myst Posted October 16, 2013 Posted October 16, 2013 Пытаюсь сделать аггрегированый канал между SRX650 и h3c5600 SRX: set interfaces ge-2/0/10 gigether-options 802.3ad ae4 set interfaces ge-2/0/11 gigether-options 802.3ad ae4 set interfaces ae4 aggregated-ether-options link-speed 1g set interfaces ae4 aggregated-ether-options lacp active set interfaces ae4 aggregated-ether-options lacp periodic slow set interfaces ae4 unit 0 family ethernet-switching port-mode access set interfaces ae4 unit 0 family ethernet-switching vlan members SSERVERS set interfaces vlan unit 888 family inet filter input packet-mode-filter set interfaces vlan unit 888 family inet filter output packet-mode-filter set interfaces vlan unit 888 family inet address 10.30.30.2/24 set vlans SSERVERS vlan-id 888 set vlans SSERVERS interface ae4.0 set vlans SSERVERS l3-interface vlan.888 srx650#run show interfaces ae4 Physical interface: ae4, Enabled, Physical link is Up Interface index: 174, SNMP ifIndex: 591 Description: # Etherchannel to SuperServers # Link-level type: Ethernet, MTU: 1514, Speed: 2Gbps, BPDU Error: None, MAC-REWRITE Error: None, Loopback: Disabled, Source filtering: Disabled, Flow control: Disabled, Minimum links needed: 1, Minimum bandwidth needed: 0 Device flags : Present Running Interface flags: SNMP-Traps Internal: 0x0 Current address: [b]b0:c6:9a:86:67:04[/b], Hardware address: b0:c6:9a:86:67:04 Last flapped : 2013-10-15 18:16:54 MSK (10:45:46 ago) Input rate : 0 bps (0 pps) Output rate : 0 bps (0 pps) Logical interface ae4.0 (Index 97) (SNMP ifIndex 593) Flags: SNMP-Traps 0x0 Encapsulation: ENET2 Statistics Packets pps Bytes bps Bundle: Input : 233916 0 16676099 0 Output: 1483 0 692820 0 Security: Zone: Null Protocol eth-switch, MTU: 0 H3C: # interface GigabitEthernet1/0/3 port access vlan 888 description # Etherchannel->Juniper-2/0/10 # lacp enable # interface GigabitEthernet1/0/4 port access vlan 888 description # Etherchannel->Juniper-2/0/11 # lacp enable # interface Vlan-interface888 ip address 10.30.30.1 255.255.255.0 [s5600]display mac-address interface GigabitEthernet1/0/3 Unit 1 MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s) b0c6-9a86-6610 888 Learned GigabitEthernet1/0/3 AGING [b]b0c6-9a86-6704[/b] 888 Learned GigabitEthernet1/0/3 AGING --- 2 mac address(es) found on port GigabitEthernet1/0/3 --- [s5600]display mac-address interface GigabitEthernet1/0/4 Unit 1 No Mac address on the port! Видно что LACP поднялся. Пытаюсь пингануть друг-друга, и получаю крайне странную картину: srx650# run ping 10.30.30.1 PING 10.30.30.1 (10.30.30.1): 56 data bytes 64 bytes from 10.30.30.1: icmp_seq=11 ttl=255 time=213.799 ms 64 bytes from 10.30.30.1: icmp_seq=24 ttl=255 time=198.650 ms 64 bytes from 10.30.30.1: icmp_seq=39 ttl=255 time=107.820 ms ^C --- 10.30.30.1 ping statistics --- 42 packets transmitted, 3 packets received, 92% packet loss round-trip min/avg/max/stddev = 107.820/173.423/213.799/46.799 ms [s5600]ping 10.30.30.2 PING 10.30.30.2: 56 data bytes, press CTRL_C to break Request time out Request time out Request time out Reply from 10.30.30.2: bytes=56 Sequence=4 ttl=62 time=164 ms Request time out --- 10.30.30.2 ping statistics --- 5 packet(s) transmitted 1 packet(s) received 80.00% packet loss round-trip min/avg/max = 164/164/164 ms Никто не сталкивался? [s5600]display version H3C Comware Platform Software Comware Software, Version 3.10, Release 1702P20 Copyright (c) 2004-2010 Hangzhou H3C Technologies Co., Ltd. All rights reserved. H3C S5600-50C uptime is 16 weeks, 3 days, 11 hours, 16 minutes srx650# run show system software Information for junos: Comment: JUNOS Software Release [11.4R9.4] Может у кого есть идеи куда можно посмотреть? Что самое обидное, H3C имеет крайне скудные настройкм lacp. http://www.h3c.com/portal/Technical_Support___Documents/Technical_Documents/Switches/H3C_S3600_Series_Switches/Configuration/Typical_Configuration_Example/Low-End_Ethernet_Switches_CG(V1.01)/200808/614573_1285_0.htm Точнее не имеет их вообще. Пробовал и lacp enable и включать порты в link-aggregation group 1 mode manual ae на стороне джуна переходит в UP только при lacp enable. Так же пробовал уводить в шат по очереди порты на h3c, картина пингов не менялась. Буду благодарен любой подказке. Вставить ник Quote
