Добрый вечер!
Попал в руки следующий девайс:
admin@MX-5> show version invoke-on all-routing-engines
Hostname: MX-5
Model: mx5-t
JUNOS Base OS boot [11.4R1.14]
JUNOS Base OS Software Suite [11.4R1.14]
JUNOS Kernel Software Suite [11.4R1.14]
JUNOS Packet Forwarding Engine Support (MX80) [11.4R1.14]
JUNOS Online Documentation [11.4R1.14]
JUNOS Routing Software Suite [11.4R1.14]
admin@MX-5# run show chassis hardware
Hardware inventory:
Item             Version  Part number  Serial number     Description
Chassis                                F8293             MX5-T
Midplane         REV 08   711-038215   CAAG5254          MX5-T
PEM 0            Rev 04   740-028288   WE04350           AC Power Entry Module
PEM 1            Rev 04   740-028288   WF04970           AC Power Entry Module
Routing Engine            BUILTIN      BUILTIN           Routing Engine
TFEB 0                    BUILTIN      BUILTIN           Forwarding Engine Processor
 QXM 0          REV 06   711-028408   CAAH4636          MPC QXM
FPC 0                     BUILTIN      BUILTIN           MPC BUILTIN
 MIC 0                   BUILTIN      BUILTIN           4x 10GE XFP
   PIC 0                 BUILTIN      BUILTIN           4x 10GE XFP
FPC 1                     BUILTIN      BUILTIN           MPC BUILTIN
 MIC 0          REV 26   750-028392   CAAJ7556          3D 20x 1GE(LAN) SFP
   PIC 0                 BUILTIN      BUILTIN           10x 1GE(LAN) SFP
     Xcvr 0     REV 02   740-013111   D252841           SFP-T
     Xcvr 1     REV 02   740-013111   D254923           SFP-T
   PIC 1                 BUILTIN      BUILTIN           10x 1GE(LAN) SFP
     Xcvr 0     REV 02   740-013111   D252844           SFP-T
     Xcvr 1     REV 02   740-013111   D254901           SFP-T
     Xcvr 2     REV 02   740-013111   D252964           SFP-T
     Xcvr 3     REV 02   740-013111   D254942           SFP-T
     Xcvr 4     REV 02   740-013111   D255139           SFP-T
     Xcvr 5     REV 02   740-013111   D254917           SFP-T
     Xcvr 6     REV 02   740-013111   D254920           SFP-T
     Xcvr 7     REV 02   740-013111   D252835           SFP-T
     Xcvr 8     REV 02   740-013111   D254872           SFP-T
     Xcvr 9     REV 02   740-013111   D255646           SFP-T
Fan Tray                                                 Fan Tray
admin@MX-5# run show system license
License usage:
                                Licenses     Licenses    Licenses    Expiry
 Feature name                       used    installed      needed
 scale-subscriber                      0         1000           0    permanent
 scale-l2tp                            0         1000           0    permanent
 scale-mobile-ip                       0         1000           0    permanent
Licenses installed: none
Необходимо поднять простой динамический нат N:1.
Сделали вот так:
interfaces {
   ms-1/0/0 {
       unit 0 {
           family inet;
   ge-1/1/0 {
       gigether-options {
           802.3ad ae0;
   ge-1/1/1 {
       gigether-options {
           802.3ad ae0;
   ge-1/1/2 {
       description "TTK inet";
       unit 0 {
           family inet {
               address xx.xx.xx.xx/24;
   ge-1/1/3 {
       description "RTK inet";
       unit 0 {
           family inet {
               address yy.yy.yy.yy/30;
   ae0 {
       description "LACP to StoneGate";
       vlan-tagging;
       aggregated-ether-options {
           minimum-links 1;
           link-speed 1g;
           lacp {
               active;
               periodic fast;
       unit 11 {
           description "Transit network between StoneGate";
           vlan-id 11;
           family inet {
               address 10.11.11.1/30;
       unit 197 {
           description "Management network with routing";
           vlan-id 197;
           family inet {
               service {
                   input {
                       service-set nat_to_ttk;
                   output {
               address 192.168.197.252/24;
   fxp0 {
       unit 0 {
           description "Management interface";
           family inet {
               address 192.168.197.251/24;
   lo0 {
       unit 0 {
           description Loopback;
           family inet {
               address 10.10.10.10/32;
   vlan {
       unit 11;
       unit 197;
services {
   nat {
       pool ttk {
           address-range low xx.xx.xx.xx high xx.xx.xx.xx;
       rule local_to_ttk {
           match-direction input;
           term t1 {
               from {
                   source-address {
                       192.168.197.0/24;
               then {
                   translated {
                       source-pool ttk;
                       translation-type {
                           dynamic-nat44;
   service-set nat_to_ttk {
       nat-rules local_to_ttk;
       interface-service {
           service-interface ms-1/0/0;
Ни в какую не хочет работать. Есть у кого какие идеи?
http://www.juniper.net/techpubs/en_US/release-independent/junos/topics/reference/general/mic-mx-series-ms.html
Без этого MX не умеют ната. Да и появился он наверное пару-тройку месяцев как.
Ну разве что только inline-nat, который я не пробовал.
Edited by DVM-Avgoor
Тогда скажите как отсутствие НАТа проявляется: команд нет или они не работают? Просто конфиг то ведь пишется, нет чтобы написать, что НАТа нет (в cli).
Ну как бы все знали что ната изначально в коробке нет. Вендор не скрывал. Ну команды есть, просто не работают :)
N:1 без сервисного модуля не полетит.
сервисных модулей к MX5/20/40/80 нет и вероятно их не будет, хотя когда-то обещали. но даже если оно появится, то вряд ли по "доступной" цене .)
Изначально MX-5 был куплен для BGP и 2 провов, но возникла потребность в НАТе. В общем пока тоже пришли к выводу о том, что НАТить он не будет. Спасибо за помощь.
Модуль есть: MS-MIC-16G
http://www.juniper.net/techpubs/en_US/release-independent/junos/topics/reference/general/mic-mx-series-supported.html
Но принимая во внимание версию софта, есть сомнения, что он сейчас работоспособен :(
ну карта поддерживается с 13.2, баги там естественно будут , но с другой стороны , скоро 13.3 будет :)
  • 6 years later...
Добрый вечер. У нас появилась аналогичная задача - динамический нат N:1 на Juniper MX5-t c  MS-MIC-16G.
Может кто-нибудь помочь с конфигурацией, пожалуйста?
Hostname: mx5-t
Model: mx5-t
Junos: 17.3R3-S7.2
Пытался настроить по обзазцу первого поста, нат заработал, а минут через 20 перестрал.
Может у кого-то есть образец рабочкго конфига?
