LinuxLoader Posted November 14, 2013 Posted November 14, 2013 Тестовая конфигурация клипы + радиус auth при нормальных порта работает правилна , если LACP не все работает правильн . Сесий up ип ест , qos ну какга изполнит командой show subscriber нет старт тиме. Здрес конфиг ааа + lacp aaa authentication administrator local aaa authentication subscriber radius aaa accounting subscriber radius attribute-guided aaa accounting reauthorization subscriber radius aaa update subscriber 11 aaa accounting event dhcp aaa accounting event reauthorization aaa accounting event ancp aaa reauthorization bulk radius aaa hint ip-address link-group CLIPS access encapsulation dot1q dot1q pvc 870 encapsulation 1qtunnel dot1q pvc 870:555 service clips dhcp context xxxxxx dot1q pvc 2319 service clips dhcp context xxxxxx maximum-links 2 lacp active sh sub clips lg id 30 vlan-id 870:555 c 70:54:f5:7d:e9:be xxxxx (AUTHENTICATING clips lg id 30 vlan-id 2319 clip 00:0c:42:a8:71:df xxxxx (AUTHENTICATING 00:0c:42:a8:71:df Session state Authenticated Circuit lg id 30 vlan-id 2319 clips 521800 Internal Circuit 255/22:1:31/7/2/60167 Interface bound vlan-multibind Current port-limit unlimited Protocol Stack not set dhcp max-addrs 1 (applied) dhcp option client id 0x3d0701000c42a871df (applied) dhcp option hostname 0x0c114d696b726f74696b426c61636b54657374 (applied) qos-metering-policy outbound-radius (applied) qos-policing-policy inbound-radius (applied) qos rate inbound rate 5120 burst 1000000 (applied) qos rate outbound rate 5120 burst 1000000 (applied) forward policy in captive-portal-redirect-inetgrp [svc mask: 0x0001] (applied) http-redirect-url http://xxxxx:4040/ [svc mask: 0x0001] (applied) ip access-group in captive-redirect-inetgrp [svc mask: 0x0001] (applied) service (applied) [svc id: 0] inetgrp-redirect (acct enabled) service-parameter (applied) [svc id: 0] redirect-url=http://xxxxx:4040/ [svc id: 0] portal-ip=xxxxxx [svc id: 0] portal-port=4040 [svc id: 0] tcp-port=www,443,4040,8080 dynamic policy acl [svc mask: 0x0001] (applied in: fwd) [svc id: 0] ip in forward dstip 178.169.169.218/16 tcp dstport = 4040 class portal fwd [svc id: 0] ip in forward tcp dstport = www class redirect-inetgrp fwd [svc id: 0] ip in forward tcp dstport = 443 class redirect-inetgrp fwd [svc id: 0] ip in forward tcp dstport = 4040 class redirect-inetgrp fwd [svc id: 0] ip in forward tcp dstport = 8080 class redirect-inetgrp fwd service-acct (in) [svc mask: 0x0001] (applied) [svc id: 0] fwd class-mask 0x01 service-abs-timeout [svc mask: 0x0001] (applied) [svc id: 0] 2147483647 service-interim-acct-interval [svc mask: 0x0001] (applied) [svc id: 0] 900 IP host entries installed by DHCP: (max_addr 1 cur_entries 1) 178.169.174.29 00:0c:42:a8:71:df ICMP is permited and ping is going perfect . any ideas ? Вставить ник Quote
vurd Posted November 14, 2013 Posted November 14, 2013 Мой мозг. Исправьте орфографию, ничего не понятно. Что у вас там рбт, чт н робт. Вставить ник Quote
LinuxLoader Posted November 15, 2013 Author Posted November 15, 2013 Проблем в тот что сеанса клиента, когда он был он clips lacp ( link-group access economical ) нет времени начнется, (и у них есть все необходимые правила QoS/IP/если нужна http-redirect, но не время начала), тот же простой dot1q pvc работает без проблем. Вставить ник Quote
LinuxLoader Posted November 15, 2013 Author Posted November 15, 2013 Странно то, что clips lg id 31 vlan-id 2319 clip 00:0c:42:a8:71:df xxxxxx(AUTHENTICATING) sh sub act 00:0c:42:a8:71:df Session state Authenticated Circuit lg id 31 vlan-id 2319 clips 412304 Вставить ник Quote
shicoy Posted November 17, 2013 Posted November 17, 2013 Блин учитесь писать понятно. Прочитал пару раз от и до и тоже не понятно, что у увас не работает. Или вы словарем на русский переводите? Вставить ник Quote
zstas Posted November 17, 2013 Posted November 17, 2013 я думаю это иностранец переводит через гугл транслейт. напишите на родном языке чтоли) Вставить ник Quote
ichthyandr Posted November 19, 2013 Posted November 19, 2013 ... in english plz :) Вставить ник Quote
snark Posted February 28, 2014 Posted February 28, 2014 @LinuxLoader Write your questions in english. Вставить ник Quote
