Вот такое в логах
2013-11-20 11:05:45 | INFO | CPU #000 | EM Agent: PRPC connection to /10.1.1.2 closed OK: peer terminated connection: user request.
2013-11-20 11:08:43 | INFO | CPU #000 | EM Agent: admin was successfully authenticated for connection usr.install-pqi and was provided authorization level Admin (requested Admin)
2013-11-20 11:08:43 | INFO | CPU #000 | EM Agent: PRPC connection to /10.1.1.2 established, client name is usr.install-pqi, session name is rpc-4.
2013-11-20 11:08:46 | INFO | CPU #000 | Engage PQI Version 4.0.0 Build 81: Installation Started
2013-11-20 11:08:47 | INFO | CPU #000 | Starting application unload to slot 0.
2013-11-20 11:08:49 | INFO | CPU #000 | Starting application unload to slot 0.
2013-11-20 11:08:49 | INFO | CPU #000 | Configuration file '/apps/data/scos/system/p3hidden/config/applcfg.txt' was saved - files size = 399.
2013-11-20 11:08:49 | INFO | CPU #000 | Starting application load of application file: /apps/data/scos/app/en40081.sli to slot 0.
2013-11-20 11:09:15 | INFO | CPU #000 | Flow data-base (FC) activated. Containing 8000 flows
2013-11-20 11:09:23 | INFO | CPU #004 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:23 | INFO | CPU #006 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:23 | INFO | CPU #003 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:23 | INFO | CPU #005 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:24 | INFO | CPU #008 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:24 | INFO | CPU #010 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:24 | INFO | CPU #012 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:24 | INFO | CPU #007 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:24 | INFO | CPU #009 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:09:24 | INFO | CPU #011 | Flow data-base (FC) activated. Containing 688127 flows
2013-11-20 11:11:13 | ERROR | CPU #000 | SE Watchdog Module: An Error occurred. Please report to Cisco's customer support
2013-11-20 11:11:14 | WARN | CPU #000 | SE Watchdog Module: A problem occurred. Please report to Cisco's customer support
2013-11-20 11:11:14 | INFO | CPU #000 | Party data base was closed.
а потом в SCA-BB
+ 11/20/13 11:08:40 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Run PQI Installer
+ 11/20/13 11:08:40 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Saving the PQI file
+ 11/20/13 11:08:41 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Extracting installation files
+ 11/20/13 11:08:43 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Registering installation files
+ 11/20/13 11:08:43 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Verifying installation is allowed
+ 11/20/13 11:08:43 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Activating installation files
+ 11/20/13 11:11:14 AM MSK | ERROR | Updating software at "SCE8000 [10.1.10.202]": Failed to update software: Please check the device's version, status, connectivity and configuration (null ### java.lang.InterruptedException java.lang.InterruptedException)
+ 11/20/13 11:11:14 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Deleting PQI file from element
+ 11/20/13 11:11:14 AM MSK | INFO | Updating software at "SCE8000 [10.1.10.202]": Disconnecting from element
Edited by AntonS
System version: Version 4.0.0 Build 548
Build time: Jun 17 2013, 21:58:17 (Change-list 731556)
Software version is: Version 4.0.0 Build 548
Cryptography class: K9
