51 hits, 493 misses, 86 trims, 87 created
493 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 3 @ 3d18h):
1 in free list (0 min, 4 max allowed)
29 hits, 464 misses, 72 trims, 73 created
464 failures (0 no memory)
Interface buffer pools:
IPC buffers, 4096 bytes (total 2, permanent 2):
2 in free list (1 min, 8 max allowed)
0 hits, 0 fallbacks, 0 trims, 0 created
0 failures (0 no memory)
Header pools:
Header buffers, 0 bytes (total 511, permanent 256, peak 511 @ 6d18h):
255 in free list (256 min, 1024 max allowed)
171 hits, 85 misses, 0 trims, 255 created
256 max cache size, 256 in cache
966516 hits in cache, 0 misses in cache
Particle Clones:
1024 clones, 286295 hits, 0 misses
Public particle pools:
F/S buffers, 128 bytes (total 512, permanent 512):
0 in free list (0 min, 512 max allowed)
512 hits, 0 misses, 0 trims, 0 created
512 max cache size, 512 in cache
286295 hits in cache, 0 misses in cache
Normal buffers, 512 bytes (total 2048, permanent 2048):
2048 in free list (1024 min, 4096 max allowed)
0 hits, 0 misses, 0 trims, 0 created
Private particle pools:
FastEthernet1/0 buffers, 512 bytes (total 400, permanent 400):
0 in free list (0 min, 400 max allowed)
400 hits, 0 fallbacks
400 max cache size, 271 in cache
2210215139 hits in cache, 0 misses in cache
14 buffer threshold, 0 threshold transitions
GigabitEthernet0/1 buffers, 768 bytes (total 2129, permanent 2000):
129 in free list (128 min, 6000 max allowed)
1957 hits, 43 fallbacks, 120 trims, 249 created
2000 max cache size, 1872 in cache
1460848 hits in cache, 0 misses in cache
GigabitEthernet0/0 buffers, 768 bytes (total 2129, permanent 2000):
4275624899 hits in cache, 0 misses in cache
Router#
Диагноз ставить :)
Какой маршрутизатор?
IOS?
Конфиг?
Трафику сколько?
7401ASR
12.4
in 50 out 15
cpu 40-50%
конфиг:
Building configuration...
Current configuration : 3811 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname Router
boot-start-marker
boot system disk0:c7400-ik9o3s-mz.124-12.bin
boot-end-marker
no logging console
aaa new-model
aaa session-mib disconnect
aaa authentication login default local
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting update periodic 5
aaa accounting network default start-stop group radius
aaa session-id common
clock timezone MSK 0
ip nbar pdlm disk0:bittorrent.pdlm
ip nbar pdlm disk0:directconnect.pdlm
ip nbar pdlm disk0:eDonkey.pdlm
ip cef
ip name-server 8.8.8.8
ip name-server 217.9.148.4
ip name-server 217.9.147.42
ip name-server 10.0.0.1
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.0 192.168.0.100
ip dhcp pool LOCAL
network 192.168.0.0 255.255.252.0
dns-server 10.0.0.1
default-router 192.168.0.1
no ip pxf
virtual-template 1 pre-clone 500
username ххххххххххх privilege 15 secret 5
archive
log config
logging enable
hidekeys
class-map match-any p2p
match protocol bittorrent
match protocol directconnect
match protocol edonkey
policy-map limit-torrents
class p2p
police 2560000 480000 960000 conform-action transmit exceed-action drop violate-action drop
bba-group pppoe global
virtual-template 1
sessions max limit 8000
ac name nas1
sessions per-mac limit 1
sessions per-vlan limit 500
sessions auto cleanup
interface GigabitEthernet0/0
description INTERNET
ip address ххх.ххх.40.210 255.255.255.252
ip nbar protocol-discovery
ip nat outside
ip virtual-reassembly
duplex full
speed auto
media-type gbic
no negotiation auto
interface GigabitEthernet0/1
description BILLING
ip address 10.0.0.2 255.255.255.0
ip nat inside
duplex full
speed auto
media-type rj45
no cdp enable
interface FastEthernet1/0
description LOCAL
ip address 192.168.0.1 255.255.252.0
duplex full
vlan-range dot1q 1 4048
pppoe enable group global
exit-vlan-config
no cdp enable
interface Virtual-Template1
mtu 1492
ip unnumbered GigabitEthernet0/1
ip flow ingress
ip flow egress
autodetect encapsulation ppp
peer default ip address pool PPPoE
ppp max-bad-auth 3
ppp authentication chap
ppp timeout retry 3
ppp timeout authentication 45
ppp timeout idle 3600
ip route 0.0.0.0 0.0.0.0 ххх.ххх.40.209
ip flow-export source Virtual-Template1
ip flow-export version 5
ip flow-export destination 10.0.0.1 9996
no ip http server
no ip http secure-server
ip nat inside source static 10.0.0.1 interface GigabitEthernet0/0
ip access-list standard RW3
access-list 114 remark ** Remix DAY-Time ACL
access-list 114 permit ip any any time-range DAY-REMIX
access-list 115 remark ** NIGHT-Time ACL
access-list 115 permit ip any any time-range NIGHT-REMIX
snmp-server community public RO
snmp-server community private RW
radius-server attribute 8 include-in-access-req
radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
radius-server attribute 31 mac format unformatted
radius-server host 10.0.0.1 auth-port 1812 acct-port 1813
radius-server retransmit 5
radius-server timeout 30
radius-server deadtime 1
radius-server key 7 03175E08140A35
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
access-class 10 in
privilege level 15
ntp clock-period 17180125
ntp server 62.117.76.142
periodic daily 8:00 to 23:59
periodic daily 0:00 to 7:59
end
Попробуйте убрать все что касается nbar и торрентов, есть мнение что это слабо помогает.
Возможно pfx включить стоит.
Убрал, загрузка цп снизилась на 5%
Рано радовался
Router>sh int gi 0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is i82543 (Livengood), address is 0008.7dfc.d408 (bia 0008.7dfc.d408)
Description: INTERNET
Internet address is ххх.ххх.40.210/30
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 5/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is force-up, media type is LX
output flow-control is unsupported, input flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 23:32:37
Input queue: 0/75/6684/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 23223000 bits/sec, 3156 packets/sec
5 minute output rate 5236000 bits/sec, 2522 packets/sec
300928374 packets input, 728921439 bytes, 0 no buffer
Received 12314 broadcasts, 0 runts, 0 giants, 18 throttles
45398 input errors, 0 CRC, 0 frame, 6089 overrun, 39309 ignored
0 watchdog, 12109 multicast, 0 pause input
0 input packets with dribble condition detected
239047206 packets output, 1059273860 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
