здравствуйте, проблема такая есть коммутатор:
SNR-S3750G-48S-E#sh version
 SNR-S3750G-48S-E Device, Compiled on May 16 20:30:00 2013
 sysLocation Ak.Vonsovskogo str. 1-118, Ekaterinburg, Russia
 CPU Mac f8:f0:82:10:18:d1
 Vlan MAC f8:f0:82:10:18:d0
 SoftWare Version 7.0.3.1(R0058.0002)
 BootRom Version 7.1.4
 HardWare Version 1.0.2
 CPLD Version N/A
 Serial No.:SW032810D610000106
 Copyright (C) 2013 NAG LLC
 All rights reserved
 Last reboot is cold reset.
 Uptime is 1 weeks, 1 days, 0 hours, 46 minutes
на нем поднят BGP, OSPF , spanning-tree mode rstp.
При смене топологи в сети постепенно начинает падать линк, сначала пинги увеличиваются, минут через 10 связь вообще пропадает. после того как я рву связь на комутаторе с которым он соединен
conf t
int gi 3/12
sh
no sh
связь восстанавливается
SNR-S3750G-48S-E# show running-config
spanning-tree
spanning-tree priority 8192
Interface Ethernet1/0/7
description 24_lan
switchport mode trunk
switchport trunk allowed vlan 524;808
switchport trunk native vlan 808
Interface Ethernet1/0/8
description 24_lan
Interface Ethernet1/0/48
description link to cisco
no spanning-tree
switchport trunk allowed vlan 202
interface Vlan524
ip address 10.24.0.1 255.255.0.0
ip address 91.219.139.97 255.255.255.240 secondary
interface Vlan808
description default vlan for 10.24.0.0
ip address 192.168.162.1 255.255.255.0
router ospf 1
ospf router-id 91.219.136.131
passive-interface Vlan524
passive-interface Vlan526
passive-interface Vlan527
passive-interface Vlan528
passive-interface Vlan529
passive-interface Vlan531
passive-interface Vlan532
passive-interface Vlan525
passive-interface Vlan1
passive-interface Vlan806
passive-interface Vlan807
passive-interface Vlan808
passive-interface Vlan809
passive-interface Vlan810
network 10.0.0.0 0.255.255.255 area 0
network 91.219.136.0 0.0.3.255 area 0
network 91.237.220.0 0.0.3.255 area 0
network 192.168.0.0 0.0.255.255 area 0
router bgp 51655
bgp log-neighbor-changes
neighbor 91.219.136.141 remote-as 51655
neighbor 91.219.136.141 description "shaper2"
neighbor 91.219.136.141 weight 1
neighbor 91.219.136.141 next-hop-self
neighbor 91.219.136.142 remote-as 51655
neighbor 91.219.136.142 description "shaper1"
neighbor 91.219.136.142 next-hop-self
ip route 10.0.0.0/8 null0
ip route 10.220.0.0/16 91.219.136.129
ip route 69.167.150.99/32 91.219.136.129
ip route 69.167.154.0/24 91.219.136.129
ip route 91.219.136.0/22 null0
ip route 91.237.220.0/22 null0
ip route 159.253.19.190/32 91.219.136.129
ip route 172.16.0.0/12 91.219.136.129
ip route 172.32.0.0/24 91.219.136.129
ip route 192.168.0.0/16 null0
ip route 192.168.168.1/32 91.219.136.129
ip route 192.168.225.0/24 91.219.136.129
ip route 193.33.232.0/23 91.219.136.129
Подскажите пожалуйста причину разрыва связи
Edited by AlexSt
Как то странно звучит)) либо он есть, либо его нет. Постепенно он падать не может. А в логах есть чего нибудь?
