Начал периодически пропадать из сети. Обновили до S2950-24G_7.0.3.1%28R0058.0003%29.zip, лучше не стало, так же перегружается сам и часто не доступен.
Вот что есть с консоли:
signal Num 11, Instruction address 0x732148, Stack Pointer 0x1e5b878
Data Access Register 0x1255c2c8
%Jan 01 08:00:46 2006 WD log begin
task: zNSM
status:SUSPEND
Stack trace:
0x73214c  ./nos(thread_process_fd+0xb4) [0x73214c]
0x7325fc  ./nos(thread_fetch+0x2f0) [0x7325fc]
0x6983a4  ./nos(nsm_main+0x24c) [0x6983a4]
0x697b00  ./nos(nsm_entry+0x48) [0x697b00]
0x78edec  ./nos(task_wrapper+0x98) [0x78edec]
0x2aaf4b88  /lib/libpthread.so.0 [0x2aaf4b88]
zero =0,at =1000fc01,v0 =41c0276,v1 =1255c2c8,
a0 =83804ec1,a1 =107009d8,a2 =1e607d4,a3 =1e607cc,
s0 =1,s1 =83badf1c,s2 =0,s3 =fffffff8,
s4 =1e5b4f8,s5 =2ab1d020,s6 =16d0000,s7 =1,
s0 =1e6bbf0,s1 =0,s2 =0,s3 =1e607cc,
s4 =1e5b8f0,s5 =1,s6 =1e60790,s7 =1e60720,
t8 =0,t9 =2aaf7fe0,k0 =0,k1 =0,
gp =1635390,sp =1e5b878,s8 =1225b48,ra =7325fc,
epc =732148, badvaddr =1255c2c8
WD log end
nos exit(SIGALRM)!
Segmentation fault (core dumped)
[1]+  Done                       ./nos
/ # dir
-/bin/sh: dir: not found
/ # pwd
/ # ls
bin                         nos_console
core-reboot-300-2206224083  proc
dev                         root
etc                         sbin
home                        sys
init                        tmp
lib                         usr
mnt                         var
nos
Mem: 29136K used, 30508K free, 0K shrd, 24K buff, 27292K cached
CPU:  0.1% usr  0.5% sys  0.0% nic 99.2% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 0.03 0.85 0.63 1/15 317
 PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
 313   305 0        R     2728  4.5   0  0.2 top
 202     1 0        S     2728  4.5   0  0.0 -/bin/sh
 305   202 0        S     2728  4.5   0  0.0 sh
   1     0 0        S     2664  4.4   0  0.0 init
   4     1 0        SW       0  0.0   0  0.0 [khelper]
 165     1 0        SW       0  0.0   0  0.0 [ftld]
 164     1 0        SW       0  0.0   0  0.0 [mtdblockd]
   2     1 0        SW       0  0.0   0  0.0 [ksoftirqd/0]
   3     1 0        SW       0  0.0   0  0.0 [events/0]
   5     1 0        SW       0  0.0   0  0.0 [kthread]
  14     5 0        SW       0  0.0   0  0.0 [kblockd/0]
  53     5 0        SW       0  0.0   0  0.0 [pdflush]
  54     5 0        SW       0  0.0   0  0.0 [pdflush]
  55     5 0        SW       0  0.0   0  0.0 [kswapd0]
  56     5 0        SW       0  0.0   0  0.0 [aio/0]
 PID USER       VSZ STAT COMMAND
   1 0         2664 S    init
   2 0            0 SW   [ksoftirqd/0]
   3 0            0 SW   [events/0]
   4 0            0 SW   [khelper]
   5 0            0 SW   [kthread]
  14 0            0 SW   [kblockd/0]
  53 0            0 SW   [pdflush]
  54 0            0 SW   [pdflush]
  55 0            0 SW   [kswapd0]
  56 0            0 SW   [aio/0]
 164 0            0 SW   [mtdblockd]
 165 0            0 SW   [ftld]
 202 0         2728 S    -/bin/sh
 305 0         2728 S    sh
 319 0         2728 R    ps
/ # dmesg
tions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 256 (order: 8, 1024 bytes)
RTC: 0/0/2040, 0:00:00
CPU: BCM4704 rev 9 at 200 MHz
Using 100.000 MHz high precision timer.
