a-zazell Posted March 12, 2014 Posted March 12, 2014 Здравствуйте, есть zabbix 2.0.7, определил ID графика, соответственно URL вида: https://zabbix.myhost.ru/chart2.php?graphid=920&period=86400 Вначале беру cookie, потом пытаюсь забрать картинку, выдает: You are not logged in.You cannot view this URL as a guest. You must login to view this page. If you think this message is wrong, please consult your administrators about getting the necessary permissions. При этом в cookie: # HTTP cookie file. # Generated by Wget on 2014-03-12 12:11:29. # Edit at your own risk. zabbix.myhost.ru FALSE / FALSE 1397290289 zbx_sessionid e4a20143a6a4bbbd50cc80f50732f59d Ниже скрипт bash: #!/bin/bash export PATH="/usr/local/bin:/usr/bin:/bin" MYDIR="/home" IMG_DIR=${MYDIR}/img ZABBIX_USER="login" ZABBIX_PASSWORD="password" ZABBIX_URL="https://zabbix.myhost.ru" GRAPH_LIST=${MYDIR}/zabbix_graph.lst COOKIE=${MYDIR}/cookie.txt getCookie () { wget -q --post-data='request=""&name='${ZABBIX_USER}'&password='${ZABBIX_PASSWORD}'&autologin=1&enter="Sign in"' \ --no-check-certificate \ --save-cookies=$COOKIE \ --keep-session-cookies "${ZABBIX_URL}" -O /dev/null } getGraph () { if [ -f $GRAPH_LIST ];then while read ID URL do if [ "${ID}" ];then wget --load-cookies=$COOKIE --save-cookies=$COOKIE \ --keep-session-cookies \ --no-check-certificate \ "${URL}" -O $IMG_DIR/$ID.png fi done < $GRAPH_LIST else echo "Error! Graph list file $GRAPH_LIST not exist ..." fi } getCookie; getGraph; $ cat zabbix_graph.lst wan.gw https://zabbix.myhost.ru/chart2.php?graphid=920&period=86400 Чего ему надо-то? Вставить ник Quote
Abram Posted March 12, 2014 Posted March 12, 2014 https://www.zabbix.com/forum/showthread.php?t=19090 Вставить ник Quote