Hardware information is:
Firmware
kernel : [kernel] 2.4.0/3 (inactive: [kernel] 2.4.0/3)
u-boot : [uboot] 2.1.0/1 (field: [uboot] 0.8.1/18)
select : [ubs-cf1] 2.4.0/3 (secondary: [ubs-cf1] 2.4.0/3)
Slot 1: SCE8000-SCM-E
serial-num : CAT1246G065
part-num : 73-10598-02
cpld : 0x8274
vtpld : 0xc004
summit-0 : 0xf2c1001
summit-1 : 0xf2c1101
dpt/tx : 0x4930
cls/ff : 0x211a
cls cam : 0x454120
cls flow cap: 67108864
ssa : 0x90
TVR
#cpus : 1
cpu SVR : 0x80900121
cpu PVR : 0x80040202
cpu freq : 1000MHz
cpu (eeprom): 2.1, 1000MHz
cpld : 0xa1bc
cpld-ufm : 0xa803
summit : 0xf2c1701
cf : Model=SILICONSYSTEMS INC 4GB-3213, S/N=B824418B5F4B0915LW02, FwRev=0x242-0230, Size=4125744KB
phy-0 : 0xcc2
phy-1 : 0xcc2
phy-2 : 0xcc2
CFC-0
board type : P2
#cpus : 3
cpu-0 SVR : 0x80900121
cpu-0 PVR : 0x80040202
cpu-0 freq : 1500MHz
cpu-1 SVR : 0x80900121
cpu-1 PVR : 0x80040202
cpu-1 freq : 1500MHz
cpu-2 SVR : 0x80900121
cpu-2 PVR : 0x80040202
cpu-2 freq : 1500MHz
cpu (eeprom): 2.1, 1500MHz
cpld-0 : 0xb219
cpld-1 : 0xb219
cpld-2 : 0xb219
cpld-0-ufm : 0xb803
cpld-1-ufm : 0xb803
cpld-2-ufm : 0xb803
summit-0 : 0xf2c1301
summit-1 : 0xf2c1401
fc : 0x1315
CFC-1
board type : P2
#cpus : 3
cpld-0 : 0xb219
cpld-1 : 0xb219
cpld-2 : 0xb219
cpld-0-ufm : 0xb803
cpld-1-ufm : 0xb803
cpld-2-ufm : 0xb803
fc : 0x1315
Slot 3: SCE8000-SIP
serial-num :
part-num : 73-10947-02
cpld : 0x9274
summit-0 : 0xf2c1501
summit-1 : 0xf2c1601
dpt-0 : 0x314c
dpt-1 : 0x314c
ssa-0 : 0x90
ssa-1 : 0x90
CIO RLDRAM : OK
spa[0] : SPA-1X10GE-L-V2
spa[1] : SPA-1X10GE-L-V2
spa[2] : SPA-1X10GE-L-V2
spa[3] : SPA-1X10GE-L-V2
SCE8000 Chassis
product-num : SCE8000
serial-num :
part-num :
part-rev : A0
vid : V01
Part number :
Revision : 1
Software revision : 1
LineCard S/N :
Power Supply type : AC
SML Application information is:
No application is configured.
Logger status: Enabled
Platform: SCE8000
Management agent interface version: SCE Agent 4.0.0 Build 115
Software package file: /apps/data/scos//images/SEOS.pkg
Из-за билда не подходит?
  • 2 weeks later...
Тоже самое с другой версией 3.85
+ 11/28/13 4:13:10 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Run PQI Installer
+ 11/28/13 4:13:10 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Saving the PQI file
+ 11/28/13 4:13:12 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Extracting installation files
+ 11/28/13 4:13:13 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Registering installation files
+ 11/28/13 4:13:13 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Verifying installation is allowed
+ 11/28/13 4:13:13 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Activating installation files
+ 11/28/13 4:15:44 PM MSK | ERROR | Updating software at "SCE device [10.1.10.202]": Failed to update software: Please check the device's version, status, connectivity and configuration (null ### java.lang.InterruptedException java.lang.InterruptedException)
+ 11/28/13 4:15:44 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Deleting PQI file from element
+ 11/28/13 4:15:44 PM MSK | INFO | Updating software at "SCE device [10.1.10.202]": Disconnecting from element
copy ftp://ftpdefaultdire.../<filename.pqi> /apps/data/scos/app/
если делать так
то долго думает
а потом
SCE8000#copy ftp://10.1.1.2/en38553.pqi /apps/data/scos/app/
Error - could not open ftp://10.1.1.2/en38553.pqi
в логах
2013-11-28 17:34:58 | INFO | CPU #000 | File system operation : copy ftp://10.1.1.2/en38553.pqi /apps/data/scos/app/en38553.pqi
