ili4 Posted October 27, 2004 Posted October 27, 2004 Всем привет! У меня есть Freeradius 1.0.1 и радиус-клиент, который посылает запросы на авторизацию с паролем MD5 вот такого вида: Packet-Type = Access-Request Wed Oct 27 08:31:27 2004 User-Name = "user" NAS-IP-Address = 10.0.0.1 NAS-Port-Type = Async Service-Type = Login-User Cisco-AVPair = "xpgk-md5-auth=user/1076653854/09456456456daebe7e6a564083ebd7e6" Cisco-AVPair = "xpgk-request-type=user" Client-IP-Address = 10.0.0.1 Но радиус упорно не хочет понимать MD5, требует аттрибут User-Password. Вот лог: rad_recv: Access-Request packet from host 10.0.0.1:1812, id=71, length=148 User-Name = "user" NAS-IP-Address = 10.0.0.1 NAS-Port-Type = Async Service-Type = Login-User Cisco-AVPair = "xpgk-md5-auth=user/1076653854/09456456456daebe7e6a564083ebd7e6" Cisco-AVPair = "xpgk-request-type=user" Processing the authorize section of radiusd.conf modcall: entering group authorize for request 4 modcall[authorize]: module "preprocess" returns ok for request 4 radius_xlat: '/var/log/freeradius/radacct/10.0.0.1/auth-detail-20041026' rlm_detail: /var/log/freeradius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d expands to /var/log/freeradius/radacct/194.13 modcall[authorize]: module "auth_log" returns ok for request 4 modcall[authorize]: module "chap" returns noop for request 4 modcall[authorize]: module "mschap" returns noop for request 4 rlm_eap: No EAP-Message, not doing EAP modcall[authorize]: module "eap" returns noop for request 4 radius_xlat: 'user' rlm_sql (pgsql-voip): sql_set_user escaped user --> 'user' radius_xlat: 'exec my_auth 'user'' rlm_sql (pgsql-voip): Reserving sql socket id: 20 query: exec my_auth 'user' radius_xlat: '' radius_xlat: '' radius_xlat: '' rlm_sql (pgsql-voip): Released sql socket id: 20 modcall[authorize]: module "pgsql-voip" returns ok for request 4 modcall: group authorize returns ok for request 4 auth: type Local auth: No User-Password or CHAP-Password attribute in the request auth: Failed to validate the user. Login incorrect: [user/<no User-Password attribute>] (from client localhost port 0) Подскажите, как научить Freeradius понимать MD5? Вставить ник Quote
bone Posted October 27, 2004 Posted October 27, 2004 Конфиг радиуса покажи в области modules { и authorize { Вставить ник Quote
ili4 Posted October 27, 2004 Author Posted October 27, 2004 authorize { preprocess auth_log # attr_filter chap mschap # digest # IPASS # suffix # ntdomain eap # files pgsql-voip # etc_smbpasswd # ldap # daily # checkval } ..... modules { pap { encryption_scheme = md5 } chap { authtype = CHAP } pam { pam_auth = radiusd } unix { cache = no cache_reload = 600 radwtmp = ${logdir}/radwtmp } $INCLUDE ${confdir}/eap.conf mschap { authtype = MS-CHAP #use_mppe = no #require_encryption = yes #require_strong = yes #with_ntdomain_hack = no #ntlm_auth = "/path/to/ntlm_auth --request-nt-key --username=%{Stripped-User-Name:-%{User-Name:-None}} --challenge=%{mschap:Challenge:-00} --nt-response=%{mschap:NT-Response:-00}" } realm IPASS { format = prefix delimiter = "/" ignore_default = no ignore_null = no } # 'username@realm' # realm suffix { format = suffix delimiter = "@" ignore_default = no ignore_null = no } # 'username%realm' # realm realmpercent { format = suffix delimiter = "%" ignore_default = no ignore_null = no } # # 'domainuser' # realm ntdomain { format = prefix delimiter = "" ignore_default = no ignore_null = no } checkval { # The attribute to look for in the request item-name = Calling-Station-Id # The attribute to look for in check items. Can be multi valued check-name = Calling-Station-Id # The data type. Can be # string,integer,ipaddr,date,abinary,octets data-type = string # If set to yes and we dont find the item-name attribute in the # request then we send back a reject # DEFAULT is no #notfound-reject = no } attr_rewrite h323_setup_time { attribute = h323-setup-time # may be "packet", "reply", "proxy", "proxy_reply" or "config" searchin = packet searchfor = "[a-zA-Z]" replacewith = "" ignore_case = no new_attribute = no max_matches = 6 ## If set to yes then the replace string will be appended to the original string append = no } attr_rewrite h323_setup_time1 { attribute = h323-setup-time # may be "packet", "reply", "proxy", "proxy_reply" or "config" searchin = packet searchfor = "^[.