as-set создан.
Пытаюсь анонсировать каждую подсеть через свою AS (если все подсети через одну AS то все нормально).
Делаю через
bgp multiple-instance
router bgp AS1 view 1
bgp router-id i.i.i.i
bgp log-neighbor-changes
no synchronization
no auto-summary
network x.x.x.x/22
neighbor isp1 remote-as NNN
neighbor isp1 send-community
neighbor isp1 route-map isp1-IN in
neighbor isp1 route-map isp1-OUT out
neighbor isp1 weight 200
neighbor isp2 remote-as NNN2
neighbor isp2 send-community
neighbor isp2 route-map isp2-IN2 in
neighbor isp2 route-map isp2-OUT2 out
neighbor isp2 weight 200
router bgp AS2 view 2
no synchronization
no auto-summary
network y.y.y.y/22
network z.z.z.z/21
в логах соединение есть, правда с ошибкой от одного isp:
2013/12/12 10:59:26 BGP: %ADJCHANGE: neighbor isp1 Up
2013/12/12 10:59:30 BGP: %NOTIFICATION: received from neighbor isp1 2/2 (OPEN Message Error/Bad Peer AS) 0 bytes
2013/12/12 10:59:49 BGP: %ADJCHANGE: neighbor isp2 Up
Маршруты вроде получаем:
router-BGP# sh ip bgp neighbors isp2 routes
BGP table version is 0, local router ID is i.i.i.i
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, R Removed
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* 1.0.0.0/24 78.25.77.189 200 31133 15169 i
* 1.0.4.0/24 78.25.77.189 100 31133 3356 6453 7545 56203 i
* 1.0.5.0/24 78.25.77.189 100 31133 3356 6453 7545 56203 i
* 1.0.6.0/24 78.25.77.189 200 31133 3356 174 4826 38803 56203 i
* 1.0.7.0/24 78.25.77.189 200 31133 3356 174 4826 38803 56203 i
* 1.0.20.0/23 78.25.77.189 200 31133 3356 2516 2519 i
* 1.0.22.0/23 78.25.77.189 200 31133 3356 2516 2519 i
* 1.0.24.0/23 78.25.77.189 200 31133 3356 2516 2519 i
* 1.0.26.0/23 78.25.77.189 200 31133 3356 2516 2519 i
* 1.0.28.0/22 78.25.77.189 200 31133 3356 2516 2519 i
* 1.0.64.0/18 78.25.77.189 200 31133 6939 4725 7670 7670 7670 18144 i
* 1.0.128.0/17 78.25.77.189 200 31133 10026 38040 9737 9737 i
* 1.0.128.0/18 78.25.77.189 200 31133 10026 38040 9737 i
а через route -n маршруты только локальные
И еще - если убираешь из конфига view, оставляешь только router bgp AS1 и route bgp AS2 то получаем:
Starting bgpd service: BGP view name and AS number mismatch
BGP instance is already running; AS is AS1
Edited by SystemSyn
Согласно документации Quagga насчет view маршруты и не должны попадать в kernel routes.
Вопрос об ошибке остается открытым. Для теста делаю конфиг из доки квагги:
router bgp 1
neighbor 10.0.0.1 remote-as 2
neighbor 10.0.0.2 remote-as 3
router bgp 2
neighbor 10.0.0.3 remote-as 4
neighbor 10.0.0.4 remote-as 5
получаю
BGP instance is already running; AS is 1
There is no such command.
Error occured during reading below line.
quagga-0.99.22
Видимо стоит смотреть в сторону Bird
Edited by SystemSyn
