littlevik Posted November 22, 2013 Posted November 22, 2013 День добрый, коллеги. Вылезла с SE600 следующая проблема. Задача - раздать по DHCP из RADIUSа 2 сети по 2 VLANам, DHCP-server - сам SE. Делаю так: context local ! interface hnet-26-0 multibind ip address 172.26.0.1/24 dhcp server interface ! interface hnet-26-1 multibind ip address 172.26.1.1/24 dhcp server interface ! subscriber default qos policy policing default-input-policy qos policy metering default-output-policy dhcp max-addrs 1 ! dhcp relay option dhcp server policy option subnet-mask 255.255.255.0 default-lease-time 3600 subnet 172.26.0.0/24 range 172.26.0.2 172.26.0.254 option router 172.26.0.1 option domain-name-server 8.8.8.8 4.4.4.4 subnet 172.26.1.0/24 range 172.26.1.2 172.26.1.254 option router 172.26.1.1 option domain-name-server 4.4.4.4 8.8.8.8 ! ! ** End Context ** ! qos policy default-input-policy policing rate 512 burst 64000 rate-calculation exclude layer-2-overhead ! qos policy default-output-policy metering rate 512 burst 64000 rate-calculation exclude layer-2-overhead ! ! card 10ge-oc192-1-port 1 ! port ethernet 1/1 no shutdown encapsulation dot1q dot1q pvc 167 service clips dhcp context local dot1q pvc 168 service clips dhcp context local RADIUS в Access-Accept возвращает Acct-Interim-Interval = 900 Framed-IP-Address = 172.26.0.10 Framed-IP-Netmask = 255.255.255.0 DHCP_Max_Leases = 1 IP-Interface-Name = "hnet-26-0" сессия пытается подняться Acct-Update-Reason = AAA_LOAD_ACCT_SESSION_UP Acct-Update-Reason = AAA_LOAD_ACCT_DHCP_IP_ADDR_GRANTED но затем падает Acct-Update-Reason = AAA_LOAD_ACCT_SESSION_DOWN Acct-Terminate-Cause = User-Error Session-Error-Code = 196 Session-Error-Msg = "DHCP IP-host mismatch" В отладке точка отказа Nov 22 14:03:27: [0001]: [1/1:511:63:31/7/2/10]: %AAA-7-DHCP: aaa_idx 5000000b: aaa_update_dhcp_sub_circuit: CLIPS session e0:cb:4e:b2:bf:94 iphost 172.26.0.10 added successfully: init XC sync Nov 22 14:03:27: [1/1:511:63:31/7/2/10]: %AAA-7-AUTHEN: aaa_idx 5000000b: aaa_process_ipc_session_down: Received SESSION_DOWN msg extern_handle 262154 ep=15 Nov 22 14:03:27: [0001]: [1/1:511:63:31/7/2/10]: %AAA-7-AUTHEN: aaa_idx 5000000b: aaa_process_ipc_session_down: session_down_in_prog is set e0:cb:4e:b2:bf:94 Nov 22 14:03:27: %AAA-7-GEN: aaa_set_protocol_stack_debug_ctrs_all: Decrementing subscriber counters during sess-down for stack-type 1 Nov 22 14:03:27: [0001]: [1/1:511:63:31/7/2/10]: %AAA-7-DHCP: aaa_idx 5000000b: aaa_is_dhcp_clips_bounce_down: bounce flag 0 reason 0 class 0x20 tc 196 Конструкция с service clips только на одном pvc работает нормально port ethernet 1/1 no shutdown encapsulation dot1q dot1q pvc 167 dot1q pvc 168 service clips dhcp context local Явно прописывал маршруты, не помогает ip route 172.26.0.0/24 hnet-26-0 ip route 172.26.1.0/24 hnet-26-1 Други! Подскажите, где не доглядел-накосячил, реально уже весь мозг сломал. ПыСы. Пробовал на SEOS 6.4.1.4, 11.1.2.9 и 12.1.1.2 - разницы никакой, получается ошибка стратегическая... Вставить ник Quote
config Posted November 22, 2013 Posted November 22, 2013 Дебагайте dhcp . И попробуйте option subnet mask пропивать в разделах subnet. Делалось такое, за одним отличием : передавался с радиуса не interface name , a subscriber-profile nane , в про файле в свою очередь был прописаны нужный интерфейс. Работало и работает наверное . Вставить ник Quote