чтобы было понятно
64 bytes from 91.219.136.131: icmp_req=1 ttl=63 time=1.21 ms
64 bytes from 91.219.136.131: icmp_req=2 ttl=63 time=1.22 ms
64 bytes from 91.219.136.131: icmp_req=3 ttl=63 time=1.63 ms
64 bytes from 91.219.136.131: icmp_req=4 ttl=63 time=1.16 ms
64 bytes from 91.219.136.131: icmp_req=5 ttl=63 time=1.31 ms
64 bytes from 91.219.136.131: icmp_req=6 ttl=63 time=1.19 ms
64 bytes from 91.219.136.131: icmp_req=7 ttl=63 time=1.20 ms
64 bytes from 91.219.136.131: icmp_req=8 ttl=63 time=1.28 ms
64 bytes from 91.219.136.131: icmp_req=9 ttl=63 time=1.17 ms
64 bytes from 91.219.136.131: icmp_req=10 ttl=63 time=1.17 ms
64 bytes from 91.219.136.131: icmp_req=11 ttl=63 time=1.26 ms
64 bytes from 91.219.136.131: icmp_req=12 ttl=63 time=1.30 ms
64 bytes from 91.219.136.131: icmp_req=13 ttl=63 time=1.27 ms
64 bytes from 91.219.136.131: icmp_req=14 ttl=63 time=1.24 ms
64 bytes from 91.219.136.131: icmp_req=15 ttl=63 time=3.25 ms
64 bytes from 91.219.136.131: icmp_req=16 ttl=63 time=89.9 ms
64 bytes from 91.219.136.131: icmp_req=17 ttl=63 time=86.6 ms
64 bytes from 91.219.136.131: icmp_req=18 ttl=63 time=227 ms
64 bytes from 91.219.136.131: icmp_req=19 ttl=63 time=150 ms
64 bytes from 91.219.136.131: icmp_req=20 ttl=63 time=177 ms
64 bytes from 91.219.136.131: icmp_req=21 ttl=63 time=259 ms
64 bytes from 91.219.136.131: icmp_req=22 ttl=63 time=261 ms
64 bytes from 91.219.136.131: icmp_req=23 ttl=63 time=242 ms
64 bytes from 91.219.136.131: icmp_req=24 ttl=63 time=193 ms
64 bytes from 91.219.136.131: icmp_req=25 ttl=63 time=293 ms
64 bytes from 91.219.136.131: icmp_req=26 ttl=63 time=351 ms
Затем вообще потери увеличиваются до полного пропадания связи
на 14 реквесте перезагружаю комутатор L2 в кольцевой топологии
а ето после релинка вручную
64 bytes from 91.219.136.131: icmp_req=62 ttl=63 time=217 ms
64 bytes from 91.219.136.131: icmp_req=63 ttl=63 time=335 ms
64 bytes from 91.219.136.131: icmp_req=64 ttl=63 time=404 ms
64 bytes from 91.219.136.131: icmp_req=101 ttl=63 time=1.26 ms
64 bytes from 91.219.136.131: icmp_req=102 ttl=63 time=1.20 ms
64 bytes from 91.219.136.131: icmp_req=103 ttl=63 time=1.15 ms
64 bytes from 91.219.136.131: icmp_req=104 ttl=63 time=1.23 ms
64 bytes from 91.219.136.131: icmp_req=105 ttl=63 time=1.49 ms
64 bytes from 91.219.136.131: icmp_req=106 ttl=63 time=1.17 ms
64 bytes from 91.219.136.131: icmp_req=107 ttl=63 time=1.13 ms
64 bytes from 91.219.136.131: icmp_req=108 ttl=63 time=1.52 ms
64 bytes from 91.219.136.131: icmp_req=109 ttl=63 time=1.15 ms
64 bytes from 91.219.136.131: icmp_req=110 ttl=63 time=1.20 ms
64 bytes from 91.219.136.131: icmp_req=111 ttl=63 time=1.17 ms
А с физическим линком все в порядке
Edited by AlexSt
В том то и дело что на интерфейсе нет рстп из конфига видно, почему при перестройки топологии участвует этот интерфейс? может опцию
какую прилепить типа портфаст?
Edited by AlexSt
