Настраиваю smart edge 100 + Ланбиллинг по dhcp opt.82
Проблема: абонента не выпускает в инет. При авторизации, абонент пингует dhcp, шлюз, интерфейсы на эрикссоне, только вот вышестоящий маршрутизатор не пингует.
При авторизации субскрайбер на эрике выглядит так:
10:bf:48:64:a3:63
Session state Up
Circuit 2/1 vlan-id 25 clips 131171
Internal Circuit 2/1:511:63:31/7/2/99
Interface bound CLIENTS
Current port-limit unlimited
Session time left 86039
Protocol Stack IPV4
dhcp max-addrs 1 (applied)
context-name LBILL (applied)
dhcp vendor class id MSFT 5.0 (applied)
dhcp option client id 0x3d070110bf4864a363 (applied)
dhcp option hostname 0x0c0549542d8f8a (applied)
timeout absolute 86400 (applied)
acct-interim-interval 600 (applied)
qos-policing-policy qos-default-in (applied)
qos-metering-policy qos-default-out (applied)
nat policy-name LB-NAT (applied)
qos-dynamic-param (applied)
police-class-rate LCLASS rate-absolute 10240 (applied)
police-class-burst LCLASS 1536000 (applied)
meter-class-rate LCLASS rate-absolute 10240 (applied)
meter-class-burst LCLASS 1536000 (applied)
IP host entries installed by DHCP: (max_addr 1 cur_entries 1)
10.199.1.3 10:bf:48:64:a3:63
Sh arp:
Host Hardware address Ttl Type Circuit
10.0.10.1 f8:f0:82:10:1a:ac 640 ARPA 2/1 vlan-id 25
10.0.10.2 00:30:88:1d:11:46 - ARPA 2/1 vlan-id 25
10.0.255.1 00:1c:c4:7b:52:ac 842 ARPA 2/2 vlan-id 10
10.0.255.2 00:30:88:1d:11:47 - ARPA 2/2 vlan-id 10
10.199.1.1 00:00:00:00:00:00 - None Multi-Bound
10.199.1.3 f8:f0:82:10:1a:ac 2744 ARPA 2/1 vlan-id 25 clips 131173
91.xx.xx.90 00:0c:cf:de:b4:1b 3573 ARPA 2/2 vlan-id 4094
91.xx.xx.91 00:30:88:1d:11:47 - ARPA 2/2 vlan-id 4094
Конфиг smart edge:
aaa global authentication subscriber radius context local
aaa global accounting subscriber radius context local
aaa global update subscriber 10
aaa global reject empty-username
aaa global session-id-count
service multiple-contexts
service inter-context routing
flow ip profile netflow
active-timeout 15
asp group test
asp-count 1
context local
no ip domain-lookup
interface mgmt
ip address 192.168.1.202/24
logging console
enable encrypted 1
aaa authentication administrator local
radius accounting server 10.0.255.1 encrypted-key
administrator admin encrypted 1
privilege max 15
no timeout session idle
subscriber default
service ssh server
context LBILL
no ip domain-lookup
ip nat pool NAT-POOL3 napt multibind
address 91.xxx.xxx.92/32 port-block 1 to 15
nat policy LB-NAT
! Default class
ignore
icmp-notification
! Named classes
access-group LGROUP
class LCLASS
pool NAT-POOL3 local
timeout tcp 18000
timeout udp 60
timeout fin-reset 60
timeout icmp 30
timeout syn 60
icmp-notification
interface CLIENTS multibind
ip address 10.199.1.1/24
dhcp proxy 253
giaddr 10.199.1.1
interface CLIENTS2 multibind
ip address 10.200.1.1/24
dhcp proxy 253
interface DOWNL
description l3-relay
ip address 10.0.10.2/30
interface UPL
ip address 10.0.255.2/24
ip source-address radius dhcp-server
interface uplink
ip address 91.xxx.xxx.91/28
no logging console
policy access-list LGROUP
seq 10 permit ip 10.0.0.0 0.0.0.255 class LCLASS
seq 20 permit ip 192.168.0.0 0.0.255.255 class LCLASS
seq 30 permit ip 172.16.0.0 0.15.255.255 class LCLASS
policy access-list http-test
seq 10 permit tcp any any eq www class redirect
http-redirect profile CABINET
url "http://10.0.255.1/admin/config.php"
message "Redirecting"
timeout 30
enable authentication local
aaa authentication administrator maximum sessions 1
aaa authentication subscriber radius
aaa accounting subscriber radius
aaa accounting event dhcp
radius coa server 10.0.255.1 encrypted-key