hwtimer: Added BCM95836 CPCI timer (BCM95836_CPCI Kernel jiffy timer) at index=0
Console: colour dummy device 80x25
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 53704k/62464k available (1760k kernel code, 8700k reserved, 343k data, 5880k init, 0k highmem)
Calibrating delay loop... 199.47 BogoMIPS (lpj=997376)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
registering PCI controller with io_map_base unset
Time: MIPS clocksource has been installed.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
io scheduler noop registered
io scheduler anticipatory registered (default)
PCI: Fixing up bridge
Generic RTC Driver v1.07
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO map 0x0 mem 0xb8000300 (irq = 3) is a 16550A
serial8250: ttyS1 at MMIO map 0x0 mem 0xb8000400 (irq = 3) is a 16550A
interleave:2, device_type:1
val[0]:0x51, val[0]:0x52, val[0]:0x59
interleave:2, device_type:2
val[0]:0x167, val[0]:0x0, val[0]:0x165
interleave:2, device_type:4
val[0]:0x157, val[0]:0x155, val[0]:0x153
interleave:1, device_type:2
Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
val[0]:0x16f, val[0]:0x1000, val[0]:0x0
Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Flash device: 0x800000 at 0x1c000000
Creating 2 MTD partitions on "Physically mapped flash":
0x00000000-0x00100000 : "flash0:"
ftla: ftla1
0x00100000-0x00800000 : "flash:"
ftlb: ftlb1
TCP cubic registered
Freeing unused kernel memory: 5880k freed
linux-kernel-bde (191): found robo device with 0:0143:bf15:0000:00
interrupt_connect: connected IRQ - 5
Cpu 0
$ 0   : 00000000 1000fc01 041c0276 1255c2c8
$ 4   : 83804ec1 107009d8 01e607d4 01e607cc
$ 8   : 00000001 83badf1c 00000000 fffffff8
$12   : 01e5b4f8 2ab1d020 016d0000 00000001
$16   : 01e6bbf0 00000000 00000000 01e607cc
$20   : 01e5b8f0 00000001 01e60790 01e60720
$24   : 00000000 2aaf7fe0
$28   : 01635390 01e5b878 01225b48 007325fc
Hi    : 0000001a
Lo    : 00000006
epc   : 00732148 0x732148     Not tainted
ra    : 007325fc 0x7325fc
Status: 0000fc13    USER EXL IE
Cause : 00000008
BadVA : 1255c2c8
PrId  : 00029006
Modules linked in: interrupt_kernel reserved_ram_kernel linux_user_bde linux_kernel_bde
Process nos (pid: 289, threadinfo=83bac000, task=83ba17f0)
Stack :
    0x01e5b878:  00000001 008b5ee4 01635390 01e5b8bc 01635390 000005ff 00000000 01e6bbb8
    0x01e5b898:  01e60754 01e60720 00000004 01e60750 01e5b8d8 01e607a8 01e607cc 007325fc
    0x01e5b8b8:  00000001 00000038 019eded0 000005e2 01e5b8e0 00000033 01635390 01e76cd8
    0x01e5b8d8:  83804ec2 000005f8 00000006 00069ca4 00000000 00000000 00000000 00020000
    0x01e5b8f8:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x01e5b918:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x01e5b938:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x01e5b958:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x01e5b978:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x01e5b998:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x01e5b9b8:  00000000 01e5a980 01e607b4 01e6079c 01e60790 01e60784 01e60738 01e6072c
    0x01e5b9d8:  01e60778 01e60810 01e5b8f0 01e6080c 01e5b934 01e60850 01e60854 01e5b978
    0x01e5b9f8:  01e60894 01e5b8e8 01e5b8e0 01e5ba48 01e5ba48 01e5da80 01650000 00000000
    0x01e5ba18:  00000000 00000a29 00000000 00408fd0 2aaca2d8 006983a4 eeeeeeee 01e5ba48
    0x01e5ba38:  eeeeeeee eeeeeeee 01635390 eeeeeeee 00000000 00000000 01e60720 01e5da80