*]" replacewith = "" ignore_case = no new_attribute = no max_matches = 1 ## If set to yes then the replace string will be appended to the original string append = no } attr_rewrite h323_connect_time { attribute = h323-connect-time # may be "packet", "reply", "proxy", "proxy_reply" or "config" searchin = packet searchfor = "[a-zA-Z]" replacewith = "" ignore_case = no new_attribute = no max_matches = 6 ## If set to yes then the replace string will be appended to the original string append = no } attr_rewrite h323_connect_time1 { attribute = h323-connect-time # may be "packet", "reply", "proxy", "proxy_reply" or "config" searchin = packet searchfor = "^[.*]" replacewith = "" ignore_case = no new_attribute = no max_matches = 1 ## If set to yes then the replace string will be appended to the original string append = no } attr_rewrite h323_disconnect_time { attribute = h323-disconnect-time # may be "packet", "reply", "proxy", "proxy_reply" or "config" searchin = packet searchfor = "[a-zA-Z]" replacewith = "" ignore_case = no new_attribute = no max_matches = 6 ## If set to yes then the replace string will be appended to the original string append = no } attr_rewrite h323_disconnect_time1 { attribute = h323-connect-time # may be "packet", "reply", "proxy", "proxy_reply" or "config" searchin = packet searchfor = "^[.*]" replacewith = "" ignore_case = no new_attribute = no max_matches = 1 ## If set to yes then the replace string will be appended to the original string append = no } preprocess { huntgroups = ${confdir}/huntgroups hints = ${confdir}/hints with_ascend_hack = no ascend_channels_per_line = 23 with_ntdomain_hack = no with_specialix_jetstream_hack = no with_cisco_vsa_hack = yes } files { usersfile = ${confdir}/users acctusersfile = ${confdir}/acct_users compat = no } detail { detailfile = ${radacctdir}/%{Client-IP-Address}/detail-%Y%m%d detailperm = 0600 } detail auth_log { detailfile = ${radacctdir}/%{Client-IP-Address}/auth-detail-%Y%m%d detailperm = 0600 } acct_unique { key = "User-Name, Acct-Session-Id, NAS-IP-Address, Client-IP-Address, NAS-Port" } $INCLUDE ${confdir}/mssql-voip.conf radutmp { filename = ${logdir}/radutmp username = %{User-Name} case_sensitive = yes check_with_nas = yes perm = 0600 callerid = "yes" } radutmp sradutmp { filename = ${logdir}/sradutmp perm = 0644 callerid = "no" } attr_filter { attrsfile = ${confdir}/attrs } counter daily { filename = ${raddbdir}/db.daily key = User-Name count-attribute = Acct-Session-Time reset = daily counter-name = Daily-Session-Time check-name = Max-Daily-Session allowed-servicetype = Framed-User cache-size = 5000 } always fail { rcode = fail } always reject { rcode = reject } always ok { rcode = ok simulcount = 0 mpp = no } expr { } digest { } exec { wait = yes input_pairs = request } exec echo { wait = yes program = "/bin/echo %{User-Name}" input_pairs = request output_pairs = reply } } Вставить ник Quote
ili4 Posted October 27, 2004 Author Posted October 27, 2004 и в догонку eap.conf Хотя freeradius его не использует, говорит : rlm_eap: No EAP-Message, not doing EAP # # Whatever you do, do NOT set 'Auth-Type := EAP'. The server # is smart enough to figure this out on its own. The most # common side effect of setting 'Auth-Type := EAP' is that the # users then cannot use ANY other authentication method. # # $Id: eap.conf,v 1.4 2004/04/15 18:34:41 aland Exp $ # eap { default_eap_type = md5 timer_expire = 60 ignore_unknown_eap_types = no cisco_accounting_username_bug = no md5 { } leap { } gtc { #challenge = "Password: " auth_type = PAP } mschapv2 { } } Вставить ник Quote
bone Posted October 27, 2004 Posted October 27, 2004 Прошу прощения, но где у тебя пользователи хранятся? Вставить ник Quote
ili4 Posted October 27, 2004 Author Posted October 27, 2004 в mssql в открытом виде. если пароль приходит аттрибутом User-Password, то все нармально Вставить ник Quote
bone Posted October 27, 2004 Posted October 27, 2004 в mssql в открытом виде.А где у тебя это написано? У меня так: authorize { sql mschap } Вставить ник Quote
ili4 Posted October 27, 2004 Author Posted October 27, 2004 у меня тоже: authorize { preprocess auth_log chap mschap eap pgsql-voip <--- } стукни мне в асю 98188683 Вставить ник Quote