radius server 10.0.255.1 encrypted-key
radius max-retries 5
radius timeout 30
subscriber default
dhcp max-addrs 1
ip route 0.0.0.0/0 91.xxx.xxx.90
ip route 10.199.1.0/24 10.0.10.1
ip route 10.200.1.0/24 10.0.10.1
service ssh
service telnet
dhcp relay server 10.0.255.1
! ** End Context **
logging debug
logging debug active
logging tdm console
logging active
logging standby short
forward policy CABINET
ip access-group http-test LBILL
class redirect
redirect destination local
qos policy qos-default-in policing radius-guided
ip access-group LGROUP LBILL
class LCLASS
rate 2000 burst 250000 excess-burst 375000
rate-calculation exclude layer-2-overhead
qos policy qos-default-out metering radius-guided
class LCLASS
system clock timezone msk 3 0
http-redirect server
port 80 8080
port ethernet 1/1
! XCRP management port on slot 1
no shutdown
card carrier 2
mic 1 ge-2-port
mic 2 ge-2-port
port ethernet 2/1
description LAN_connected
no shutdown
medium-type copper
encapsulation dot1q
dot1q pvc 25
bind interface DOWNL LBILL
service clips dhcp context LBILL
port ethernet 2/2
description ip Uplink
no shutdown
medium-type copper
encapsulation dot1q
dot1q pvc 10
bind interface UPL LBILL
dot1q pvc 4094
bind interface uplink LBILL
service auto-system-recovery
system hostname LANBILLING_SE100
pppoe services all-domains
pppoe service-name accept-all
end
Edited by kmk08
Не пингуется 91.xxx.xxx.90? А прямо из контекста LBILL пингуется? Покажите show nat policy и show ip route nat.
С эриксона пингуется 91.xxx.xxx.90, и вообще инет он видит, только не видит инета абонент.
Policy-Grid Rules Slot-Mask Binds Policy-Name
0x00000005 0 0x0000000c 1 LB-NAT
Policy name : LB-NAT
Policy grid : 0x5
Number of rules : 0
Slot mask : 0xc
Number of binds : 1
sh ip ro nat молчит
У Вас, если не ошибаюсь, в
nat policy LB-NAT
! Default class
ignore
icmp-notification
! Named classes
access-group LGROUP
class LCLASS
timeout tcp 18000
timeout udp 60
timeout icmp 30
timeout syn 60
icmp-notification
строка
ссылается на контекст локал. Попробуйте поправить на
pool NAT-POOL3 LBILL
и запросить снова sh ip ro nat.
Ты создал nat acl но не применил их к интерфейсам. Эриксонами не пользовался, но на цисках надо указывать на интерфейсе в сторону клиентов nat in, а в сторону аплинка nat out. Команда не точная, т.к. точно не помню.
К интерфейсам и не надо, если полиси вешается на сабскрайбера. ACL определяет класс, класс указывается в полиси и вся конструкция целиком вешается либо на интерфейс, либо на абонента. На Эриксоне своя атмосфера, ггг.
Не могу писать больше, лимит.
По-прежнему нет инета у абонентов? Переподнимите сессию.
на вышестоящем маршрутизаторе не настроен маршрут на 91.xxx.xxx.92 нужно ли?
Если для 91.xxx.xxx.91/28 есть, то и для нат-пула сделайте, не повредит.
![/code] строка
> NAT 91.xx.xx.92/32 0.0.0.1 4 0 00:00:53
> 0.0.0.2
> 0.0.0.3
> 0.0.0.4
> 0.0.0.5
> 0.0.0.6
> 0.0.0.7
> 0.0.0.8
> 0.0.0.9
> 0.0.0.10
> 0.0.0.11
> 0.0.0.12
> 0.0.0.13
> 0.0.0.14
> 0.0.0.15
> 0.0.0.16
В инет еще не пускает.
А на следующем после эриксона маршрутизаторе настроена маршрутизация на этот ип? (91.xxx.xxx.92/32)
На вышестоящем роутере арпы идут такие прописал маршрут, но все равно не паускает
Internet 91.xx.xx.91 4 0030.881d.1147 ARPA GigabitEthernet0/1. 4094
Protocol Address Age (min) Hardware Addr Type Interface
Internet 91.xx.xx.92 42 0030.881d.1147 ARPA GigabitEthernet0/1. 4094
Трасса останавливается на вышестоящем роутере при трассировке 91.xx.xx.92
Edited by kmk08
Нужно, иначе как он узнает за каким маршрутизатором этот ип. Вы извне попробуйте трассировку сделать - она до эрикссона должна доходить.