    0x01e5ba58:  0069f62c 01e6b780 04010200 83804ec1 000f3067 eeeeeeee 00000000 01e5cbe8
    0x01e5ba78:  2aaf4ac8 003d0f00 00000000 01e5cbfc 2ab1e000 00697b00 eeeeeeee eeeeeeee
    0x01e5ba98:  eeeeeeee eeeeeeee 00000a29 00000000 011ed96c 00000000 01635390 eeeeeeee
    0x01e5bab8:  eeeeeeee 0078edec eeeeeeee eeeeeeee eeeeeeee eeeeeeee 00000000 00000000
    0x01e5bad8:  00000000 00000000 00000000 00000000 01635390 eeeeeeee 2accb950 00000000
    0x01e5baf8:  2ab15000 2aaf4b88 eeeeeeee eeeeeeee eeeeeeee eeeeeeee 2ab1d020 eeeeeeee
    0x01e5bb18:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bb38:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bb58:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bb78:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bb98:  2aaf4b4c 01e5bb00 01e5c0b0 2ab15000 2aaf4ac8 003d0f00 00000000 01e5cbfc
    0x01e5bbb8:  2ab1e000 00408fd0 2aaca2d8 2accb950 eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bbd8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bbf8:  eeeeeeee eeeeeeee 00000000 eeeeeeee 00000000 00000000 eeeeeeee eeeeeeee
    0x01e5bc18:  01e5c0b0 eeeeeeee 01e5c0b0 2ab15000 2aaf4ac8 2ac3e4e8 01e5c0b0 01e5c0b0
    0x01e5bc38:  003d0f00 eeeeeeee eeeeeeee eeeeeeee eeeeeeee 2accb950 eeeeeeee eeeeeeee
    0x01e5bc58:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bc78:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bc98:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bcb8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bcd8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bcf8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bd18:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bd38:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bd58:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bd78:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bd98:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bdb8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bdd8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bdf8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5be18:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5be38:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5be58:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5be78:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5be98:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5beb8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bed8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bef8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bf18:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bf38:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bf58:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bf78:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bf98:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bfb8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bfd8:  eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee eeeeeeee
    0x01e5bff8:  eeeeeeee eeeeeeee
Call Trace:
Code: 00041142  00022880  02851821 <8c620000> 3083001f  00621006  30420001  1040fff4  02653021
Cpu 0
$ 0   : 00000000 1000fc00 2aaca2d0 0000d3a8
$ 4   : 004960fb 7fc957a0 0000000a 00000000
$ 8   : 2ab1f540 00000002 00000072 7fc956a0
$12   : ffffffff 7fc955f8 2aab2a20 f0000000
$16   : 00000000 00496018 7fc95890 ffffffff
$20   : 0000d3a8 00010121 00000000 00496030
$24   : 000000d7 2ab52730
$28   : 2ac95950 7fc95718 004960fb 2ab51fb8
Hi    : 000001e5
