Всем доброго дня!
Нужна помощь.
абоненту нужен прямой белый ip, у нас авторизация по ПППоЕ, сеть нам настраивали
вот конфиг роутера:
archive
log config
logging enable
hidekeys
class-map match-any p2p
match protocol directconnect
match protocol edonkey
bba-group pppoe global
virtual-template 1
sessions max limit 8000
ac name nas1
sessions per-mac limit 1
sessions per-vlan limit 500
sessions auto cleanup
interface GigabitEthernet0/0
description INTERNET
ip address ххх.ххх.40.210 255.255.255.252
ip nbar protocol-discovery
ip virtual-reassembly
duplex full
speed auto
media-type gbic
no negotiation auto
interface GigabitEthernet0/1
description BILLING
ip address 10.0.0.2 255.255.255.0
duplex full
speed auto
media-type rj45
no cdp enable
interface FastEthernet1/0
description LOCAL
ip address 192.168.0.1 255.255.252.0
duplex full
vlan-range dot1q 1 4048
pppoe enable group global
exit-vlan-config
no cdp enable
interface Virtual-Template1
mtu 1492
ip unnumbered GigabitEthernet0/1
ip flow ingress
ip flow egress
autodetect encapsulation ppp
peer default ip address pool PPPoE
ppp max-bad-auth 3
ppp authentication chap
ppp timeout retry 3
ppp timeout authentication 45
ppp timeout idle 3600
ip route 0.0.0.0 0.0.0.0 ххх.ххх.40.209
ip flow-export source Virtual-Template1
ip flow-export version 5
ip flow-export destination 10.0.0.1 9996
no ip http server
no ip http secure-server
ip access-list standard RW3
access-list 114 remark ** Remix DAY-Time ACL
access-list 114 permit ip any any time-range DAY-REMIX
access-list 115 remark ** NIGHT-Time ACL
access-list 115 permit ip any any time-range NIGHT-REMIX
snmp-server community public RO
snmp-server community private RW
radius-server attribute 8 include-in-access-req
radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
radius-server attribute 31 mac format unformatted
radius-server host 10.0.0.1 auth-port 1812 acct-port 1813
radius-server retransmit 5
radius-server timeout 30
radius-server deadtime 1
radius-server key 7 03175E08140A35
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
access-class 10 in
privilege level 15
ntp clock-period 17180193
ntp server 91.226.136.136
ntp server 62.117.76.142
periodic daily 8:00 to 23:59
periodic daily 0:00 to 7:59
end
заранее благодарен за помощь.
Присоединяюсь к вопросу, нам тоже надо дать поток инета для пользования с белым айпишником, что нужно сделать, если кто-нибудь знает что -нибудь, то напишите по этому вопросу более конкретно???
Edited by user555
В атрибуте Framed-IP-Address радиус должен отдать тот IP-адрес, который нужно назначить абоненту.
Настраивать нужно биллинг, BRAS трогать не нужно.
Сори, я наверно не правильно объяснил, у нас и так выдаются по ПППоЕ белые статические адреса, как без процедуры авторизации дать абоненту IP чтоб он у себя в настроика сетевухи прописал его и был в интернете?
Ничего не понял.
Если используется PPPoE, то у абонента ничего вручную прописывать не надо. Нужно настроить биллинг/BRAS так, чтобы абоненту с помощью Framed-IP-Address назначался публичный статический IP-адрес.
Если же нужно абоненту выдать подсеть со статической маршрутизацией, то это уже IPoE.
