Пытаемся настроить QinQ между двумя cisco 3750. Перерыли кучу статей..
соединены медным патчкордом
вот конфиг
catalyst 1
Building configuration...
Current configuration : 16577 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service unsupported-transceiver
hostname c3750
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750g-12s
system mtu routing 1500
vtp domain xxi
vtp mode transparent
ip routing
ip dhcp relay information trust-all
ip multicast-routing distributed
no errdisable detect cause gbic-invalid
no errdisable detect cause sfp-config-mismatch
errdisable recovery cause sfp-config-mismatch
spanning-tree mode pvst
spanning-tree extend system-id
no spanning-tree vlan 1-4094
vlan internal allocation policy ascending
vlan 2-19,22-24,888
interface GigabitEthernet1/0/7
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 2-19,22-24
switchport mode trunk
switchport nonegotiate
no cdp enable
no cdp tlv server-location
no cdp tlv app
interface GigabitEthernet1/0/8
switchport trunk allowed vlan 4,23
no cdp enable
no cdp tlv app
interface GigabitEthernet1/0/10
description QinQ
switchport access vlan 888
switchport mode dot1q-tunnel
no cdp enable
no cdp tlv app
interface Vlan888
ip address 10.21.80.1 255.255.255.0
---skip---
catalyst 2
version 12.2
no service pad
no service password-encryption
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750g-24t
ip routing
no spanning-tree optimize bpdu transmission
vlan dot1q tag native
interface GigabitEthernet1/0/3
switchport access vlan 23
switchport mode access
interface GigabitEthernet1/0/23
description QinQ
speed 1000
no mdix auto
no cdp enable
interface GigabitEthernet1/0/24
no cdp enable
interface Vlan1
no ip address
interface Vlan4
no ip address
interface Vlan23
ip address 192.168.17.8 255.255.255.0
interface Vlan888
ip address 10.21.80.2 255.255.255.0
---skip---
на обеих цисках MTU
sh sys mtu
System MTU size is 1546 bytes
System Jumbo MTU size is 9000 bytes
System Alternate MTU size is 1546 bytes
Routing MTU size is 1500 bytes
в транспортном влане(888) связь есть с первой циски 10.21.80.2 пингуется, а остальные vlan 4,23 не проходят.
что может быть не так ?
Edited by Serg_xxi
Вы хотите принять трафик в 4 влане, накинуть на него 888 и отправить соседу? Если да, то Вы не правильно поняли принцип.
Верхний тег накидывается на ingress порту и уходит в транк с этом влане. И наоборот, прилетает с двумя тегами и на egress снимает верхний тег.
Т.е. на железке с куинку Вы не увидите внутренние теги.
Edited by lejek
  • 1 year later...
Скажите, это значит что ограничение в 1005 активных вланов не распространяются на эту железку ? При такой схеме ?
Железка со "switchport mode dot1q-tunnel" оперирует только внешними тегами, поэтому не распространяется.
Подскажите пжл,
1. какое кол-во вланов сможет "проглатить" данная железка. Т.е. сколько можно запихнуть в dot1q tunnel ?
2. какое колличество пользователей (если отталкиваться от схемы vlan-per-costumer) можно прогнать через ip unnumbared ?
В данной железке ?
Подскажите пжл,
В данной железке ?
1. На 3560G я когда-то засовывал одну-две тысячи inner'ов в каждый из нескольких outer'ов. Не помню, чтобы кто-то жаловался :) 3560 не сильно отличается фичами от 3750. Вообще, мне кажется число inner'ов не ограничено.
2. Если хотите терминировать на 3750, то судя по докам 3750 умеет 1000 vlan-интерфейсов, получается на VPU тысячу хомячков должна съесть. Если делать vlan per switch (+traffic segmentation), должна есть больше, пока не упрется в нехватку ТСАМ (погуглите "SDM profile"). Если хотите терминировать на отдельном брасе - см. п. 1 ;)
Лучше всего все самим протестировать генератором трафика (ixia, spirent).
ТОка уточню пожалуй: SNR s3750g-24s ))
В данной железке нет ip unnumbered. Есть унылый SuperVLAN, в который, насколько я помню, больше 127 subvlan не засунуть. А при схеме vlan-per-switch или больше начнутся проблемы с неконтролируемым arp polling'ом, который там практически не конфигурируется (таймеры, пороги и тд).
На счет dot1q-tunnel не вижу каких-то ограничений. На счет схемы с Selective QinQ были темы в персонально разделе, что у SNR кончается TCAM, но на других DCN я такого не встречал. Еще был баг с хождением ARP в схеме с Selective, тема тоже есть.