Lo    : 0002af19
epc   : 2ab52778 0x2ab52778     Not tainted
ra    : 2ab51fb8 0x2ab51fb8
Cause : 00000008
BadVA : 0000d3ac
PrId  : 00029006
Process reboot (pid: 300, threadinfo=824aa000, task=824a9be8)
Stack :
    0x7fc95718:  00402699 2aad99f8 7fc95740 2aad9c78 2ac95950 00000001 00000000 00000000
    0x7fc95738:  00000000 00496018 7fc95890 ffffffff 0047c610 00010121 00000000 00496030
    0x7fc95758:  00000020 2ab51fb8 004960d0 7fc957a0 ffff9008 00000002 0000d3a8 7fc957a0
    0x7fc95778:  2ac95950 6e75782d 2aae1010 0040a334 2ac95950 00408804 00402b5c 7fc957cc
    0x7fc95798:  0049b1f0 7fc95890 ffffffff 0047c610 7fc957cc 0046d520 ffffffff 7fc95778
    0x7fc957b8:  2aab2a20 f0000000 0049b1f0 27d5ae07 7fc95820 2aab2c68 7fc95828 00000000
    0x7fc957d8:  00000001 00000000 7fc957e8 2aab337c 00000000 00000000 2aad9510 2aab6c34
    0x7fc957f8:  7fc95828 2aad9c1c 00000000 2aac99a0 00000000 00000000 2ac95950 2aad9510
    0x7fc95818:  2aae1010 2ac8c000 2aae1010 2aac9974 00000002 00000004 00000000 2aab30ac
    0x7fc95838:  2aae1010 00000000 2aab7c50 7fc95810 2aae1010 0040016c 00000000 00000000
    0x7fc95858:  00000000 000003d5 2aac99a0 2aac95f0 2ac95950 2ab27ee0 004013e8 00000001
    0x7fc95878:  00000001 2ab1f540 00000002 7fc958f8 ffffffff 7fc95850 2aab2a20 f0000000
    0x7fc95898:  2aad9c78 3eb3f776 7fc958f8 2aab2c68 7fc95900 00000000 00000001 00000000
    0x7fc958b8:  7fc958c0 2aab337c 2ac90000 6e652900 2ac95950 0000002b 7fc95900 2aad9c1c
    0x7fc958d8:  00000000 2aac99a0 00000000 00000000 00000001 00000000 2aae1010 00000000
    0x7fc958f8:  0c6beb30 0047cb6c 2ab23290 2aac95f0 2ab2e908 2aad9510 2aae1010 00000016
    0x7fc95918:  00000000 00000000 0049b1f0 00000006 7fc95d14 64020000 00000001 00000000
    0x7fc95938:  00000000 00000000 7fc95d20 00000000 00000000 00000036 00000040 00493200
    0x7fc95958:  00000079 00000001 0000006b 7fc95ec4 2aaca2d8 2aabf6e0 00402e85 2aad99f8
    0x7fc95978:  7fc95998 2aad9c78 2aac99a0 00000001 00000000 00000000 2aae1010 00000000
    0x7fc95998:  2ab23290 69000000 7fc959f8 00000002 2ac95950 2ac4d174 00480c96 2aabf4e8
    0x7fc959b8:  7fc959f8 000002c9 00000002 2aad8f00 00480c96 00000001 0000006b 7fc95ec4
    0x7fc959d8:  2aaca2d8 00460b60 00000000 7fc959f8 00000000 00000000 0049b1f0 00000000
    0x7fc959f8:  00010000 00000000 7e7e0000 00000000 00000000 00000000 00000000 00000000
    0x7fc95a18:  00000000 00000000 7e7e0000 73687574 646f776e 00000000 00000000 00000000
    0x7fc95a38:  00000000 00000000 00000000 322e362e 32312e31 00000000 00000000 00000000
    0x7fc95a58:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x7fc95a78:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x7fc95a98:  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0x7fc95ab8:  2aae1010 00000000 2aae1010 2aac9974 00000002 00000004 00000000 2aab30ac
    0x7fc95ad8:  00000000 00000000 00000000 00000000 2aae1010 00000000 00000000 00000000
    0x7fc95af8:  00000000 00000880 2aac99a0 2aac95f0 00402633 2ab27ee0 00401668 00000001
    0x7fc95b18:  00000000 2ab1f540 00000002 7fc95b98 ffffffff 7fc95af0 2aab2a20 f0000000
    0x7fc95b38:  2aad9c78 0d39ad3d 7fc95b98 2aab2c68 7fc95ba0 00000000 00000001 00000000
    0x7fc95b58:  7fc95b60 2aab337c 00000000 00000000 00000000 00000000 7fc95ba0 2aad9c1c
    0x7fc95b78:  00000000 2aac99a0 00000000 00000000 00000001 2aac95f0 2aae1010 2ab27ee0
    0x7fc95b98:  07383353 00000001 2ab27d40 2aac95f0 00000002 7fc95c20 2ac95950 7fc95b78