Butch3r Posted October 16, 2013 Posted October 16, 2013 А вы уверены на LACP так вообще настраивается? Я что-то на h3c.com не могу найти модель 5600, что это за зверь? На 5500 LACP настраивается так: Создаем бридж: interface Bridge-Aggregation1 description port access vlan 888 link-aggregation mode dynamic дальше заходим в порты, настраиваем их также как и бридж и плюсом пишем строчку: port link-aggregation group 1 После этого все настройки портов меняем заходя в int br1, он сам будет применять настройки бриджа ко всем портам Вставить ник Quote
myst Posted October 16, 2013 Author Posted October 16, 2013 (edited) А вы уверены на LACP так вообще настраивается? Я что-то на h3c.com не могу найти модель 5600, что это за зверь? На 5500 LACP настраивается так: Создаем бридж: interface Bridge-Aggregation1 description port access vlan 888 link-aggregation mode dynamic дальше заходим в порты, настраиваем их также как и бридж и плюсом пишем строчку: port link-aggregation group 1 После этого все настройки портов меняем заходя в int br1, он сам будет применять настройки бриджа ко всем портам Это LAG. В принципе только что проверил: link-aggregation group 8 mode manual interface GigabitEthernet1/0/3 port access vlan 888 description # Etherchannel->Juniper-2/0/10 # port link-aggregation group 8 # interface GigabitEthernet1/0/4 port access vlan 888 description # Etherchannel->Juniper-2/0/11 # port link-aggregation group 8 set interfaces ae4 aggregated-ether-options link-speed 1g set interfaces ae4 unit 0 family ethernet-switching port-mode access set interfaces ae4 unit 0 family ethernet-switching vlan members SSERVERS srx650# run show interfaces ae4 Physical interface: ae4, Enabled, Physical link is Up Interface index: 174, SNMP ifIndex: 591 Description: # Etherchannel to SuperServers # Link-level type: Ethernet, MTU: 1514, Speed: 2Gbps, BPDU Error: None, MAC-REWRITE Error: None, Loopback: Disabled, Source filtering: Disabled, Flow control: Disabled, Minimum links needed: 1, Minimum bandwidth needed: 0 Device flags : Present Running Interface flags: SNMP-Traps Internal: 0x0 Current address: b0:c6:9a:86:67:04, Hardware address: b0:c6:9a:86:67:04 Last flapped : 2013-10-16 08:49:08 MSK (00:46:06 ago) Input rate : 0 bps (0 pps) Output rate : 880 bps (1 pps) Ситуация несколько не поменялась. http://www.h3c.com/portal/Products___Solutions/Products/Other_Products/Switches/Quidway_S5600_Series_Switches/ Вот оно. Бриджа там нет в конфигурации да и не нужен он при LAG Edited October 16, 2013 by myst Вставить ник Quote
vurd Posted October 16, 2013 Posted October 16, 2013 1 .Возьмите первую попавшуюся железку. 2. Поднимите между ней и юнипером lacp. 3. Поднимите межуу ней и h3c lacp. 4. Что-то не поднимется, выясняем почему и копаем в эту сторону уже по конкретному вендору. Вставить ник Quote
myst Posted October 16, 2013 Author Posted October 16, 2013 1 .Возьмите первую попавшуюся железку. 2. Поднимите между ней и юнипером lacp. 3. Поднимите межуу ней и h3c lacp. 4. Что-то не поднимется, выясняем почему и копаем в эту сторону уже по конкретному вендору. Между джуном и 3комом (каким то, не помню) - поднимается. Между джуном и циской - поднимается. Вопрос в H3C, это понятно, но куда копать-ума не представляю. В документации инфы минимум. Вставить ник Quote
tros10 Posted October 16, 2013 Posted October 16, 2013 На HP 5800( Тот же H3C только под другим лейблом) настроено так: link-aggregation load-sharing mode destination-ip source-ip LAG: interface Bridge-Aggregation1 port link-type trunk port trunk permit vlan 100 link-aggregation mode dynamic link-aggregation selected-port minimum 1 Конфиг порта: interface GigabitEthernet1/0/3 port link-mode bridge port link-type trunk port trunk permit vlan 100 port link-aggregation group 1 Вставить ник Quote
myst Posted October 16, 2013 Author Posted October 16, 2013 На HP 5800( Тот же H3C только под другим лейблом) настроено так: link-aggregation load-sharing mode destination-ip source-ip LAG: interface Bridge-Aggregation1 port link-type trunk port trunk permit vlan 100 link-aggregation mode dynamic link-aggregation selected-port minimum 1 Конфиг порта: interface GigabitEthernet1/0/3 port link-mode bridge port link-type trunk port trunk permit vlan 100 port link-aggregation group 1 В том вся и проблема. Команды, доступны исключительно те, что приведены в ЭТОЙ ссылке: [s5600]link-aggregation ? group Specify aggregation group number [s5600]interface ? Aux Aux interface Cascade CASCADE interface GigabitEthernet GigabitEthernet interface LoopBack LoopBack interface NULL NULL interface Vlan-interface VLAN interface Никаких link-aggregation load-sharing Никаких interface Bridge-Aggregation1 Итд. Вставить ник Quote
