Есть cisco 2921 с vic3-2fxs/did и c CUCME и cisco 2611 c платами NM-2V и vic-2fxs соеденины кошки без промежуточных устройств (через ethernet)на обоих прописаны пиры, пытаюсь их подружить по H323 , звонки проходят в обе стороны, а вот при подъёме трубки тишина, уже не знаю в какую сторону копать, может кто подскажет? Конфигурации ниже.
cisco 2921
card type e1 0 0
no aaa new-model
clock timezone MSK 4 0
network-clock-participate wic 0
ip dhcp excluded-address 10.10.10.1 10.10.10.4
ip dhcp excluded-address 10.10.10.251 10.10.10.254
ip dhcp excluded-address 172.17.0.1
ip dhcp pool IP-TELEFONE
import all
network 10.10.10.0 255.255.255.0
dns-server 10.10.10.1
option 150 ip 10.10.10.1
default-router 10.10.10.1
ip dhcp pool ANALOG-TLF
network 172.17.0.0 255.255.255.0
default-router 172.17.0.1
dns-server 172.17.0.1
ip cef
no ipv6 cef
multilink bundle-name authenticated
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix *
stcapp supplementary-services
port 0/2/0
fallback-dn 103
port 0/2/1
fallback-dn 104
stcapp call-control mode feature
isdn switch-type primary-net5
trunk group Test1
hunt-scheme round-robin
voice-card 0
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
registrar server
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 100
max-pool 50
tftp-path flash:
create profile sync 0225214008494712
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-28
description POTS
interface Loopback0
ip address 172.17.0.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.10.20.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.20.1
interface GigabitEthernet0/1
ip address 192.168.4.252 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
description POTS
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.4.254
ip route 172.17.1.0 255.255.255.0 10.10.20.2
control-plane
voice-port 0/0/0:15
description POTS
voice-port 0/2/0
cptone RU
timeouts ringing infinity
station-id name fax
station-id number 103
caller-id enable type 1
voice-port 0/2/1
cptone RU
station-id name fax1
station-id number 104
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local Loopback0
sccp ccm 10.10.10.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
port 0/2/0
dial-peer voice 2 pots
service stcapp
port 0/2/1
dial-peer voice 3 voip
destination-pattern 20.
session target ipv4:10.10.20.2
gateway
timer receive-rtp 1200
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 100
ip source-address 10.10.10.1 port 2000
max-redirect 5
cnf-file location flash:
load 6921 SCCP69xx.9-3-3-2-SR1.loads
load 6941 SCCP69xx.9-3-3-2-SR1.loads
load 6911 SCCP6911.9-3-1-SR1-3.loads
time-zone 35
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name vasy secret 5 $1$RvdT$sRUz8Hm3Ij6sjjmGLnXCG0
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 02 2013 13:56:15
ephone-dn 1 dual-line
number 101
name A A
ephone-dn 2
number 102
ephone-dn 3
number 103
label FAX_MASHINE
ephone-dn 4
number 104
label FAX_MASHINE-1
ephone 1
mac-address 5006.04FA.4F57
username "1"
type 6921
button 1:1
ephone 2
mac-address 64D9.89C3.CAF3
max-calls-per-button 2
username "2"
type 6911
button 1:2
ephone 3
mac-address 9F66.91A6.0100
type anl
button 1:3
ephone 4
mac-address 9F66.91A6.0101
type anl
button 1:4
cisco 2611
clock timezone moscow 3
ip subnet-zero
ip cef
ip name-server 192.168.3.1
voice-port 1/0/0
cptone RU
voice-port 1/0/1
cptone RU
destination-pattern 200
port 1/0/0
destination-pattern 201
port 1/0/1
destination-pattern 10.
ip precedence 5
session target ipv4:10.10.20.1
gateway
interface Loopback0
ip address 172.17.1.1 255.255.255.0
interface Ethernet0/0
ip address 10.10.20.2 255.255.255.0
no ip proxy-arp
half-duplex
h323-gateway voip interface
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 10.10.30.2 255.255.255.0
no ip proxy-arp
half-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.20.1
no ip http server
И ещё версия ios 2611 - c2600-is-mz.121-27b.bin у 2921 - c2900-universalk9_npe-mz.SPA.153-2.T.bin
Edited by sui245