    0x7fc95bb8:  2aab2a20 00000000 2ac8d94c 2ab9e8e8 7fc95c20 2aab2c68 7fc95c28 00000000
    0x7fc95bd8:  2ac95950 00000000 7fc95be8 2ab9b9e4 00000000 00000036 00000040 00493200
    0x7fc95bf8:  000000a1 00000001 2ac95950 7fc95ec4 00000fff 00000000 00000020 2aad99f8
    0x7fc95c18:  2ac95950 2aad9c78 2aac99a0 00000001 00000004 2ac8f64c 00000002 2ab9aa64
    0x7fc95c38:  0047c610 00000001 0000006b 7fc95ec4 2aaca2d8 2ab9d608 0000006b 00000004
    0x7fc95c58:  2aaca2d8 2ab9d8cc 2ac95950 00000000 00000004 00000004 00000002 2aad8f00
    0x7fc95c78:  0047c610 00408ff8 0000014c 00000001 0000006b 7fc95ec4 2aaca2d8 00000000
    0x7fc95c98:  00010120 7fc95800 00000000 00000000 00000000 00496008 0047c610 00407438
    0x7fc95cb8:  004717b0 0046d3a4 00010121 00465628 00000000 000002c9 00000002 2aad8f00
    0x7fc95cd8:  0049b1f0 2aabf4e8 00000000 000002c9 00000002 2aad8f00 00480c96 00000001
    0x7fc95cf8:  0000006b 7fc95ec4 2aaca2d8 00460c5c 7fc95ec4 2ab4e8b4 7fc95d20 00000001
    0x7fc95d18:  0049b1f0 2aad8f00 00000000 2aabf4e8 7fc95ec4 000002c9 004963b4 00406c48
    0x7fc95d38:  2aad8f00 00480c96 00000008 004778f8 0049b1f0 0040634c 00000000 7fc95ec4
    0x7fc95d58:  7fc95f76 004963b4 2aad8f00 00480c96 00000008 004778f8 00408fd0 00406cbc
    0x7fc95d78:  00480c96 2aabf4e8 fffffffd 2aad8f00 0049b1f0 00000008 2ac95950 0000002f
    0x7fc95d98:  00000043 7fc95f76 00490000 7fc95ec4 004963b4 2aad8f00 00480c96 00000008
    0x7fc95db8:  004778f8 00408fd0 2aaca2d8 00407280 0049b1f0 7fc95f76 7fc95ec4 00406048
    0x7fc95dd8:  0049b1f0 004963b4 2ac95950 00406048 00403590 2ab329ac 2aafbff0 00000001
    0x7fc95df8:  7fc95ec4 2aac9298 2ac95950 2aada830 2ab32964 7fc95df0 00406048 00403590
    0x7fc95e18:  004963b4 2aad8f00 00480c96 00000008 004778f8 00408fd0 2aaca2d8 2ac95950
    0x7fc95e38:  7fc95e58 2aad9c78 2aac99a0 00000001 00000000 00000000 2aae1010 7fc95ecc
    0x7fc95e58:  2ab23430 2aab82d8 2aae1010 00403590 004963b4 00480c96 00000000 2aabf4e8
    0x7fc95e78:  00000000 00000000 00403590 004963b4 004071e0 2aae1010 00403590 004963b4
    0x7fc95e98:  00480c96 004035e8 004071e0 00000001 7fc95ec4 2aaa8868 00406040 2aab874c
    0x7fc95eb8:  7fc95ea0 7fc95ec0 00000001 7fc95f76 00000000 7fc95f7d 7fc95f87 7fc95f8e
    0x7fc95ed8:  7fc95fa1 7fc95fad 7fc95fb8 7fc95fdb 7fc95fe9 00000000 00000010 00000000
    0x7fc95ef8:  00000006 00001000 00000011 00000064 00000003 00400034 00000004 00000020
    0x7fc95f18:  ...
Call Trace:
Code: 8fb40058  0080f021  afa5004c <8e840004> 14e000d4  00008821  0000b821  04c0002d  24020001
процесс загрузки:
Testing RAM...
0x01000000 RAM OK.
Loading flash:/nos.img ...
## Booting kernel from Legacy Image at 82000100 ...
  Image Name:   Linux-2.6.21
  Created:      2013-06-09   9:42:47 UTC
  Image Type:   MIPS Linux Kernel Image (lzma compressed)
  Data Size:    6658918 Bytes = 6.4 MiB
  Load Address: 80001000
  Entry Point:  80210000
  Verifying Checksum ... OK
  Uncompressing Kernel Image ... OK
Starting kernel ...
BusyBox v1.19.3 (2012-06-14 09:58:25 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Current time is Sun Jan 01 00:00:00 2006
SNR-S2950-24G Series Switch Operating System
Software Version 7.0.3.1(R0058.0003)
Compiled Jun 09 17:10:14 2013
26 Ethernet/IEEE 802.3 interface(s)
Mac Addr 00-03-0f-29-61-f6
recv signal 11, tid 289
дальше в ребут уходит и через несколько ребутов может загрузиться и поработать немного. Либо совсем зависнуть.
Как победить его?
Edited by Slad
