Добрый день...
делаю тест. quagga версии 0.99.21
AS64512 <- AS65000 <-> AS65001
на AS65001 получился такой конфиг
65001# sh ru
hostname zebra-as65001
log file /var/log/quagga/zebra.log
log monitor informational
hostname AS65001
log file /var/log/quagga/bgpd.log
bgp config-type cisco
debug zebra events
debug zebra packet
debug zebra kernel
debug bgp updates
password 123
enable password 123
interface de0
ipv6 nd suppress-ra
interface ipfw0
ipv6 nd suppress-ra
interface lo0
router bgp 65001
no synchronization
bgp router-id 192.168.192.42
network 192.168.1.0
redistribute static route-map blackhole-out
neighbor 192.168.192.41 remote-as 65000
neighbor 192.168.192.41 description BHPROBE
neighbor 192.168.192.41 interface de0
neighbor 192.168.192.41 ebgp-multihop 8
neighbor 192.168.192.41 update-source 192.168.192.41
neighbor 192.168.192.41 send-community both
neighbor 192.168.192.41 soft-reconfiguration inbound
neighbor 192.168.192.41 filter-list 1 in
no auto-summary
ip route 192.168.1.100/32 Null0
ip prefix-list blackhole-list seq 1 permit 192.168.1.100/32
ip as-path access-list 1 deny .*
route-map blackhole-out permit 10
description BHPROBE
match ip address prefix-list blackhole-list
set community 65001:666 additive
set ip next-hop 127.0.0.1
set local-preference 10
ip forwarding
line vty
exec-timeout 0 0
end
на AS65000 уходит для 192.168.1.100/32 маршрут 192.168.192.41
65001# sh ip bgp neighbors 192.168.192.41 adv
BGP table version is 0, local router ID is 192.168.192.42
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
             r RIB-failure, S Stale, R Removed
Origin codes: i - IGP, e - EGP, ? - incomplete
  Network          Next Hop             Metric LocPrf Weight Path
*> 192.168.1.0      192.168.192.42            0         32768 i
*> 192.168.1.100/32 192.168.192.42            0     10  32768 ?
Total number of prefixes 2
65001#
на AS65000 соответсвенно получаю
65000# sh ip bgp neighbors 192.168.192.42 routes
BGP table version is 0, local router ID is 192.168.192.41
*> 192.168.1.0      192.168.192.42            0             0 65001 i
*> 192.168.1.100/32 192.168.192.42            0             0 65001 ?
65000#
что не так... где руки выпрямить?
в доку, не отсылайте, еще больше путаница возникает..
...skip..
description blackhole
set community 65000:666 additive
! add BLACKHOLE
route-map blackhole-out deny 20
...skip..
в zebra.conf на AS65001
...skip..
!ip route 192.168.1.1/32 Null0
...skip..
вывод
65001#
У меня сделано как-то так, попробуйте
redistribute connected route-map rip-map
access-list zeus permit a.a.a.a/24
access-list zeus permit b.b.b.b/23
access-list zeus deny any
route-map rip-map permit 1
match ip address zeus
Ну или вообще не объявляйте ненужную сеть в
router bgp 65001
network 192.168.1.0
Edited by kayot
...skip...
с этим не обьявилось ничего. можно полный конфиг. (можно в л/с)
router bgp 65001
network 192.168.1.0
это через vtysh выводится так. а так в конфиге bgpd.conf стоит/прописано
network 192.168.1.0/24
мне нужно обьявить комунити для айпи/32. чтоб из сети /24 в/из AS он попал в это. и далее ушел в 127.0.0.1
У меня конфиги для rip, смысла в полном листинге нет.
У вас должно быть redistribute static route-map xxxx(а не connected, у меня ppp-bras)
Ну и network наверное не нужен вообще. В списке маршрутов он без маски показывается по стандартному соглашению, в реальности анонсируется подсеть /24 как и прописано.
redistribute .... - прописан в 1-ом сообщении
network нужен. т.к. нужно будет обьявить сеть /24 выше стоящей AS...
что еще не так...
п.с. по 3 сообщения дает пока писать
Что в итоге получить то хотелось? Навесить коммунити на маршрут 192.168.1.100/32?
set ip next-hop 127.0.0.1 в карте бесполезен, это карта для BGP, а не для маршрутизации в ядре.
Если все же коммунити на удаленной стороне, то
description BHPROBE
route-map blackhole-out permit 20
router bgp 65001
neighbor 192.168.192.41 route-map blackhole-out  out
...skip...
конечно же 192.168.1.100 из сети 192.168.1/24 отправить в "ноль" на вышестоящей зоне.
это должен делать AS65000 анализируя полученные коммунити маршрутов.
AS65001 только маркирует нужные маршруты.
т.е. конфиг в стартовом сообщении правильный?
покапаюсь с 65000.
